Biostar P4M80-M4
  • damon_sisk
    • Jun 2006
    Biostar P4M80-M4
    Original capacitors: Chemicon kzg,3300uf, 6.3v, 105C
    I've been watching the capacitors on this board for a while. A few months ago, I replaced two (badly domed) of the five with used ones as a temporary band aid. It helped the computer complete its self test and boot much more reliably.
    The frequency of trouble has slowly increased since. I installed capacitors I ordered from Digikey:
    Replacement capacitors: Panasonic CE FM, 3300uf, 6.3v, 105C
    I'm quite experienced at soldering, however now the board will not show video, boot etc. The capacitors must be wrong. What capacitors should I buy and use? Also, where can I get them?
    I would just throw this junk board out, but I want to get the computer working with its current OS install for about 8 more months or so.
  • c_hegge
    • Sep 2009
    • 5219
    Re: Biostar P4M80-M4
    Panny FM are a slight downgrade from KZG, but I would have thought they would be close enough. These would be a perfect match (Rubycon MBZ Series), but there could be something else wrong with the board.
    • yyonline
      • Jul 2009
      • 692
      KZG are known to fail without showing any signs such as bloating or leaking. It sounds like you only replaced the capacitors showing visible signs of failure. I'd replace the remaining KZG capacitors and see if it helps.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        +1
        the vrm input kzg's in the 775 version of that board i just fixed were open.only reason it still worked was 2 tiny lytics under the hsf.all the kzg's were open or had hatched!
        the system was on a custom cnc of all things.a dozen or so bsod a day was what it took to get them to bring it in!fm's are higher esr than kzg but not enough for it to not work.replace all kzg and check your work.make sure all are in correctly.
        • dragon3x
          by dragon3x
          power on.
          Here are some examples :
          switching supply area).
          than 6.3 V.)
          03-21-2025, 02:46 PM
        • ajdrenter
          Picking caps for Antec SU-380
          by ajdrenter
          In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
          https://www.badcaps.net/forum/showthread.php?t=14159
          It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
          05-13-2023, 10:40 AM
          After all of...
          07-13-2024, 08:14 PM
        • Cama
          Solar Inverter - SMH-II - 2 missing capacitors
          by Cama
          I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
          My model is : EASUN SMH-II 7 KW
          Mother Board : P/N 18947-002401250250
          Maybe the EASUN SMH-II 4.2 KW have the same capacitors
          Thank you...
          09-12-2025, 02:50 AM
        • Ady2017
          Are there any datasheets available for Elna RJG capacitors?
          by Ady2017
          I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
          05-25-2025, 02:19 PM
