DELL XPS 600 BAD CAP Leaked NO BOOT
  • Mephisto
    • Nov 2010
    Expensive computer with dual Nvidia 7800, etc... Would they replace/fix this??
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: DELL XPS 600 BAD CAP Leaked NO BOOT
    I would.
    But then again, I've been know to recap 486's.
    "They" who?
    Mann-Made Global Warming.
    - Dr Seuss
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      If its the XPS600, those are prone to other issues. There's usually 2x 2700uF caps and a toroid coil right behind them that burns to a crisp. Recapping and replacing the coil usually only fixes half of them.... I'm about 50% with them.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        I think maybe it was a warranty question.
        That's why I asked who "they" are.
        - Dr Seuss
        • dsamis
          • Sep 2011
          I just had a neighbor bring over one with the same issue. I was about the order the caps but was wondering if anyone, maybe topcat, knew what the toroid coil or compatible part number would be? thanks
          • MSNKat
            • Sep 2011
            Interesting, I just received an XPS 600 with the same issue - though it boots with a warning "Low System Voltage". Otherwise it works great.
            Here's a shot of the failed components:
            Dell XPS 600 - Failed caps/inductor
            I'm going to at least try to replace the caps but does anyone know the value of that burned up inductor? It's so blackened I have no way of identifying it. Is it something I can order from this site?
            • brethin
              • Dec 2008
              • 1907
              I would not call this Expensive these days unless you consider $100 expensive since that is what they sell for on Ebay these days. It is like saying my 286-16 with 4 sticks of 4 meg of ram I payed $3500 for 20+ years ago is expensive. As far as computers go you can 1/2 the price you paid every 6 months to get a close to value of what it is worth now.
              • MSNKat
                • Sep 2011
                I think you underestimate the demand for these. There are two that sold just recently on Ebay for $550 and $350, and those aren't even the top end units. There are also three of the motherboards from these that went for between $280 and $315. The XPS 600 has aged very well, and is worthy of repair if recaping is all that's needed.
                My only issue is that no one seems to know what the specs are on the inductor.
                • Z28Rodeo
                  • Jul 2011
                  • 8
                  In the event you're still interested I've got the #'s.
                  - Cor
                  • TCKTMB
                    • Jun 2011
                    • 56
                    I'd be interested. I fixed a couple of these by cleaning the coil and re-wrapping with magnet wire of the same diameter and turns.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16956
                      That's what I've always done with them, and they work every time. The boards that don't work after repair have other things wrong with them.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • Z28Rodeo
                        • Jul 2011
                        • 8
                        OCL: 0.18
                        TOL: 20%
                        DCR: 0.00145
                        I rating: 18.00
                        - Cor
                        • XmouseX
                          • Aug 2011
                          • 158
                          • US
                          how many turns? Does anyone know by chance. I am trying to repair my coil...thanks
                          • Z28Rodeo
                            • Jul 2011
                            • 8
                            2 loops
                            - Cor
                            • Sailman
                              Dell inspiron 3558 cpu frequency drops after boot
                              by Sailman
                              Hello
                              I have Dell inspiron 3558 motherboard number 14216-1 Rev: A00
                              the laptop came dead (no boot and no lights) to me and I changed:
                              1- pu4503 (tps 512525)
                              and
                              2- EC (nuvton npce285)
                              then the laptop works but after it boot to windows the Cpu frequency drops to 0.48ghz (wont go up after that) and fan goes full speed, it also do that if I boot from Windows PE.
                              I tried different bios's with clear me same problem and another EC nothing changed.
                              both cpu and gpu are cold with this happen.
                              Anyone have any idea what is the problem?...
                              04-22-2023, 04:57 AM
                            • hinisa
                              Xiaomi router freezes at boot after re-capping
                              by hinisa
                              I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                              When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                              After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                              Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                              07-08-2023, 05:58 AM
                            • trix11
                              Dell Precision T1650 MT Workstation bricked after BIOS update
                              by trix11
                              I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                              - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                              - Dell Precision T1650 mid tower Workstation
                              - Xeon E3-1225 V2
                              - 32Gb PC3-12800E RAM
                              - 4Tb SATA HDD
                              - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                              I see now that others have experienced like issues e.g.:
                              - https://www.dell.com/community/Prec...
                              10-24-2022, 10:35 PM
                            • mr.Data
                              Dell Latitude E5590 NO BOOT comes on and goes off
                              by mr.Data
                              I have a Dell Latitude E5590 that was working fine but suddenly it wont start.
                              The power light comes on and then after a couple of seconds goes off.
                              I have seen this many times with Dell and mostly it's the memory or an empty BIOS battery.
                              I have checked these things but none of them seem to be the issue.
                              Any ideas?
                              03-13-2023, 05:52 AM
                            • bmxlovah
                              Dell Precision T7910 no bios, no post after applying SAS/RAID setup
                              by bmxlovah
                              My Dell Precision T7910 died after enabling onboard SAS controller and applying RAID settings. There were no hardware changes between working and not working state, only setup (via bios -> controller settings). After applying settings and reboot PC turns on, flash leds (normally) but there's no further action, it just stays on with no graphics and no keyboard led's on. There's no Dell logo, nothing. I've tried resetting bios by jumper, replacing cpu's, replacing ram, removed/replaced cmos battery, disconnecting all drives etc. I've also dumped .bins from mobo chips SLI1 (16...
                              11-24-2022, 06:29 AM
