ati radion 9100v/d/vo
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    blinking junk during post/garbage in images.
    found 4 licon 470@10 bulging.
    replacement caps cured it.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: ati radion 9100v/d/vo
    added pic
    • gonzo0815
      • Feb 2006
      • 1600
      What caps you have used for replacement? I have some Sapphire Radeon 9600 cards with them. Actually nothing bulged, but i want on this rig a "on time got all buggers recapping". ATM i am considering some Panasonic FM 1200uF or some 2200uF MCZ. I do not have anything smaler atm.
      • arneson
        • Sep 2005
        • 1267
        470 up to 2200 is a radical jump, even 1200 is a two and a half X jump up.
        What's with the blue felt tip marking across the vents, quality assurance?
        Jim
        • Shroomie
          • Apr 2006
          • 356
          Ooh, I'll have to keep an eye out then. My neighbor's 9100 has the same caps.
          You know there's something wrong when you open up a PSU and are glad to find Teapos.
          Why I don't buy cheap cases!
          • gonzo0815
            • Feb 2006
            • 1600
            Well, i know its a huge jump, but from my point of view it should not be that important on those buck controlers. May be i google for an app sheet of the controler chip. If it can handle that low esr i think i should be fine. The FM`s arent that low esr than e.g. Oscon or MCZ. Inrush current should not that dramatically higher than with 470uF cap. May be i leave them, as they are probably not bad atm.
            • Tom41
              • Oct 2005
              • 338
              • England
              I've got a Radeon card with Licon caps. No sign of bulging or leaking yet, but I regularly take the card out and check that nothing has happened to the caps.
              Also, why do they mark the top of caps with a pen on video cards?
              You know there's something wrong when you open your PC and it has vented Rubycons...
              • gonzo0815
                • Feb 2006
                • 1600
                probably QC to assure none of their crappy caps is bulged before the cards are shiped. IMHO capsare bought in large quantities and are then stored for several yearsuntil they used them up. Thus even frommthe good ones there could be a bad in a few thousends.
                • Big Pope
                  Approved Vendor
                  • Dec 2005
                  • 426
                  Oh, my last 4 pcs of Samxon GC 470uF 16v D10mm have sent to trodas. I am using these for recappment with Radeon 8500/9100 series in the past. Now, I will not get stock again, because i am using GD 680uF 16v D10mm for replacement.
                  My SAMXON Capacitors Database HERE!!
                  X-CON is a new brand for SAMXON's Polymer Capacitors.
                  • reformatt
                    by reformatt
                    07-31-2025, 08:37 PM
                  • the_rem
                    Unknown transformer : how to find a good replacement part ?
                    by the_rem
                    Hello guys,
                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                    04-23-2025, 01:48 AM
                  • ezenia
                    PS4 controller left stick potentiometer replacement issue
                    by ezenia
                    Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
                    So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
                    I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
                    09-30-2023, 02:19 PM
                  • boosti45
                    Macbook pro logic board replacement parts quesion
                    by boosti45
                    i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                    08-21-2024, 05:23 AM
                  • r2digital
                    klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                    by r2digital
                    I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                    04-18-2024, 03:50 PM
