Dell Dimension 4700C - V-Core Rubycon MCZ's were ALL bad
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Dell Dimension 4700C - V-Core Rubycon MCZ's were ALL bad
    Granted I missed HZ 'cause I don't buy them and they don't have that many sizes but.....
    Originally posted by PCBONEZ
    And AFAIK all Mouser carries in lytics with better specs than FM is Nichicon HN and HM.
    Mouser dropped HM and HN when they were found defective until it was clear the problem was fixed.
    Started carrying them again in '08 or '09 I think.
    Mann-Made Global Warming.
    - Dr Seuss
    • bw1
      • Sep 2010
      • 172
      Well I've got more than enough of these in stock, which by the sound of it would work for the 8 v-core. Also, I do want to use 8 now, not 5, correct?
      Still not sure what to do with the oddball... would this work? Ripple is good and impedance is 9 vs. original 12.
      *I'm calling it an oddball because it's the odd one out in this case, not because I think it's a strange cap/value in general.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        You can go either way but using 5 @1500 will probably cost more.
        If you go with 5 then make sure to spread them out in Vcore.
        The % difference makes it seem like a lot but the values are so low to start with it only amounts to a .003 ohms change.
        - Should be fine.
        [Where it's positioned right next to the 2x2 PSU connector make sure you didn't error and it was actually a 16v cap.]
        Me too.
        - Dr Seuss
        • bw1
          • Sep 2010
          • 172
          Yeah I double checked already earlier - I've got (9) 6.3's here from it.
          • bw1
            • Sep 2010
            • 172
            UPDATE: Used the (8) 820uf poly's I already had and used a Samxon GC temporarily next to the 2x2 12v to test it out and it worked for a quick power up test.
            I did discover that the power supply (stupid micro/mini narrow custom thing for these slim computers) was bad as well though, so my successful test was using a new power supply. I should have caught that, but the caps were so bad it didn't even occur to me to check the power supply.
            I'm sure that was the reason it wasn't turning on as of recently, but I have no idea how it was running up until that point, because 7 of the 8 v-core caps had a good amount of dried up electrolyte stuck to the tops of them.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              If the uF is appropriate the Samxon GC can be a permanent fix.
              - Dr Seuss
              • bw1
                • Sep 2010
                • 172
                #27
                The voltage, uF, and impedance are correct, but the ripple is under the original.
                2220 vs. 2350
                Or is that close enough?
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  I could be wrong but,,,
                  I would normally expect to see something like an MBZ in that position and I suspect the only reason they used MCZ is because they had to stock them for the VRM anyway.
                  In other words I think they used an over-spec'ed cap in aid of simplicity at the factory.
                  [That and MBZ may have already been out of production when it was built.]
                  [Back to.] I would normally expect to see something like an MBZ in that position and an MBZ's ripple would be ~2000 so I think the GC will do just fine.
                  On the Dell/Intel boards when MBZ and MCZ were both readily available it was common to see MCZ [or HN] in Vcore and MBZ [grade] every where else on the board.
                  Just after MBZ went 'poof' a lot of Dell boards started using MCZ where MBZ used to be.
                  I think that's the case here.
                  - Dr Seuss
                  • bw1
                    • Sep 2010
                    • 172
                    #29
                    Very good points - Thanks!
                    • bw1
                      • Sep 2010
                      • 172
                      #30
                      UPDATE: Replaced the V-core (Low) w/the (8) 820uf polymers. Also replaced the (4) V-core (High) with Samxon GC's. These looked just fine, but were '04 HN's, so I didn't trust them.
                      At first power-up attempt, got nothing. Tested power supply and it was bad. Replaced it and everything working. Yes, I probably could have tracked that problem down too, but replacements aren't horrible, and the thing is really cramped and overall a PITA to work on.
                      I suppose it's possible that the only "problem" when it came in was the power supply, but as bad as the V-core (Low)'s were leaking all over, it's amazing it was running as long as it did and it didn't even cross my mind to check the power supply first.
                      Overall seems like a bit much work for the computer it is, but everything has been working great for a day now, so looks like it's good to go.
                      Thanks everyone!
                      • Tesla
                        • Jul 2011
                        • 31
                        #31
                        Also, check that the 4 solder connections (for 2 loops) that hold down the NorthBridge passive Heat-Sink are soldered in good.
                        My father-in-law has a Dell 4600c. The other day, I found that one loop got so hot it un-soldered itself and the HS fell off. It also completes a circuit, so the BIOS complained about HS Failure. The one that was still in there looked like a cold solder, so I also removed and resoldered that one as well.
                        It had a pad (instead of paste) and it looked fine, so I just re-used it.
                        Works fine now.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Good call, and Congrats!
                          - Dr Seuss
                          • TCKTMB
                            • Jun 2011
                            • 56
                            #33
                            Works fine now.
                            The old familiar PINGGGGGG, those clips fly off SX280s too.
                            • barry101
                              Apple 820-3662 VCore shorted to ground.
                              by barry101
                              Hi, Would appreciate some help.
                              I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                              Get charger light but no fan spin or chime. No liquid damage.
                              Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                              Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                              With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                              Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                              06-24-2025, 07:34 AM
                            • Francisco.s
                              CPU vcore missing in HP workstation Z2 Mini 4G
                              by Francisco.s
                              Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
                              The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
                              It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
                              Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
                              The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
                              I wonder which circuit generates this enable...
                              04-22-2024, 12:35 PM
                            • mikzs
                              Rx580 8gb sapphire nitro+ turn off vcore randomly
                              by mikzs
                              Hello, this is my first post, English is not my native language but I hope you understand me. I recently got a 580 that didn't turn on the typical short mosfet, as I didn't know exactly which one was short, I unsoldered them until I got the bad one out, I was able to remove the short and identify the bad mosfet, the gpu gives video again! but it has a problem that completely turns off vcore at random times or if I try to put a load on the gpu vcore drops to 0 I don't have much idea why because I don't know much about sapphire, any advice on where I could start looking or what problem it could...
                              11-06-2023, 12:28 PM
                            • jm942
                              Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                              by jm942
                              My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                              I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                              I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                              I did voltage injection on the cpu with 0.7V and i have a current...
                              07-11-2024, 05:11 AM
                            • kotel studios
                              Epox EP 85 MVP3C-M - 3.54v Vcore regardless of jumpers
                              by kotel studios
                              Recently I got an Epox EP-85 MVP3C-M board from scrap. After fixing the broken caps I powered it on without CPU and the jumpers set to 60Mhz FSB and 2x multiplier.
                              Sadly, Vcc3 was stuck at 3.54v regardless of jumpers. Vcc2 (Vi/o I think) was also the same voltage.
                              So, I've returned to the original configuration I got the board in - 100Mhz FSB and 4x multiplier. Voltages haven't changed at all.
                              What I've tried so far:
                              replace the original N-MOSFETs with beefier 60V ones for testing
                              Resolder the resistors near the Vcore Jumper block
                              Short Vcore...
                              05-25-2025, 01:46 AM
