Finished recapping Rosewill NIC (4 months later)
  • TheLaw
    • Jan 2011
    • 477
    Hey guys,
    I had a thread in January about my onboard NIC which died, so I replaced it with a Rosewill 400-LX PCI Network Card for only $10! Unfortunately, caps on the NIC included TWBor and Cheng.
    So this thread is just a reference for anyone else who might feel like they want to do the same for their Rosewill NIC. Though I'm fairly certain that I'm the only one who has done this...but anyway!
    I bought the replacement caps a long time ago, and was too lazy to recap. Finally got the time today.
    Here's how I did replacements.
    TWBor 22uF 16V (4x) --> Panasonic FR 22uF 50V
    Cheng 10uF 16V (1x) --> Panasonic FC 10uF 50V
    I did some speed tests and no signs of instability. If anything, it's more stable. I've yet to see a dead Panasonic, so I should be good to go for the next 100 years.
    Also stuck a VRAM heatsink onto the main NIC chip. Hopefully it will prevent that flaky Realtek chip from dying, because the capacitors sure as hell aren't.
    See ya.
    On Panasonic FR...
    Panasonic FRs have to be the ugliest capacitors I have ever seen/used from a reputable manufacturer...ever. They have the same performance as FM, but are rated for a longer life. 10,000hours vs 7,000hours. They are also priced very similar to FM, which makes them a pretty good bang for your buck. Unfortunately, for certain niche markets who feed on good looking components, FR just doesn't cut it. I suppose for anything else, no one really cares...but it's a lame, for me.
  • lti
    • May 2011
    • 2545
    Re: Finished recapping Rosewill NIC (4 months later)
    I bought a Rosewill RC-100 USB card that used the same brands of caps. There was also a cap that appeared to have been soldered in by hand and was a different brand than the rest (I think it was Jian branded). I couldn't get the card to work properly. I tried removing one of the caps, but the board absorbed the heat and the solder wouldn't melt.
    Why did you recap something that cheap and crappy instead of buying a decent card in the first place?
    • TheLaw
      • Jan 2011
      • 477
      The main reason I did it this way is because this card only cost $10, and in order for me to avoid bad caps, I would have to buy a $35 Intel card, which would have worked also, but...
      Since I was already ordering some stuff off Mouser around that time, I decided just to bundle in these caps with it, and it wound up only costing me around $3. So $13 vs $35. Yes I'm that cheap.
      • TheLaw
        • Jan 2011
        • 477
        I don't have any conclusive evidence, and it would easily be my mind, but I think my network performance is indeed faster.
        • inuyasha.rules
          • May 2011
          • 43
          Rosewill = shit. Realtek is ok,other than you have crabs all over in your computer :P that's what I've ran for years, and yes a realtek card is a hair faster than a compairible intel card. That heatsink is a bit overkill but atleast it hides your crabs! Lol
          • TheLaw
            • Jan 2011
            • 477
            Nah Rosewill is decent. They do a good job keeping it affordable, though I wish they would stop with the bad caps.
            I noticed that the chip did run a little bit hot, and though I'm sure it was designed to do so, I think I might be able to help it out a bit by slapping one of them on.
            • lmcancu
              • Oct 2009
              • 158
              What thermal compound did you use to attach the heatsink to the chip? i.e. is it secure?
              • TheLaw
                • Jan 2011
                • 477
                Ermm...It was a VRAM heatsink, therefore it just sticks on.
                The actual chip is only about 1/2 inch x 3/4 inch.
                • Andre Gilbert
                  by Andre Gilbert
                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                  11-20-2024, 08:52 PM
                • AquaMan Ua
                  by AquaMan Ua
                  05-17-2025, 09:40 AM
                • stecos
                  Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                  by stecos
                  Hi everyone!
                  For my passion for technology I'm now collecting several...
                  11-28-2022, 11:39 AM
                • aa10aa10
                  Panasonic Toughbook CF-33 mk1 BIOS repair
                  by aa10aa10
                  Good day,
                  I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                  I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                  01-21-2025, 06:13 AM
                • Mnawar27
                  Panasonic CF-H2AU24EF3 bios locked
                  by Mnawar27
                  Hello ,my Panasonic CF-H2AU24EF3 I get bios password locked after factory reset, can't enter bios
                  I need help to remove it,
                  thankyou all.
                  SN; 2FKCA26876...
                  11-16-2024, 08:00 AM
