MSI pro266 Master
  • tidus_X
    • Mar 2006
    • 10
    MSI pro266 Master
    this board was a computer build for someone about 2 years ago, it was working fine for about a year and the lady called me and said that it was locking up costantly, i took it to my shop and noticed that 2 capacitors had swollen and split, so i replaced it with a new board and figured i could fix this one sooner or later, now i am very new to this, i have never dealt with capacitors at all, but i can solder, the caps have 4700uf 6.7v on them, so maybe someone can tell me what i need and where i can get it, i took pictures of the others capacitors also so i could get someones opinion on them as well, to me they all look fine except for the 2 that split, but im not the professional, so just let me know if they need to be replaced also.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: MSI pro266 Master
    tell us the brands and values (uf and v) of the capacitors on your board that are 330uf and above. i see chhsi, tayeh, teapo there. we will tell you what to replace.
    please read
    the recapping FAQ
    the bad capacitor FAQ
    where can i buy capacitors FAQ
    and then come back with questions. we are pleased to help you. i am sure you can fix the board properly yourself no worries
    • Rainbow
      • Aug 2005
      • 1372
      Changing the 2 big bad ones should fix it. Some of the other smaller caps may fail later.
      • tidus_X
        • Mar 2006
        • 10
        alright thanks i really appreciate it, ill get all that when i get off work tonight, im hoping that i will only have to replace the 2 big ones because i dont want to have to put alot of money into the board (there are quite a few capacitors on this board) im just putting it together with some spare parts i have at my shop and im going to use this as a spare computer in my room, but anyway thanks.
        • tidus_X
          • Mar 2006
          • 10
          alright, all the caps from midway down and in the upper right corner of the board 24 of them, all the same size, green and grey, are chhsi 1000uf 6.3v caps, there are 3 different brands around the cpu, one is yellow and black the writting on it is dead against another cap so i cant tell what brand it is but i can see that it says 4v820uf on it, 2 black and silver ones tayeh 2700uf 6.3v, and theres the four big ones two are teapo 3600uf 10v which are green and gold, and the other two wich have split are 4700uf 6.3v which are also green and gold, its hard to make out the brand but i think it says LELON
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            the yellow and black sounds like a fujitsu (especially since it is 4v) dont worry about it.
            sounds like an msi badcap pizza with everything. i would replace the lelon, chssi, tayeh and teapo to do a proper final job.
            • Chris1992
              • Apr 2005
              • 561
              Also, are you located in Georgia, the US state, or Georgia, the eastern European country? This will help in recommending places to get caps.
              The great capacitor showdown!
              • tidus_X
                • Mar 2006
                • 10
                wow really? man thats a lot of caps to replace, and i live in geogia the US state sorry i didnt put that on my profile but its there now, anyway so what do i replace all the caps with other brands? the very small ones the 24 caps in total that are chhsi, i really cant see that there are anything wrong with them, is it a necessity to replace these or just a precaution?
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  its what is required to do the proper final job that will result in a stable trouble free board until it is obsolete. of course you should weigh up the costs and how you intend to use the board.
                  you can try replacing the blown caps and see if the board is working ok. i would run some http://www.memtest.org/ for a while to see if it is giving stable power to the ram, then install your os and run some test programs there.
                  i have personal bad experience with chhsi, tayeh and lelon though. if its not stable or becomes not stable later then you will have to look into replacing other caps.
                  • tidus_X
                    • Mar 2006
                    • 10
                    well where can i just get all the caps from then? or actualy can you refer me to the caps i should replace them with, im not sure what brands and such to look for, i mite as well go ahead and replace all of them, the small ones cant cost that much.
                    • tidus_X
                      • Mar 2006
                      • 10
                      hey, i see no one has put up a link since ive been gone, i havnt been around a computer for a few days, but anyway maybe someone can point me in the direction i can get the caps i need, just let me get a link and ill leave everyone alone, i swear lol
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        pm topcat the owner of these forums, he will sell you caps. otherwise digikey catalogue page 1028 Panasonic FM
                        • tidus_X
                          • Mar 2006
                          • 10
                          thanks for all your help, im just going to pm topcat because i cant make head or tales of the catalouge, thanks again.
                          • dragon3x
                            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                            by dragon3x
                            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                            power on.
                            Here are some examples :
                            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                            switching supply area).
                            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                            than 6.3 V.)
                            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                            I replaced capacitors with aluminum-polymer.
                            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                            03-21-2025, 02:46 PM
                          • slybunda
                            AA and AAA battery charger capacitors?
                            by slybunda
                            hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                            it has inside:
                            2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                            2 x 470uf 16v LZ105c branded as G.Luxon
                            not heard of these brands are they any good?
                            iv attached photos of the charger and the board inside for an idea on the type of...
                            12-24-2023, 04:41 AM
                            by sam_sam_sam
                            After all of...
                            07-13-2024, 08:14 PM
                          • chinhang899
                            KORG Piano Keyboard: Low Phones/Line Out help
                            by chinhang899
                            Hey everyone!
                            My KORG iS50 has a volume issue where the internal speakers are only acceptable above ~50% on the master slider. What's worse is that the headphone (phones out) and line outputs are extremely quiet, even at max volume. Both left and right channels are equally affected.
                            Here's what I've checked:
                            Voltages: Vcc to DAC section measures ~5V, MUSB (mute pin on the DAC) measures ~4.xxv, and the 2 op-amps show ~9V
                            Master Volume Slider: Resistance ranges from single-digit Ω to ~11kΩ (seems functional).
                            Visual Inspection: Capacitors on the main/speaker...
                            04-23-2025, 12:25 PM
                          • Ady2017
                            Are there any datasheets available for Elna RJG capacitors?
                            by Ady2017
                            I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                            05-25-2025, 02:19 PM
