Mini pc board no charging, no lights.
  • Cryogen
    • Jan 2015
    • 91
    Re: Mini pc board no charging, no lights.
    Dyna I am happily married and with many kids but I must tell you that I really love you. Sorry my buddy.
    You really saved me.
    Thanks to fellow Brit SMD as well for the kind help too.
    I don't think this is the only problem I have with the board. I think It's either a chip, a mosfet or both. I have an idea though but will share once I manage to fix this.
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • mtrento
      robomow rs serie power supply board PCG6005B not charging
      by mtrento
      i'm trying to repair my mowner's power supply unit which doesn't provide the 34VDC from the control electronic board. (PCG6005B)
      As i'm newbie in electronic repair ,i 'm seeking for advices.
      i can solder things and have some voltmeter
      here's a picture of the board .
      note : the input power is 34V DC and the output (white connector on the left) output 0V .
      when i turn on power , the status leds light up as normal (this board is measuring if the peripheral wire is cut , and can see when the robot is on it's base , all theses functions seems to work...
      03-26-2025, 04:18 AM
