RTX2060/NCP81611 Issue
  • manuforti1314
    • Sep 2021
    • 44
    Questions on the NCP81611 please, my RTX2060 was working with an odd issue of the not powering on at first boot, always needed a soft reboot then ran fine.
    The card originally had a blown fuse and faulty DRMos, I'd fixed them and the can ran since albeit with the boot issue.
    Issue now is the Vcore has gone AWOL.
    The controller is a NCP81611, I've changed this twice with no change.
    I've been using a schematic for the MSI 2060/2070, this seems very close although my board is a Palit which seems to have a few less components on it.
    I've got 5v VCC, 2v VREF, 3v enable but only 10mv on PGOOD on the NCP81611.
    It there anything else I should check, this NCP81611 is more complex than any others I've worked with so I might be missing something?
  • manuforti1314
    • Sep 2021
    • 44
    Re: RTX2060/NCP81611 Issue - Now Boots
    Card now boots. Embarrassed to say I'd installed a resistor in the wrong place on the card, there is a series of empty pads with the odd resistor here and there. I recall changing the NCP81611 and having to sort out one that had blown off the pads. Put it back on the wrong place.
    Still got the odd booting issue. Need to soft power off at first boot then it starts fine.
    • ongobongo
      • May 2023
      • 62
      were you able to fix your strange booting problem?
      I have the exact same problem with a Gigabyte RTX-2060 i've just fixed.
      I had a shorted capacitor at 5V rail and after fixing that the card worked, but only when doing a reset after powering it up.
      Cheers
      • manuforti1314
        • Sep 2021
        • 44
        The card works fine now. Not totally sure I can claim to have fixed it.
        I took the card apart again and noticed that I had a thermal pad in the wrong place, instead of being on top of the inductors it was over the section of the card with the crystal and the logical and gate for PEXRST. I moved the pad and put the card back together. Works fine, every time.
        I cannot imagine that doing this actually fixed anything however it has.
        The fault had me baffled, I could never really understand why the card never started normally but always started with the quick reset after power on.
        When I was troubleshooting the NCP81611 issue it was not getting the enable signal unless I did the quick reset.
        • ongobongo
          • May 2023
          • 62
          Thanks for the answer.
          I just managed to fix the issue on my card.
          I'm not very experienced when it comes to GPU repair, in fact, this is my very first attempt.
          During fault search I took of the NCP and the PWM controller as well.
          After finding and fixing the main problem - a tiny cap went bad - I put the two chips back. After that the strange behavior appeared.
          Yesterday evening I took some time, re-seated both QFN-chips and touched up all connections to the pads.
          After that, the problem went away and my card is now working as expected :-)
          I highly guess - as you worked on the same area - that the problem has to do with the NCP and/or not perfect connections from the chip to the pads.
          Maybe your fix put pressure on the right spots of the card and fixed a not perfect fitting by accident?
          Anyways, thanks for your feedback and help on this.
          Cheers
          ongobongo
          • abajor
            Alienware Area-51 R2 Boot Loop issue.
            by abajor
            I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
            It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
            To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
            Right now I'm trying to dig through the PDF schematics and Board...
            03-08-2024, 10:08 PM
          • Safio
            Asus Rog Strix g15 g512LI BOOT ISSUE
            by Safio
            Hello
            My asus rog strix g15 g512 keeps repeating the "Republic of Gamers" animation and won't power on. Anyone know what could be wrong with it?
            i tried to install new system on it but it is same issue , does the same thing when i try to boot from usb or externals hard drive, flashed bios still same issue , if its a hardawre issue please share your experience
            thank you
            06-08-2024, 08:43 PM
          • javierwilliam
            Boot loop issue with LCD TV
            by javierwilliam
            I am experiencing boot loop issues with my LCD TV. When the TV briefly displays the logo, such as LG or Philips, and then shuts down only to repeat this cycle, it indicates a boot loop problem. The challenge lies in the inability to install new software under these circumstances.
            Should I consider replacing the mainboard as a solution, or are there alternative approaches to address this issue?
            Thanks in advance!​
            08-29-2024, 04:06 AM
          • lukkihapsi
            Asus Vivobook X515JA Weird Boot Issue
            by lukkihapsi
            Asus Vivobook X515JA Laptop
            Issue :
            Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
            Tried :
            Cleaned inside for dust, applied fresh thermal paste. No Change!
            Removed keyboard, Trackpad, fingerprint sensor. No Change!
            Removed Internal SSD. No Change!
            Updated BIOS to latest version. No Change!
            Removed battery and pressing power button for 1 minute. No Change!
            Weird Part :
            Upon turning laptop ON, screen lights up - stays black,
            I...
            07-07-2025, 12:07 PM
          • Stephen
            iMac 27” 2020 Boot issue
            by Stephen
            Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
            08-16-2024, 09:32 AM
