Ga-8knxp
  • Crash1hd
    • Sep 2011
    • 11
    Ga-8knxp
    Hello Everyone,
    I have attached an image of what I believe to be some bad caps. The motherboard will give off a sound of very fast beeps a couple of times on boot but nothing shows up on the screen, I have tried a different power supply and video card but both work fine in other systems which leaves it to the mobo, cpu or ram (pretty sure the ram and cpu are fine) alas I think its the mobo? Can anyone let me know if this sounds correct and if the image is showing bad caps have I just been lucky up to this point with it booting? cause they have beeen looking like this for awhile.
    THanks
    P.S. I just realized that I put this in the wrong thread (please move if possible) thanks
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Ga-8knxp
    it looks like you had a power supply that blew those, as they look baaaaad, I don't mean bloated but exploded-i'm suprised you didn't hear a pop
    yes, replace them, but it might be too late for nearby components.
    • Crash1hd
      • Sep 2011
      • 11
      Re: Ga-8knxp
      What do you mean by nearby components? like other parts?
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Re: Ga-8knxp
        Looks like Rubycon, too!
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • mariushm
          • May 2011
          • 3799
          Re: Ga-8knxp
          The circuitry near those capacitors is probably related to the generation of proper voltage for memory (remember, power supplies give 3.3v, 5v and 12v but memories are either about 2.5v for ddr1 or 1.5-1.8v for ddr2/ddr3) .
          If so, the motherboard probably can't power/recognize the memory modules properly and beeps.
          I would also check the capacitors near the agp slot as that uses 3.3v/1.5v so it may receive power from the same place (but unlikely, it's a bit far away) and should also check the ones near the cpu socket (but if the problem you have is due to bad 3.3v from psu, shouldn't have problems with cpu area as that uses 12v)
          • Crash1hd
            • Sep 2011
            • 11
            Re: Ga-8knxp
            This makes sense thank you would explain exactly what is going on will have a look at the ones around the video card (maybe post picks for confirmation)
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Re: Ga-8knxp
              I've seen many blown Rubycon MBZ like this - in all my cases, it was due to excessive heat (HP/Compaq DC5000 SFF computers have poor cooling design) so I doubt the PSU is the reason why these bulged. I suggest you check your computer and make sure it has enough airflow because Rubycon caps don't go bad for no reason.
              In any case, just replace them and all should be well. For replacements, you can use Rubycon MBZ (MCZ is a slight upgrade in ESR, but they should also work) or Nichicon HM (HN is a slight upgrade but would also likely work). Not sure which series of Samxon correspond to these (most likely either GC or GD). All of these are available at the badcaps.net capacitor store.
              • c_hegge
                • Sep 2009
                • 5219
                Re: Ga-8knxp
                Out of curiosity, what PSU do you use?
                • Crash1hd
                  • Sep 2011
                  • 11
                  Re: Ga-8knxp
                  Well First it was an Enermax 350w whisper EG365 which eventually died and then I replaced it in 2005 with the Enermax 420w EG425P-VE sfma noisetaker which is still working to this day and afaik it could have been the first one or this one that caused the error no idea since it is a system that sits in the basement and I never physically see it unless something is wrong and I cant remote into it (like now) lol
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Re: Ga-8knxp
                    If I'm not mistaken [and I might be] the Noisetakers were one of the Enermaxs with the conductive glue problem.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • Crash1hd
                      • Sep 2011
                      • 11
                      Re: Ga-8knxp
                      Is this something I should worry about? Or something I could look into as I just picked up a new mobo and I will be using this psu with it. Not too worried though since the new mobo has a 4yr warrenty
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Re: Ga-8knxp
                        The warranty doesn't cover being taken out by a PSU.
                        • Crash1hd
                          • Sep 2011
                          • 11
                          Re: Ga-8knxp
                          actually this warranty covers anything its an over the counter exchange and if its broken due to power surge they dont question it or at least they have not yet.
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            Re: Ga-8knxp
                            hahaha. I didn't realize, I actually have a VERY similar version of this board
                            my boss gave me a GA-SINXP1394, included the VRM board. with SAME bloated caps, but not burnt like yours. still booted though
                            first pics i've taken with my blackberry curve, kinda sucks
                            I recapped them with some rubycon yxg's
                            and replaced some main vrm caps KGZ's with MBZ's.
                            I'm probably going to end up putting a P4 3.4ht chip I found in a laptop in here (laptop with a desktop chip, I know)
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5042
                              • US
                              Re: Ga-8knxp
                              all I need to do now is clean the NB fan. my boss smokes like a stack and its stuck
                              • DynaxSC
                                by DynaxSC
                                06-14-2024, 03:49 PM
                                HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-12-2024, 02:20 PM
                              • Jaime Morillo
                                Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                by Jaime Morillo
                                Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                The TV was stuck on the logo and I couldn't access the update menu.
                                I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                The image result was good, but the image is inverted.
                                The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                08-18-2025, 11:38 AM
                                HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                09-06-2024, 10:56 AM
                                HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
