Recapping Asus Board with Cool Stack
  • Mthrboard
    • Oct 2010
    Does anyone have any tips on how to properly remove the capacitors that are attached to the cool stack board on my Asus P5AD2-E Premium board? I've been trying for about an hour now to get the bad caps out, but I just can't get the solder to melt completely around the leads. I wicked out the top layer on the cool stack board itself, but it looks like there's another layer on the actual motherboard underneath. I have a 40 watt Weller iron with the base cranked all the way up. I was able to remove the other caps that aren't attached to this cool stack with no troubles at all.
  • Toasty
    • Jul 2007
    • 4171
    Re: Recapping Asus Board with Cool Stack
    Higher power iron and larger(wider) tip and use just the corner. Mine is a 3/16" wide, 800°F tip that does okay. None do well as these are through 2 circuit boards. Heat the other side of the board with a hair dryer to assist you, and leave it running while you work. Flux and add solder to each joint to increase the heat conduction.
    The Cool Stack works well, no?
    Which ones are you trying to remove?
    VCore is Panasonic FL, and VRM is Ruby MBZ. They're fine.
    The one ringer is an OST 1500uF that looks like a Ruby (same purple sleeve) on the corner of the CPU area towards the RAM. All the Ltec 820uF have to go.
    Toast
    veritas odium parit
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      whats a cool stacK?
      • jeelani
        my brother use a revoke station to remove the bad caps
        • mockingbird
          • Dec 2008
          • 5484
          Process for removing caps from multilayered PCBs:
          1) Apply flux to the pins
          2) Apply a little solder to each pin
          3) Heat one pin andwith your hand underneath rock the cap back and forth while heating each side
          Adding solder to the pin adds surface area for the heat to contact and melt the solder. Take your time and be patient, don't let the iron slip and damage the traces.
          You don't need a high powered iron, any 25 watt junk iron can do this.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            NOT!
            Too low of watts and you are heating the whole PCB slowly vice just the joint quickly.
            Beyond the fact it will take FOREVER to melt the solder you are highly likely to burn the pads right off the board.
            Some people get by with a 40 watt but even that is too 'light' for most people.
            For most people the sweet spot is the 50-60 watt range.
            Mann-Made Global Warming.
            - Dr Seuss
            • Toasty
              • Jul 2007
              • 4171
              FWIW: The correct name is Stack Cool.
              Huh? What's a revoke station?
              Process for removing caps <snip>
              Not correct for multilayer boards. Definitely not correct for -this- board in -this- area. It is TWO boards under the CPU/VRM area with a small gap in between (think 1 piece of paper). It's heavily plated and double sided.
              Fortunately the only caps that probably need replacement are those I mentioned in Post 2, the "ringer" OST and the Ltec's.
              Toast
              veritas odium parit
              • mockingbird
                • Dec 2008
                • 5484
                Originally posted by PCBONEZ
                NOT!
                As a testament to my success, I write to you this message on a Soltek 848P board where I had to do just this. I had to replace around 10 capacitors with Sanyo equivalents. Judging by the newfound stability of my system, the job was a success. I did this when I had a 25 watt iron. I now use a 35 watt iron, and while it isn't easy to do, it is quite possible. It just needs some patience, but in my opinion, it is certainly worth it - that is - not having to purchase a relatively expensive iron.
                I also recap Dell GX240s all the time with excellent results.
                My iron is generic, and my electronics store miraculously carried the obscure thread-in bits which are out of production.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Either you don't actually know the watts or your iron, you are an abomination, or you have made deals with the devil.
                  I suspect two of the three.
                  - Dr Seuss
                  • Toasty
                    • Jul 2007
                    • 4171
                    Ouch!
                    LOL!
                    veritas odium parit
                    • Pyr0Beast
                      • Feb 2009
                      • 406
                      When 60W iron in the shop costs few bucks more than 25W one, saving money really falls out of question once you encouter problems
                      Also 1000W heat gun helps heaps.
                      • larrymoencurly
                        • Oct 2004
                        • 960
                        Are you using Chipquik or some other very low temperature solder? Because 25W is barely enough for desoldering single-layer boards, and I've had problems desoldering DIP chips from double-layer boards with less than 40W. I've found that the Radio Shack 45W desoldering iron, modified to minimize heat loss (insulate the top, cut the pipe to the sucker bulb), can do 4-layer boards.
                        • mockingbird
                          • Dec 2008
                          • 5484
                          No, I'm not using chipquick. Your problem is your flux is weak. I use plumbing flux with my 25 or 35 watt irons and I have no problems. I can even desolder large coils from multi-layered boards. The 35-watt I found in the trash. If this hobby makes me a million dollars someday, I might consider investing in one of those overpriced irons, but until then, I refuse to pay.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            I don't care if you do use -ACID BASED FLUX-.
                            25 watts won't do it.
                            - Dr Seuss
                            • mockingbird
                              • Dec 2008
                              • 5484
                              It has, and it does. In fact, I have four Dell GX240 boards I need to recap. I think I'll order a bunch of Samxon from Topcat for this one. Just yesterday I had to replace a GX240 board with blwon Nichicons, and the replacement I soldered is working fantastically.
                              If you want pictures, I'll be glad to oblige.
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Only if you get some good close-ups so I can point out the acid damage that will cause the eminent failure.
                                - Dr Seuss
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  I don't use "massive amounts" - nowhere enough to cause damage to the PCB screen. Just a little dab on the joint - enough to encourage some melting - and I have stuff I recapped with this method working for years now. When I get the caps I'll do it.
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    If you got your solder irons from trash cans then you have no idea if the previous owner stuck a 35w handle on a 40-50w iron or upgraded the element.
                                    IOW: You don't know what watts your iron is.
                                    - Dr Seuss
                                    • Pyr0Beast
                                      • Feb 2009
                                      • 406
                                      Might work with a big 25W iron, which takes 10 minutes to warm up and has enough heat capacity to do (a quick) job.
                                      But personally, I use 45W iron which is registers as 65W (240 instead of 220V)
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Hahahaha
                                        Talking like 2 days to recap one board there....
                                        - Dr Seuss
                                        • DynaxSC
                                          ASUS STRIX Z490-F GAMING - No POST, stubborn board
                                          by DynaxSC
                                          I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
                                          The situation looks like this:
                                          After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
                                          1. RTC oscillates normally (32.768KHz).
                                          07-08-2022, 05:45 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • ShadowAi12
                                          ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                                          by ShadowAi12
                                          I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                                          • The board enters a "ready to power on" state after plugging in the PSU.
                                          • Pressing the power button increases power draw.
                                          • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                                          Measurements:
                                          (taken after pressing the power button, while the board is attempting to start)
                                          • H_SKTOOC#
                                          06-11-2025, 01:05 PM
                                        • jimbodriver
                                          Faulty ASUS X99-PRO board. Some progress with repair. Need advice\help please.
                                          by jimbodriver
                                          I am trying to learn electronics repair. I purchased a “faulty for spares/repairs” ASUS X99-PRO/ USB 3.1 motherboard for a very low price from ebay – a good enough price to offset the high probability that the board was completely toast and not realistically repairable.
                                          Initial results:
                                          Board would power-cycle when turned on either with switch on board or shorting pwr pins. Fan would spin for a second or so and a QCODE of 00 would display then it would power off and then do the same thing again over and over. I think maybe 2 times in about 100 attempts...
                                          03-20-2022, 02:30 PM
