Does anyone have any tips on how to properly remove the capacitors that are attached to the cool stack board on my Asus P5AD2-E Premium board? I've been trying for about an hour now to get the bad caps out, but I just can't get the solder to melt completely around the leads. I wicked out the top layer on the cool stack board itself, but it looks like there's another layer on the actual motherboard underneath. I have a 40 watt Weller iron with the base cranked all the way up. I was able to remove the other caps that aren't attached to this cool stack with no troubles at all.
Recapping Asus Board with Cool Stack
Re: Recapping Asus Board with Cool Stack
Higher power iron and larger(wider) tip and use just the corner. Mine is a 3/16" wide, 800°F tip that does okay. None do well as these are through 2 circuit boards. Heat the other side of the board with a hair dryer to assist you, and leave it running while you work. Flux and add solder to each joint to increase the heat conduction.
The Cool Stack works well, no?
Which ones are you trying to remove?
VCore is Panasonic FL, and VRM is Ruby MBZ. They're fine.
The one ringer is an OST 1500uF that looks like a Ruby (same purple sleeve) on the corner of the CPU area towards the RAM. All the Ltec 820uF have to go.
ToastLast edited by Toasty; 11-02-2010, 09:57 PM.veritas odium parit -
Process for removing caps from multilayered PCBs:
1) Apply flux to the pins
2) Apply a little solder to each pin
3) Heat one pin andwith your hand underneath rock the cap back and forth while heating each side
Adding solder to the pin adds surface area for the heat to contact and melt the solder. Take your time and be patient, don't let the iron slip and damage the traces.
You don't need a high powered iron, any 25 watt junk iron can do this.Comment
Too low of watts and you are heating the whole PCB slowly vice just the joint quickly.
Beyond the fact it will take FOREVER to melt the solder you are highly likely to burn the pads right off the board.
Some people get by with a 40 watt but even that is too 'light' for most people.
For most people the sweet spot is the 50-60 watt range.
.Last edited by PCBONEZ; 12-03-2010, 12:23 PM.Mann-Made Global Warming.
- Dr Seuss
FWIW: The correct name is Stack Cool.
Huh? What's a revoke station?
Fortunately the only caps that probably need replacement are those I mentioned in Post 2, the "ringer" OST and the Ltec's.
Toastveritas odium paritComment
NOT!
I also recap Dell GX240s all the time with excellent results.
My iron is generic, and my electronics store miraculously carried the obscure thread-in bits which are out of production.Comment
Either you don't actually know the watts or your iron, you are an abomination, or you have made deals with the devil.
I suspect two of the three.
- Dr Seuss
Are you using Chipquik or some other very low temperature solder? Because 25W is barely enough for desoldering single-layer boards, and I've had problems desoldering DIP chips from double-layer boards with less than 40W. I've found that the Radio Shack 45W desoldering iron, modified to minimize heat loss (insulate the top, cut the pipe to the sucker bulb), can do 4-layer boards.Comment
No, I'm not using chipquick. Your problem is your flux is weak. I use plumbing flux with my 25 or 35 watt irons and I have no problems. I can even desolder large coils from multi-layered boards. The 35-watt I found in the trash. If this hobby makes me a million dollars someday, I might consider investing in one of those overpriced irons, but until then, I refuse to pay.Comment
I don't care if you do use -ACID BASED FLUX-.
25 watts won't do it.
- Dr Seuss
It has, and it does. In fact, I have four Dell GX240 boards I need to recap. I think I'll order a bunch of Samxon from Topcat for this one. Just yesterday I had to replace a GX240 board with blwon Nichicons, and the replacement I soldered is working fantastically.
If you want pictures, I'll be glad to oblige.Comment
Only if you get some good close-ups so I can point out the acid damage that will cause the eminent failure.Mann-Made Global Warming.
- Dr Seuss
I don't use "massive amounts" - nowhere enough to cause damage to the PCB screen. Just a little dab on the joint - enough to encourage some melting - and I have stuff I recapped with this method working for years now. When I get the caps I'll do it.Comment
If you got your solder irons from trash cans then you have no idea if the previous owner stuck a 35w handle on a 40-50w iron or upgraded the element.
IOW: You don't know what watts your iron is.Mann-Made Global Warming.
- Dr Seuss
- Dr Seuss
Assuming...7 Photos -
by DynaxSCHi,
I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
The situation looks like this:
After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
1. RTC oscillates normally (32.768KHz).
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by ShadowAi12Hi,
I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.- The board enters a "ready to power on" state after plugging in the PSU.
- Pressing the power button increases power draw.
- Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
(taken after pressing the power button, while the board is attempting to start)- H_SKTOOC#
06-11-2025, 01:05 PM -
by jimbodriverHi everyone,
I am trying to learn electronics repair. I purchased a “faulty for spares/repairs” ASUS X99-PRO/ USB 3.1 motherboard for a very low price from ebay – a good enough price to offset the high probability that the board was completely toast and not realistically repairable.
Initial results:
Board would power-cycle when turned on either with switch on board or shorting pwr pins. Fan would spin for a second or so and a QCODE of 00 would display then it would power off and then do the same thing again over and over. I think maybe 2 times in about 100 attempts... - Loading...
