Asus A8R-MX/DP motherboard change 7 caps
  • Oldschool297
    • Jun 2023
    • 24
    • Sweden
    I have a asus a8r-mx/dp motherboard, can anyone id the open ones? I can't see the text without removing the processor and i can't at the moment. The motherboard is from 2005, support a dual core processor, rare at that time.
  • PeteS in CA
    • Aug 2005
    • 3576
    • USA, Unsure of Planet
    Re: Post help identifying capacitors here
    Those caps look to be from Nippon Chemicon. I am going to guess they are KZG or KZJ series, which are known to die ugly.
    PeteS in CA
    • Oldschool297
      • Jun 2023
      • 24
      • Sweden
      Thanks, 1500, 6,3v 8mm/20mm. I have found an amazon but i don't know if they are false or good.
      • Oldschool297
        • Jun 2023
        • 24
        • Sweden
        Asus a8r-mx/dp motherboard change 7 caps.
        I have tried to solder them out with 350 to 450 heat but it don't work. The tenn isn't much on the pins and it's hard to reach them. It seems like the tip only gets against the legs? The solder tool is not the big right to the motherboard. It is the blue one.
        • Oldschool297
          • Jun 2023
          • 24
          • Sweden
          Re: Asus a8r-mx/dp motherboard change 7 caps.
          Is this something to recommend? https://www.youtube.com/watch?v=BFDwsdEGsDE
          • Oldschool297
            • Jun 2023
            • 24
            • Sweden
            Re: List of Bad Cap Manufacturers
            I took a try and bought these. Did i do wrong? https://www.amazon.com/dp/B08RXW8VJ2...roduct_details
            • Oldschool297
              • Jun 2023
              • 24
              • Sweden
              I got one loose so the legs are left on the motherboard. It seems to be a black plastic plug on the back. It had been easy to insert a new one to the legs on the motherboard. If the + and - gets right. It is KZG 6.3V 1500UF (M)105c.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                No that is completely retarded!
                You need to add some fresh solder to the legs, the more the better really.
                It helps with heat transfer.
                But above all you need to practice soldering on some scrap PCB's if you never did it successfully before or you will destroy this mainboard.
                You also preferably need a decent soldering iron with say 60W of power, and thermal regulated.
                They could be ok, but the KZG have been out of production for at least 15 years.
                I would make a guess that these are from 2009 but the problem with United Chemi-Con's dating system is they only print the last digit of the decade.
                So the "9" can really mean 2009 or 1999 you really can't know... But 2009 is more likely (and 2019 is impossible because they where out of production then).
                Keep in mind it is a good idea to reform old capacitors, see this thread for info: https://www.badcaps.net/forum/showthread.php?t=50530
                • Oldschool297
                  • Jun 2023
                  • 24
                  • Sweden
                  Re: Asus A8R-MX/DP motherboard change 7 caps
                  It seems hard i tried with 400 and it goes up to 450. But it dosen't loose. I tried to add more solder to the legs but then it only gets loose and the original solder to the legs are left.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Take a look at this thread: https://www.badcaps.net/forum/showthread.php?t=485
                    The best way to remove the solder is with a needle as willawake shows further down in that thread:
                    • Oldschool297
                      • Jun 2023
                      • 24
                      • Sweden
                      I tried to add more solder to the legs and heat up but it don't move, it must be hard to remove caps.
                      • Oldschool297
                        • Jun 2023
                        • 24
                        • Sweden
                        I solved it by taking a bigger solder tool 75W. Thanks for the help. I bougth these https://www.amazon.com/dp/B08RXW8VJ2...roduct_details i took a chance
                        • Oldschool297
                          • Jun 2023
                          • 24
                          • Sweden
                          I got it to work with KZG 6.3v 1500uf. The system seems stabile to. It was the first time changing. Of course i placed the caps wrong the first time by looking at a photo online where the white strip on the caps should be on the white hemisphere on the motherboard. But i did not start it, by looking at the others i realized they was wrong so i had to solder them away one more time. Asus has the negative on the plus side. Reversed. Thanks for all help.
