Dell 3421 wont turn on with strange behavior
  • julianmustofa
    • Dec 2021
    • 39
    • indonesia
    Hi all
    I've been working on dell 3421 that won't turn on/charge
    Specs: i3-3217U no discrete gpu
    The behavior is
    -won't charge (charging light up for 3 second and goes away)
    -won't turn on if both battery + power adapter plugged in
    -in other way it can turn on with either power adapter only or battery only
    But sometimes all this issue goes away with no clear reason.
    Does it indicates faulty board chipset?
  • mon2
    • 16568
    Re: Dell 3421 wont turn on with strange behavior
    Review the DCin mosfets. Often the 2nd DCin mosfet will be leaky. Review the sticky article above by @Piernov on charger circuits.
    • julianmustofa
      • Dec 2021
      • 39
      • indonesia
      Digging around and just found out that 5v/3v tps51225 was faulty and glowing hot
      • mcplslg123
        • Jun 2015
        • 7263
        • india
        Before going for replacement of 51225 Ic,do take measurements of PSL logic circuit. Often, its PSL fault and not the PWM itself. Other reason could be shorting in RTC circuit.
        • julianmustofa
          • Dec 2021
          • 39
          • indonesia
          Ah, I'am so late for this.
          You're correct, the pwm it self was fine
          Still searching the rabbit hole..
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • electronics and DJing/producing music
            I'd check the peripherals that are connected in standby. Could be a bad keyboard or touchpad or the KBC chip itself.
            A working TV? How boring!
            • mcplslg123
              • Jun 2015
              • 7263
              • india
              Going by this board, its either shorted/leaky RTC and/or PSL circuit.
              • masoksian
                Dell latitude e7470 not turn on .power buton on off and Run Power problem
                by masoksian
                I am dealing with the problem of turning on and off my Dell e7470 notebook.
                The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                The system does not turn on, there is no post.
                I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                The problem continues in the same way.
                I tried to turn on the Fn key, nothing came to the screen....
                02-15-2025, 12:08 PM
              • Bowline
                by Bowline
                06-11-2025, 10:13 AM
              • Naineesh1
                DELL inspiron 15-3515 GDM54 LA-L245P Won't turn on
                by Naineesh1
                I just recieved a working laptop for a quick dc port swap, i tested the laptop on battery it worked, tested dc port issue felt loose, so disassembled the laptop and removed battery connector, swapped the dc port, re-connected the battery connector, inserted dc pin, white led glowed up - stable, pressed power switch, but it didn't turn on, no fan spin and no display. just 1 white led that glows up, doesn't move to orange (charging), i check voltage (battery : 11.37v) (dc input port : 19.3v)(bios : 1.75), i am stumped, there is no shorting on board.
                Schematic diagram : bios chip volt...
                07-05-2025, 01:20 AM
              • javieromex
                Dell G15 5511 LA-K452P won't turn on
                by javieromex
                Hello, any help will be apprecited!
                • Model: Dell G15 5511
                • MB: LA-K452P
                • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
                • Customer reported it was turned off and left plugged in during the night and thats it...
                • No signs of liquid damage or burned components.
                Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
                I have checked so far:
                04-17-2025, 12:44 PM
              • meron1122
                Dell Latitude 7320 LA-K371P 3.0 - won't turn on
                by meron1122
                After pressing the power button, it doesn't turn on. No increased power consumption.
                Additionally, the 5V USB draw only appears in one cable position on both connectors - no negotiation for higher voltages.
                The power LED glows red as long as I hold the power button
                The PU200 coil beeps, but it doesn't receive the EN signal to turn on and supply voltage to the RAM.
                +3.3V_ALW / +5V_ALW -> present
                ALW_PWRGD_3V_5V -> present
                +3.3V_PRIM -> present
                +1.8V_PRIM -> present
                +VCCIN_AUX -> present
                PCH_RSMRST# -> none
                PJP405 ->...
                03-11-2026, 12:43 PM
