Biostar GeForce 6100-M9
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    So, yeah the CPU caps on this Biostar motherboard failed hard...ALL of them. It was used daily from December, 2007 to July, 2011. All the caps on the mobo are KZG. I heard that these caps tend to die after around 3 years?
    I figured it might have been the power supply, considering it's a PowerMan 350W PSU with an old group regulated design with OST caps on the Primary and Secondary. I don't think it was the PSU though cause none of the caps are bulging or leaking and the PCB doesn't look burnt anywhere.
    EDIT: I was wrong, besides the 5 KZG's that failed, there are 3 that didn't fail. And concerning the rest of the motherboard, the rest of them are OST's and they're all black. From what I have heard, OST's are mediocre but not TERRIBLE. I haven't had any OST's die on me but then again they seem to be very popular with the cheaper companies.
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Biostar GeForce 6100-M9
    KZG are bad caps from a good manufacturer. They just got that line... wrong.
    Your power supply might not have caused it, but I always like to see something a little more... beefy.
    Ludicrous gibs!
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      Yeah, this is from a friend's computer, I wouldn't run one of my computers on that wimpy thing BUT...Even with that dinky PSU, it only had to power an Athlon 64 3500+ (939), 3 sticks of RAM, and a single hard drive....No graphics card, it probably rarely peaked at 100W, so I guess the KZG's are to blame...If I were to replace them (never done it before ) would it be worth it?
      • c_hegge
        • Sep 2009
        • 5219
        I wouldn't worry about the PSU. In Win power men are good performers. It may not look beefy, but that would - probably - do 400W or even more with the ripple and voltages in spec. I reviewed a 400W In Win Power Man (PM me if you want a link) and I actually got 500W out of it. The ripple was a tad high but I've seen worse.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          Really? Yeah please send me a link cause I honestly don't think this thing could do over 350W. It has a -5V which means it's ancient and it has 18A on the 12V. I have a 300W Bestec (Which is only decent) that has 19A on the 12V and with NCC Primary caps (OST for secondary)
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            In Win designs most of their units, and they are competent. This is a single transistor forward, not really much that it needs to perform well.
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              But they can fail. I have seen Inwin Powerman with bulging Primary Capacitor (probably killed by apfc)
              • c_hegge
                • Sep 2009
                • 5219
                This one lacks PFC. It's just a standard single transistor forward. It also looks like it uses a PWM IC for the 5vsb (like the one I reviewed), rather than the two-transistor design.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Can someone help me find some Rubycon or Panasonic caps to replace these???
                  • brethin
                    • Dec 2008
                    • 1907
                    I would replace all the KZG with https://www.badcaps.net/store/produc...roducts_id=142
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Thank you!!!
                      • bp1
                        • Jul 2010
                        • 46
                        I think caps failing on the Biostar 6100-M9 is quite common. From memeory the 5 caps 3300uf near the cpu is common to go bad. I did a re-cap to one sometime ago.
                        Some useful info here http://www.punj.co.uk/punjwebfiles/e.../mbbadcap.html
