iMac 21.5" RAM upgrade, now three beeps
  • survivalbloke
    • Aug 2021
    • 296
    Hey, got a 21.5" imac A1418 14,3. customer supplied ram upgrade but we get the three beeps indicating RAM problem. We then bought ram from OWC which is where we normally get mac ram, but same problem, the three beeps. CMOS battery was 2.88v, so we replaced. I've done many ram upgrades in these, and not sure what's going on. Any insight?
  • reformatt
    • Feb 2020
    • 1412
    Re: iMac 21.5" RAM upgrade, now three beeps
    Disconnect the headphone jack. Seen a shorted cap on this board across a 3.3V supply caused this problem for me.
    • survivalbloke
      • Aug 2021
      • 296
      Thank you - unfortunately, it isn't working.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        1 long-2 short bleeps? Take out the RAM and reinsert the RAM.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • reformatt
          • Feb 2020
          • 1412
          If you are inserting known working RAM then you need to go through all the switched power rails to see if they are present. Some are often shorted like the headphone jack I mentioned earlier. Also check the pins of each RAM socket as well for debris or loose pins etc.
          • tommy97
            iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
            by tommy97
            we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
            Any ideas what might've...
            04-20-2024, 04:48 AM
          • mon2
            iMAC A1418 820-00431-A 8GB upgrade to 16GB
            by mon2
            Hi. Inspired by the following iMAC A1418 upgrade:
            https://www.youtube.com/watch?v=YmX0MVuVKcE
            Performed the upgrade on a working 8GB iMAC. After the upgrade and moving of the single RAMCFG jumper, the logic board is not showing LED3 and no LED4.
            Logic board turns on fine with the power button and the fan does spin.
            Have applied the LCD display but does not make a difference.
            Q1: Is the video card (linked to LED3) requiring the use of the external LCD? Believe that LCD is mandatory for LED4 only but wish to confirm....
            03-15-2021, 03:32 PM
          • ryogadan78
            iMac A1418 - No LED, no power after overvoltage on Ethernet port
            by ryogadan78
            Hi guys, I need your help again.
            I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
            When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
            06-10-2025, 03:49 AM
          • Stephen
            iMac M1 DFU restore issue
            by Stephen
            iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
            this is the message it gives me with the error
            Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
            Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
            03-07-2025, 12:19 PM
          • Stephen
            iMac 27” 2020 Boot issue
            by Stephen
            Customer came in for data recovery, came to find out data is soldered on to this iMac (learn something new everyday) this is a 2020 T2 iMac so I was surprised because the iMac Pro has a T2 chip and it isn’t soldered on. Anyways, the iMac boots to Apple logo and then restarts, before it turns off you hear a quarter fan spin then it repeats itself. I decided to do a DFU revive to restore any hardware firmware issues and it was successful in reviving the device however the issue persists in boot looping. It shows the Apple logo for like 40 seconds then turns off and fan spin rinse repeat. I...
            08-16-2024, 09:32 AM
