Dell 400SC
  • Cpmiller22
    • Mar 2011
    Dell 400SC
    Hello-
    I'm new to the forums. I have a dell 400sc that has started rebooting intermittently and after some research I noticed my caps were bad (bulged and leaking). I ordered replacement caps (nichicon 820 6.3v) and replaced them on my board. After I put things back together, when I push the power switch everything spins up for barely a second but doesn't actually turn on. Any thought/suggestions would be much appreciated!
    Chris
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: Dell 400SC
    Sounds like a short somewhere. Check your soldering to make sure you didn't bridge any connections, and make sure the board is mounted properly in the case.
    Ludicrous gibs!
    • delaware74b
      • Apr 2009
      • 628
      Re: Dell 400SC
      You could also have a replacement cap reverse polarity. Reverse caps will cause power supply to 'fold back' and shut down. How do I know...... been there, done that, got the t-shirt.
      Stupidity should be a crime, especially for drivers. I have NO patience for them.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        Re: Dell 400SC
        I had a gx270 do the same thing on me after replacing some caps backwards. switched them all out again and it still did it =/
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • siuras676
          Dell XPS Plus 9320 blue screen and rebooting
          by siuras676
          I have a Dell XPS 9320 in for repair, and the machine has a strange issue.
          First, a bit of history: the laptop came in after liquid damage and was completely dead. I've repaired all the broken traces, replaced the damaged components, and it now powers on.
          However, it's now showing a Windows blue screen related to hardware (as seen in the picture), along with another Dell error I've never seen before.
          Has anyone encountered this issue on a Dell machine before and could point me in the right direction? I've checked the power rails around...
          04-07-2025, 12:10 PM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
          Dell Thunderbolt Firmware
          by SMDFlea
          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
          The SKU is in brackets (****)
          EDIT: NVM65...
          01-26-2025, 06:22 AM
