kzg / ost
  • a23d56
    • 29
    kzg / ost
    I have a MSI 7032 v1 (K8M Neo - V) main board. It has rubicons, ost, and kzg. I don't see any bulging caps, they all look good. But I read elsewhere that kzg were a problematic series.
    Should I worry about the kzg 10v 1000uf (8mm x 14mm)? Or the ost 6.3v 1500uf (8mm x 20mm)?
    I don't have a CPU to test this board with yet ...
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: kzg / ost
    both, replace them both. bonez will probably be posting here today about which ones you should replace them with
    • c_hegge
      • Sep 2009
      • 5219
      Re: kzg / ost
      Yup. If you want to get it going. Replace both the OSTs and the KZGs, since they are both problematic.
      • a23d56
        • 29
        Re: kzg / ost
        That's a big job then, about 20 in all. I think I'll set that aside for now.
        I also have an Intel D865perl with 5 bulging caps near the CPU, 6.3v 820uf. Can't read the brand, all I see is HN(M). All others are Rubycon or Nichicon and look fine. I want to see if fixing the 5 bulged ones will stabilize it. It runs, but bluescreens and fails prime95 stress test.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          Re: kzg / ost
          instability is normal for small numbers of bad caps
          I replaced 22 on a linksys srw2048, it is a big job, and having a desoldering tool can help with crappy solder and help things go faster
          • yyonline
            • Jul 2009
            • 692
            Re: kzg / ost
            HN is Nichicon. They failed due to a manufacturing defect that existed prior to 2005.
            The 820uF capacitors on this board are extra tall compared to normal 820uF HN capacitors. I'd recommend replacing them with 1500uF or 1800uF capacitors. ESR is critical in VRM capacitors, and the ESR depends on the physical size of the capacitor. The extra capacitance won't hurt anything here. Replacing them with smaller 820uF capacitors will raise the ESR and that will cause issues.
            The other option would be to replace them with 680uF polymer caps. I've done a number of Intel 865 boards replacing the electrolytic caps in the VRM with 680uF polymers, matching the polymers that are already there.
            Replace the failed HN and the board has a good chance of becoming stable again. Check the USB ports for proper function. The 865 southbridge is prone to issues there.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: kzg / ost
              Exactly right.
              Both OST and KZG have a nasty habit of failing without bloating.
              Mann-Made Global Warming.
              - Dr Seuss
              • a23d56
                • 29
                Re: kzg / ost
                Yes, they appear to be 8mm x 20mm. Looks like I can substitute these:
                https://www.badcaps.net/store/produc...products_id=63
                Thanks for helping a newbie.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Re: kzg / ost
                  Yes,
                  HM and HN with date codes from 2001-2004 should be considered bad.
                  Date code format is [letter][2 digit year][2 digit week]
                  H0322 - would be week 22 of 2003.
                  Some D865perl had them.
                  Some Intel boards also use 85C caps for the small 4&5mm caps.
                  Those can start going bad after about 4 or 5 years but it depends a great deal on hours actually used and case temp.
                  If they are happy caps in a nice cool system that grandma only drives on weekends they might last 15 years.
                  - Dr Seuss
                  • a23d56
                    • 29
                    Re: kzg / ost
                    Originally posted by PCBONEZ
                    Exactly right.
                    OK. Gonna start with the Intel board first though. 5 is about all I want to tackle right now.
                    Thanks for the help.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Re: kzg / ost
                      If they are 1800uF and not 16v caps then yes.
                      - Dr Seuss
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Re: kzg / ost
                        You should replace all the HM and HN.
                        If some have gone over the edge the rest are right on it.
                        - Dr Seuss
                        • a23d56
                          • 29
                          Re: kzg / ost
                          That would be close to 40 total. Whoa. Not sure I want to spend that much money or work that hard.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Re: kzg / ost
                            That's up to you.
                            You know, you don't have to do them all in one 'sitting'.
                            - Dr Seuss
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2640
                              Re: kzg / ost
                              another little tip: preheat the board with a hairdryer before soldering. helps a lot for the CPU VRM caps on huge heat-sucking ground traces..
                              • mockingbird
                                • Dec 2008
                                • 5484
                                Re: kzg / ost
                                PCBONEZ - to clarify, ALL '05 HM/HN are good?
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Re: kzg / ost
                                  Yes, contrary to paranoid speculation the '05 are good.
                                  I've only heard of two bad '05's and both were on questionable PSUs.
                                  Source of problem was discovered in mid 2004 and was in the International news immediately.
                                  Nichicon even admitted it publicly and recalled the bad ones at that time too.
                                  [At least the bad ones in supply channels.]
                                  They weren't screwing around on the recall because they pissed off some really big names,, like Dell, HP, Apple/MAC, Intel, and, ......
                                  I don't think they made very many in '05 because no one wanted to buy them after that.
                                  For example Mouser dropped HN and HM product lines entirely for several years after that fiasco.
                                  - Dr Seuss
                                  • a23d56
                                    • 29
                                    Re: kzg / ost
                                    I removed the 5 bulging caps. I had a hard time getting all the solder out of the holes, those little suction thingys don't work for me. So I grabbed a can of compressed air, stuck my iron in the back side of the hole, and blew air in from the other side. Worked great, the holes are all clean now.
                                    I'll invest $10 to fix the board, but that's my limit. If that fails, it's out with the trash.
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Re: kzg / ost
                                      I put a SS needle in an exacto knife handle to help clean out the holes.
                                      Iron on one side, needle on the other until it slips through.
                                      Need an all metal handle though. Not one with a plastic Collet.
                                      Homedepot and some hobby/craft stores like Michaels have the all metal ones.
                                      - Dr Seuss
                                      • Uranium-235
                                        Comrade Glimmer
                                        • Aug 2007
                                        • 5042
                                        • US
                                        Re: kzg / ost
                                        hah, never thought about doing that
                                          AMD Radeon R7 340 / R7 430 Schematic & Board View
                                          The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
                                          10-01-2024, 12:36 PM
                                        • elmark
                                          HP 15-cw1002ua strange keyboard issue
                                          by elmark
                                          HP Pavilion 15-CW1002UA
                                          S/N 5CD0251CBC
                                          P/N 7KE54EA
                                          Hello guys!
                                          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                          It powers on OK and has no other issues except the following:
                                          • CAPS LOCK does not work at all
                                          • Fn button toggles Flight Mode
                                          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                          • (with SHIFT pressed: 't%' and 'y^' respectively)
                                          I initially thought it was a keyboard malfunction (internal short, etc.),
                                          but when I press and hold...
                                          Today, 01:10 AM
                                        • flat-earther
                                          Hoover FM216LI cordless vacuum refuses to charge
                                          by flat-earther
                                          I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                          I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                          5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                          So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                          06-06-2025, 03:14 AM
                                        • M1NEBLANK SHOW
                                          MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                                          by M1NEBLANK SHOW
                                          Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                                          (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                                          Schematic and Boardview here
                                          04-04-2025, 03:57 PM
                                        • D@nt3s_1nfern0
                                          820-02016-07 [Macbook Air m1 2020 A2337 EMC3598] 5.07V 0.00A NO POWER NO CHARGE
                                          by D@nt3s_1nfern0
                                          Hi there guys. This is my first post on this forum and my first attemp to fix a problematic board. Ill give you a litle pre history of the device. The Macbook was powering on but it wasnt charging (it was showing an X sign on the battery icon) i went to my local apple authorised repair centre and they told me that they tried with a new battery and charging port but the issue was still there so they said its a board issue. The laptop belongs to my partner and she already ordered a new one but she considers the data gone on this one. I want to try my best to fix it and surprise her. The laptop at...
                                          03-17-2025, 06:00 AM
