B450 LED Standby Behavior
  • calipso99
    • Nov 2023
    • 11
    • Venezuela
    So i got a B450 mother with a Ryzen APU, if i turn on the power supply without the CPU installed, motherboard standby LEDs will turn on and remain on, if i do the same but with the cpu installed, motherboard stand by lights will turn on and off and then remain off.
    has anyone seen that kind of behavior?
    • 31291
    Re: B450 LED Standby Behavior
    did it ever work with that part number cpu?
    these boards are a bastard because the cpu MUST be supported by the bios.
    • calipso99
      • Nov 2023
      • 11
      • Venezuela
      Its a used board, i dont know what cpu used to run on this board, previous owner told me he hasnt touched the bios. My chip is a Ryzen 5 3400G tho. and someone has also recommended me flashing back to a previous bios
      thanks for replying tho.
      • calipso99
        • Nov 2023
        • 11
        • Venezuela
        Flashing back to a bios previous to Ryzen 5000 series release didnt do anything
          • 31291
          i would have flashed the newest bios - not an older one.
          btw, the bios writes to the syscon - you cant downgrade the syscon - i think AMD calles it AGESA.
          • calipso99
            • Nov 2023
            • 11
            • Venezuela
            I flashed to newest bios before, and still wont post. all i want to know is that the board has good PCH. everything else is fixable.
              • 31291
              how are you flashing it?
              • calipso99
                • Nov 2023
                • 11
                • Venezuela
                flashback button on the back, this model has that feature. ive seen guides about it and motherboard seems to do the flashback with no issues.
                  • 31291
                  your lucky,
                  i have a B350 here that doesnt have that feature.
                  it uses a specialised flash chip so i cant even do it the hard way till my new programmer arrives from china that can flash in 4bit mode!
                  • calipso99
                    • Nov 2023
                    • 11
                    • Venezuela
                    your lucky,
                    I would gladly swap that flashback feature for a working motherboard or system. but... it is what it is, electronics can be so dodgy and finicky
                    • calipso99
                      • Nov 2023
                      • 11
                      • Venezuela
                      your lucky,
                      Being honest i forgot to mention something about the board, someone borrowed me a multimeter, which i set in continuity mode, started testing voltage rails on the power connectors to ground, got beeps on most of them. CPU side was giving me beeps, and the 24 pin was giving a lot of beeps on a lot of the pins.
                        • 31291
                        switch to resistance mode.
                        a beep just means 50 ohms or less - it could be a capacitor charging
                        that said, shorted fets wouldnt be unusual.
                        • PNI E.
                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                          by PNI E.
                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                          03-17-2025, 04:23 AM
                        • madsox
                          Harman Kardon AVR 171S - standby led lights up, does not turn on
                          by madsox
                          Greetings!
                          Thank you in advance for your understanding, I am writing to you through a translator.
                          A Harman Kardon AVR171S amplifier was given.
                          The history of the machine is as follows:
                          It was faulty when I bought it, I want to fix it.
                          I replaced the HDMI switch and one of the DAC ICs in it.
                          After that it worked without a problem.
                          I watched a movie using the amplifier, and at the end the amplifier got really hot.
                          The cooling was faulty, I will fix this later.
                          I switched it to standby mode, waited for...
                          09-24-2022, 10:46 AM
                        • julianmustofa
                          Dell 3421 wont turn on with strange behavior
                          by julianmustofa
                          Hi all
                          I've been working on dell 3421 that won't turn on/charge
                          Specs: i3-3217U no discrete gpu
                          The behavior is
                          -won't charge (charging light up for 3 second and goes away)
                          -won't turn on if both battery + power adapter plugged in
                          -in other way it can turn on with either power adapter only or battery only
                          But sometimes all this issue goes away with no clear reason.
                          Does it indicates faulty board chipset?
                          08-30-2023, 06:29 AM
                        • pajdek
                          Lenovo Y700-17ISK turn on and off
                          by pajdek
                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                          09-20-2023, 02:49 AM
                        • valvashon
                          Samsung LS23PTNSF/ZA- Erratic behavior 20 minutes after turn on
                          by valvashon
                          This smaller Samsung TV will turn on fine and work fine at first. By this I mean that it will respond properly to the remote commands with channel up and down working and volume up and down working, etc.
                          After the set has been on for a while- 20 to 30 minutes- it stops responding or responds erratically to commands from the remote or the front panel buttons. Remote is fine, works well with other TV's.
                          My guess is caps in the power supply warming up and changing value leading to the erratic behavior. TV does not act erratically unless you try to change a channel or something like...
                          06-16-2023, 01:22 PM
