I had a typical motherboard issue with an HP yesterday where a few of the filter caps were blown. The PC still booted fine but was obviously very unstable. I have removed the three blown caps and replaced them with the same values. Problem is, with the new caps in, the PC will refuse to power on. The CPU fan moves for a second then the power supply shuts off. Something is going on with that 12v rail. I can remove the caps, and the machine powers on fine again. Plug just 'one' of the three caps in (doesnt matter which) and it refuses to power again. I've attached a pic of what I'm talking about. I've done this literally 100's of times and this is the 1st one I've had do this.
HP / Asus ptgd1-la bad caps, wont boot with replacements
by jrodefeldI would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
The model: Asus Zenbook Pro Duo UX582L
I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...-
Channel: General Capacitor Questions & Issues
09-02-2024, 04:55 PM -
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
Channel: BIOS Requests ONLY!
by trbovanLaptop is a GL731GT with the I7-9750h and GTX1650.
Full model number is gl731gt-rb71-cb
Serial: (placeholder for when I get home)
Board model: G531GT REV. 1.5
Issue: Laptop was password protected with admin password. I extracted the Bios with the CH341A and ASprogrammer. I Initially saved the backup. I then scoured the internet for a rom to flash to the chip. I found a file and flashed it. I then read it back to verify and mistakenly over wrote my backup of the original Bios.
I assembled and tested anyway. The bios worked, I was able...-
by acataI get this Asus X450LC REV 2.2 can't boot from SATA, ODD or USB flash drive.
Power on normally. Boot to bios ok.
But I can't normal boot from HDD (windows 7) just freeze on the animation. I can't boot from pre-installed SSD windows 10, bsod: driver pnp watchdog. I can't boot USB flash drive Hiren boot CD or linux mint.10-10-2023, 05:15 AM -
by lukkihapsiAsus Vivobook X515JA Laptop
Issue :
Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
Tried :
Cleaned inside for dust, applied fresh thermal paste. No Change!
Removed keyboard, Trackpad, fingerprint sensor. No Change!
Removed Internal SSD. No Change!
Updated BIOS to latest version. No Change!
Removed battery and pressing power button for 1 minute. No Change!
Weird Part :
Upon turning laptop ON, screen lights up - stays black,
I... - Loading...
