Expensive computer with dual Nvidia 7800, etc... Would they replace/fix this??
DELL XPS 600 BAD CAP Leaked NO BOOT
Re: DELL XPS 600 BAD CAP Leaked NO BOOT
I would.
But then again, I've been know to recap 486's.
"They" who?
.Mann-Made Global Warming.
- Dr Seuss
If its the XPS600, those are prone to other issues. There's usually 2x 2700uF caps and a toroid coil right behind them that burns to a crisp. Recapping and replacing the coil usually only fixes half of them.... I'm about 50% with them.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
I think maybe it was a warranty question.
That's why I asked who "they" are.
- Dr Seuss
Interesting, I just received an XPS 600 with the same issue - though it boots with a warning "Low System Voltage". Otherwise it works great.
Here's a shot of the failed components:
Dell XPS 600 - Failed caps/inductor
I'm going to at least try to replace the caps but does anyone know the value of that burned up inductor? It's so blackened I have no way of identifying it. Is it something I can order from this site?Comment
I would not call this Expensive these days unless you consider $100 expensive since that is what they sell for on Ebay these days. It is like saying my 286-16 with 4 sticks of 4 meg of ram I payed $3500 for 20+ years ago is expensive. As far as computers go you can 1/2 the price you paid every 6 months to get a close to value of what it is worth now.Comment
I think you underestimate the demand for these. There are two that sold just recently on Ebay for $550 and $350, and those aren't even the top end units. There are also three of the motherboards from these that went for between $280 and $315. The XPS 600 has aged very well, and is worthy of repair if recaping is all that's needed.
My only issue is that no one seems to know what the specs are on the inductor.Comment
That's what I've always done with them, and they work every time. The boards that don't work after repair have other things wrong with them.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by mpower1226Hi masters, need your help in solving this mystery.
i have a dell optiplex 7090 micro that i bought from local kijiji.
when i turn it on, error comes out saying no hard disk.
i go to bios to check the boot option, only httpboot shows. If i try to add boot option, it only shows file search but nothing happens when i click.
i took out the ssd and put it into old laptop and format and installed the windows 10 and put it back into the desktop. It boots up and same error again no hard disk.
it seems as if the computer doesnt recognize the ssd...-
Channel: BIOS Requests ONLY!
by mamado mosaSo i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
The problem is it takes more than a minute to boot ..
The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
Can someone suggest something to fix -
by estabilitoHello, i just swapped CPU(i5-8350u) from fujitsu lifebook e548 to Dell Latitude E7490 Board, all resistances are fine, laptop wants to boot but after 1 second draw of 0,3A its turning off, after pressing power on button same situation. I've cleaned ME region and same situation. Is it boot guard problem - and if it is, is it any chance to bypass this or this cpu just can't be used in Dell.
by Raven7032Hello everyone!
Stucked with this problem.
Model: Dell G15 Ryzen Edition
Board: GDL LA-K454P
Symptoms:- Board powers on (consumption ~0.5A), but no boot or display.
- Fans spin briefly, keyboard backlight turns on, then fans stop.
- Can be shut down via power button (EC active).
- No POST, no BIOS splash, no backlight.
- Led is blinking 2 orange 1 white
- No activity on SPI bus (no CS#, no CLK, no MOSI/MISO) even after pressing power.
- No APU_PCIE_RST# - 0V
- All voltage rails present: +1.8V, +0.75V, +3VS, +5VS, VDDCR_VDD, VDDCR_SOC, DDR VDDQ, VTT.
- EC_RSMRST#
- Loading...
