Asrock 939Dual-SATA2
  • amartolos
    • Aug 2011
    • 58
    This board is currently running fine, with some rare instants when it does not POST at the first time when powered up (it keeps restarting until it succeeds, usually 2-3 times) or it does not POST at all and I have to power cycle the computer. However, I would like to give a try at recapping it, because I don't intend to change my computer very soon. The same board was discussed by user gonzo0815 quite a while ago here. I just want to make sure that I won't do anything stupid, so here I am, asking the pros.
    The capacitors that are in the line for replacing are some UCC KZG 3300uF/6.3V, which already failed me on another board as shown in this thread (I want to put some Panasonic FMs instead), LTec LZP 1000uF/6.3V (-> Panasonic FM) and OST RMH 100uF/16V (-> Nichicon PW).
    The UCC KZEs around the CPU and memory slots and two UCC KMG next to the PCIe slot (which I don't use anyway) should be fine and will not be replaced.
    One last question is about the CPU fan header, which has an empty capacitor place next to it. Should a filter capacitor go here, and if yes, what value?
    Thanks a lot!
    Dan
  • larrymoencurly
    • Oct 2004
    • 960
    Re: Asrock 939Dual-SATA2
    I've seen 47uF, 25V on some mobos, but other mobos use a ceramic cap, which on some Gigabyte mobo schematics is 0.1uf, 25V.
    • amartolos
      • Aug 2011
      • 58
      Finally, managed to recap it. I can say that it is a robust mainboard, as it took a fair amount of damage during desoldering , but it survived. I used the opportunity to lap the NB and SB heatsinks, as well as the CPU heatspreader and the cooler, but unfortunately with no obvious change in idle/load temps.
      Oh well, here is the replacement list:
      OST RMH 100uF/16V, positions 6,7,17,18,30,71,72,73,83,84,85 - replaced with Nichicon VZ
      LTec LZP 1000uF/6.3V, positions 8,9,11,12,14,16,34,40,41,42,43,44,52,53,54,64,76,80,81,82,83,89,90,91,93 - replaced with Nichicon HM (whew, this was a long list)
      UCC KZG 3300V/6.3V, positions 21,22,24,25,26,27 - replaced with Rubycon MBZ
      After recapping the sound card output seems to be cleaner (before, moving windows on the screen caused some annoying buzzing). Also, when the system is put to full load (like starting prime95) the speed of the fans remains now constant (it was obviously decreasing, probably due to poor voltage regulation).
      Ah, yes, and...
      RoHS sucks.
      • Evil Lurker
        Warranty Voider
        • Feb 2011
        • 454
        Make sure you have the appropriate cool'n quiet drivers loaded from AMD's website and Windows XP set to "minimal power management". Took me a minute to figure out how to get it to work, but once that combo has been enabled the CPU clock speed should throttle down when idle.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          One last question is about the CPU fan header, which has an empty capacitor place next to it. Should a filter capacitor go here, and if yes, what value?Dan
          That cap keeps the electrical noise from the fan's motor from getting into the power distribution on the board.
          I've seen everything from 22uF to 120uF used.
          33uF, 47uF, and 100uF are probably most common.
          Go for the middle and use a 47uF unless you have none and a 33 or 100 uF is at hand.
          A 16v cap is good enough [is on 12v] as long as it's not a crap brand.
          Mann-Made Global Warming.
          - Dr Seuss
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Since I had one on the bench I looked at a C2D Intel board.
            It has a 100uF 16v there.
            - Dr Seuss
            • amartolos
              • Aug 2011
              • 58
              Wait, after I inspected more closely, I think a SMD ceramic cap should go in there. Actually, some pictures would be useful here. Maybe I can try and make some nice ones.
              Sorry for my bad english, what I wanted to say was that improving the surface finish did not bring anything. CPU throttling works well, it slows from 2200 MHz to 1000 when idle, and also Vcore drops. Idle temp is ~30 °C and it goes to ~57 °C at full load (Opteron 175 CPU). At idle, one of the cores is 3-4 °C warmer than the other, but they are at the same temperature under load. On the other hand, the cooler is probably not the best. Anyway, the south-bridge heatsink was really warped, there was obviously some free space beneath the center. I have made it flatter now.
              • Evil Lurker
                Warranty Voider
                • Feb 2011
                • 454
                Temps sound normal to me. If the board runs stable I say leave it alone and enjoy it till it finally dies.
                • Old Thrashbarg
                  • Jan 2010
                  • 20
                  Yep, I'm still running an Opteron 165 on a 939Dual board, and with the stock AMD cooler I get about 34C idle and 55C under load, with 3-4C difference between the cores. As long as the CPU stays under about 60C or so, you have nothing to worry about.
                  • amartolos
                    • Aug 2011
                    • 58
                    Concerning the fan headers and their capacitors, here are the promised pictures. I have also made pictures of the other Asrock board I have (K7VT4A Pro). I think the picture with the location of the northbridge fan shows best that a SMD cap should go to C152.
                    I am now wondering: is the 12V present at the fan header the same as 12V from the PSU, or it has gone through some filtering? And where would it be best to connect a fan, from the point of view of generated electrical noise?
                    • amartolos
                      • Aug 2011
                      • 58
                      One more comment: I would really put a fan to cool the northbridge area. gonzo0815 in his thread mentioned that the three capacitors there get very hot during the operation. There are also some power FETs soldered to the board, and on the backside one can already see a change in colour.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        The +12v for fans comes from the 20 or 24 pin main power connector.
                        The +12v for CPU[s] comes from the auxiliary +12v connector.
                        On that board it's the usual/typical 2x2 [4-pin].
                        Servers and some higher end boards [needing more CPU power] might have more pins, more connectors or both for CPU power.
                        On some boards the two +12v supplies are connected together through the board.
                        [That's the usual case on older boards.]
                        On other boards they are completely separate.
                        [That's the usual case from about the time PSUs started having multiple +12v rails.]
                        - Dr Seuss
                        • Exim
                          ASRock N100M, no picture no boot, but semi-alive
                          by Exim
                          Hi guys,
                          I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
                          ASRock N100M special features:
                          - CPU soldered to board, small Intel 12th gen
                          - iGPU
                          - four POST LEDs
                          Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
                          I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
                          Symptoms:
                          - no picture/signal on any of the display connectors,...
                          04-01-2025, 02:36 PM
                        • MasterCap
                          What IC does AsRock usually use to make the PWM signals for GPU fans ?
                          by MasterCap
                          I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
                          Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
                          But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
                          12-28-2024, 08:42 AM
                        • nolaryie
                          BIOS .bin file for ASRock B450M Steel Legend
                          by nolaryie
                          Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
                          I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
                          Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
                          If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
                          Thank you!
                          08-06-2025, 12:01 PM
                        • khanhtq0
                          Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
                          by khanhtq0
                          I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
                          I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
                          I suspect the original Intel ME and descriptor...
                          08-06-2025, 02:14 AM
                        • zklgfs
                          AsRock B560 Pro4 Possible Short on +1.8VSB
                          by zklgfs
                          I have an AsRock B560 Pro4 (boardview: https://www.badcaps.net/forum/troubl...pro4-schematic) that's completely dead (it doesn't even turn on the power supply when the power button is pressed or the power button pins are shorted). I do get about 3.4V on the power button pin, but 1.8VSB isn't there. The resistance to ground on the inductor PL53 is only about 0.1-0.4 Ohms. Am I correct in assuming that there must be a short...
                          06-07-2025, 02:22 AM
