ECS (Elitegroup) MCP61PM-HM Recap questions
  • eddie97044
    • Dec 2010
    I have a motherboard out of an HP Pavillion model A6332W with an ECS motherboard Model MCP61PM-HM (Nettle2) and is in need of recapping. My question is, do I have to replace all the electrolytics on the board or just the ones around the vrm and also bulged ones. Here is a complete list of electrolytics that I see on the board including the smaller ones. Thier is 58 caps in total.
    Qty Brand Voltage Capacitance
    9 TK 6.3v 1800uf (the 4 VRM secondary caps and all others of this type on the board are bulged on top)
    3 TK 16v 1800uf (all 3 VRM primary caps look ok as do the rest listed below)
    8 Ost 6.3v 1000uf
    5 G-Luxon 16v 470uf
    14 G-Luxon 16v 100uf
    10 G-Luxon 25v 10uf
    9 G-Luxon 25v 22uf
    This could get expensive.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: ECS (Elitegroup) MCP61PM-HM Recap questions
    The small G-Luxons don't usually go bad. Maybe change the 470uF ones but not below that. TK=OST and should be all replaced.
    A working TV? How boring!
    • c_hegge
      • Sep 2009
      • 5219
      Yup. Replace everything 470uF and higher.
      Use these for all the 1800uF 6.3v caps, these for the 1800uF 16v caps on the VRM in, these for the OST 1000uF caps and these for the 470uF caps.
      • eddie97044
        • Dec 2010
        We actually have 3 of these boards in the house at the moment, so probably will do mine next after I get my roommates redone. His was bsod'ing and crashing like mad. That's when I pulled the case and noticed the bulging capacitors. Thanks for the input on what to get. It saves me trying to cross them over to a better brand. I think rubycon seems to be the top of the line at the moment as far as reasonably priced capacitors go.
        Just finished replacing caps on a board out of an older Dell. They where the nichicon HM(N) series that are known to be bad around the time that the pc was manufactured. Overfilled from the factory I guess. The caps where so bad in that pc that it wouldn't even post. Worked fine after I replaced them.
          ASUS P5GC-MX motherboard recap
          by momaka
          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
          So here is what the motherboard looked like with its original caps:
          CPU VRM area up close…...
          01-27-2021, 11:59 PM
          no-name Radeon 9600 XT recap and cooler
          by momaka
          I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
          This one was actually suggested to me by ChaosLegionnaire....
          11-06-2020, 07:54 PM
        • varunviolin007
          Looking for someone to recap Dell XPS T450 motherboard (Live in suburbs outside of Philly)
          by varunviolin007
          Hi guys,
          I’m looking for someone in the Northeast to do a full electrolytic capacitor recap on a working Dell Dimension XPS T450 motherboard (it's an Intel 440BX, Slot 1). The board runs mostly fine but is beginning to freeze after warm reboots (turns back on for 30 secs or so and then freezes up but is perfectly fine after 12 hr cool down).
          I’d be sending just the bare motherboard (CPU, cards, bracket, battery all removed). I’m located in Chadds Ford, PA and happy to ship within the US.
          Looking for someone experienced with older PC boards who uses...
          07-29-2025, 11:53 PM
        • Foetuss
          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
          by Foetuss
          Hi all
          Hope this is in the correct place.
          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
          Could use some double checking to see if I'm not doing something stupid .
          Pictures of the boards are attached.
          What I will be replacing with what : (planned)
          Soltek Golden ::
          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
          01-18-2025, 11:44 AM
        • Michael Rath
          BIOS Passwords for many Elitegroup Classmate EC10IS2
          by Michael Rath
          i have many Elitegroup EC10IS2 with empty BIOS battery. They have all a factory standard password, that i don´t know.
          Remove battery / flush CMOS Memory / setting jumper will not work.
          I also try the Unlock Key-Method from here (which not work): https://www.badcaps.net/forum/troubl...password/page3
          Maybe you will find the standard password in BIOS or CMOS data (both txt-files are binary files with wrong extension)...
          01-05-2025, 05:13 PM
