Resurrection weekend...
  • skiddz
    • Nov 2005
    • 22
    Put new floors in my house and when I was putting my office back together, I found a few old motherboards I'd left for dead.. All Abits.. A couple BF6s and a well seasoned BX6-2.. For giggles, I thought I'd try and resurrect them with my trusty soldering iron and some new Nichicon caps... Called my Mouser rep, gave him some part numbers from page 572 of the latest catalog and a couple days later, I've got a box of caps.
    1st BF6 took a couple hours to do, but it posted on the 1st try and I was able to stuff in an old Celeron 566 on an MSI Slotket adapter and OC it to 850MHz.. 24 hours with Prime95 showed no problems at all.
    2nd BF6 took less than an hour (I had my methods worked out after 22 caps on the 1st one) and resulted in another saved board. This one got a PIII/1000 on a slotket adapter and it's chugging along on Prime 95 at 1.33GHz. No problems.
    The BX6-2 is still in surgery, but I'm hopeful it'll be back up and working in an hour or so. I just had to take a moment to offer my thanks to badcaps.com for the info I needed to make this happen. (and to get away from the magnifying glass - my eyes are tired!)
  • Chris1992
    • Apr 2005
    • 561
    Re: Resurrection weekend...
    Nice to hear success stories. Pics would also be nice.
    The great capacitor showdown!
    • skiddz
      • Nov 2005
      • 22
      Alas, the BX6-2 seems to be dead.. Replaced the usual suspects and no joy. No beeps, no nothing.. Individual components are all ok as they work in the BF6s.. Don't see any damage to the board and it's failure wasn't dramatic. Just wouldn't POST one day - same as after surgery.. No beeps or anything.
      Should have taken pics while the boards were on the bech, but I've got 'em all built up - one's in my rack in my office and the other is in my daughter's room..
      I'm kinda bummed about the BX6 tho. I've had that board running since the C300a@450 days and this is it's 3rd or 4th iteration with a C566@850 (Same as the BP6 I saved)
      Might have another one to work on.. The Dell Dimension that's my house's Win2k server started "singing" last night and locked up a couple times today.. (Thankfully my backup domain controller is still solid..) If/When I do that one, I'll take some pics..
      • AK0R
        • Mar 2005
        • 204
        Check for a shorted or open VRM. Any one of them bad could prevent the board from POSTing.
        • skiddz
          • Nov 2005
          • 22
          Pardon my ignorance, but I just walked in from another 13 hour day and my brain is fried... What's a VRM and what do they look like? Voltage regulator? I know what those are... That'd be nice if that's what it is..
          Thx!
          • Calchaqui
            • Oct 2005
            • 112
            I think AK0R is meaning mosfets and the VRM chip which switching them .
            I've seen mosfets toasted and good VRM, but if VRM is toasted or shorted, than, mobo is dead.
            I LOVE WWW.BADCAPS.NET
            • Rainbow
              • Aug 2005
              • 1373
              The VRM chips can be replaced too - but you have to find exact same type. Boards with bad VRM chips wait until I get another board which can't be repaired (fried chipset) but the VRM chip is still good. The problem is that there are many different types of VRM chips - but I've already repaired some boards.
              • skiddz
                • Nov 2005
                • 22
                OK, I guess the VRM isn't what I thought it was.. Can someone post or send me a pic with that I should be looking for (and how to check for shorts/opens??)
                This has become sort of a personal challenge now..
                • Rainbow
                  • Aug 2005
                  • 1373
                  VRM is composed of:
                  1. VRM controller - a small chip with 16 or more pins
                  1.5 MOFSET drivers - small 8-pin chips if not integrated into VRM controller
                  2. MOSFETs - the black things with two pins and back soldered to the board
                  3. coils
                  4. capacitors
                  If the caps go bad, the MOSFETs can short - and that can damage the MOSFET drivers or VRM controller.
                  • Calchaqui
                    • Oct 2005
                    • 112
                    Perfect Explanation Rainbow . Yes, but how to desolder a VRM chip, it is solder on the surface of the PCB, I've tried with a "pencil" 15W Soldering Iron, 3 hours , and nothing , i couldnt. Also even different models of VRM has the same Pin out, and they works.
                    • skiddz
                      • Nov 2005
                      • 22
                      OK, armed with that bit of knowledge, again, how does one check VRMs or Mosfets for shorts/opens??
                      • Calchaqui
                        • Oct 2005
                        • 112
                        Here is the link: https://www.badcaps.net/forum/showth...&highlight=VRM
                        I dont understand quite well because of my enligsh and specific vocabulary. I'd love a FAQ with a mini-DICTONARY . I mean, what means VRM IC, is that the buck controller a.k.a VRM chip . Generally, what means IC ?
                        Sorry for the questions.
                        • Chris1992
                          • Apr 2005
                          • 561
                          IC is integrated circuit, which is a chip. Yo se bastante espanol de hablarle en espanol, si eso ayude. (no puedo hacer acentos en este teclado)
                          • Calchaqui
                            • Oct 2005
                            • 112
                            Perfect Chris1992, I think the right thing is that i must learn english well :P .
                            By the way, almost all short/dead mosfets I've seen also they took away the VRM IC.., is that a rule?. Change mosfets is hard but possiblechange IC a lottaaa harder
                            • Rainbow
                              • Aug 2005
                              • 1373
                              If there's no resistor between the MOSFET driver and MOSFET's base, then the driver (which is sometimes integrated in the VRM controller) is likely to be damaged by shorted MOSFET. The reverse can also happen - bad VRM controller can open both upper and lower MOSFET, effectively shorting 5V (or 12V) to ground through them - but haven't seen that yet.
                              • Calchaqui
                                • Oct 2005
                                • 112
                                Rainbow, thank you for answer. How could I know if the Driver mosfets is integrated in the VRM chip, I mean, in example for the IC HIP6019BCB . I read the datasheet, and doesnt talk about driver mosfets, but i dont see another chip next to mosfets and IC in the mobo .
                                datasheet: (almost the same)
                                • Calchaqui
                                  • Oct 2005
                                  • 112
                                  Sorry, again, given this pics, how is possible to know if the mobo has driver mosfets chip (not integrated in the IC), and if there is some resistor btw mosfets and IC
                                  http://www.soyogroup.com/images/prod...0x600/6vca.jpg
                                  http://www.xbitlabs.com/images/mainb...3v4x/p3v4x.jpg
                                  http://www.soyogroup.com/images/prod...00/7vba133.jpg
                                  Thanks a lotta in advance
                                  • Rainbow
                                    • Aug 2005
                                    • 1373
                                    In the datasheet, see the chip pinout - if it has UGATE and LGATE outputs (or something like that), that means that it can directly drive the MOSFETs.
                                    Also see "typical application" in datasheet - that shows if the MOSFETs are connected directly to the chip or to the driver chips (see e.g. HIP6302 datasheet, it's used with HIP6601 drivers). P2/P3 board typically use all-in-one chips but many Socket A boards use external drivers.
                                    • skiddz
                                      • Nov 2005
                                      • 22
                                      OK, did some more poking and prodding with my meter and found what I believe to be a bad VRM. Unfortunately I can't make out any nomenclature on the thing so have no clue what part I might be able to replace it with... Oh well, 2/3 is still a 67% success rate.. The "saved" machines are rock-solid with over 72 hours of Prime 95 time on each of them.
                                      $35 in caps, a few hours of my time and a couple Newcastle Brown Ales made it all worthwhile.
                                      • AK0R
                                        • Mar 2005
                                        • 204
                                        What is the component number? Chances are good that someone on this board can tell you what should go there.
                                        • SolomonMan
                                          A Couple Quick Battery Questions...
                                          by SolomonMan
                                          All,
                                          I have 4 laptops all the same HP Elitebook model. These are now close to 8-10 years old now but they all were high end software development machines (ie 16GB ram (32 max) and all now have been upgraded to 1TB SSD). They are used throughout my house (family).
                                          I recently bought a Software Defined Radio setup (SDR) and I will use it with one of the laptops but the batteries appear to be all dead.
                                          The replacements seem reasonable at the sub $30 range (some as low as $20 shipped).
                                          So I am thinking of replacing them all.
                                          So the question...
                                          04-16-2023, 07:41 AM
                                          Electronic Goldmine has a weekend sale Wireless Charging Awesome Earbuds with Microphone CTS-MB3
                                          by sam_sam_sam
                                          https://theelectronicgoldmine.com/products/g26731
                                          There regular price is $49.99 they are worth that but I would not buy any unless they are at $10.00
                                          When they had them on sale the first time I just add to an order that I was getting I have had wired earbuds before and was not impressed with the way they fit in your ear but these fit in your ears very well and easily put into your ear
                                          I bought a pair of them when they had them on sale for $10.00...
                                          06-22-2024, 07:38 AM
                                        • JohnML1975
                                          LG 49UK7550PTA - after couple of hours screen starts to blink
                                          by JohnML1975
                                          Hello Forum team
                                          Have this TV; searched for the model and could not anything so thought I would share in here
                                          Had an issue, some years ago, and looks like some placed sticky tape over some of the lines on the FFC cables between the T con and the mainboard
                                          Anyway, the owner, who gave me the TV, says it starts to blink after a few hours
                                          So I removed the covers, and could not see anything visibly
                                          Removed the power supply and thought some of the solder joints, on the hot side, were not the best. I thought some looked like they were cracked.
                                          07-25-2025, 10:48 PM
                                        • Nikolai Danylchyk
                                          Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                                          by Nikolai Danylchyk
                                          Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                                          Thanks in advance!...
                                          05-08-2025, 06:18 AM
                                        • CZFan
                                          XBox One PSU Mosfets
                                          by CZFan
                                          Hi All,
                                          My original PSU for XBox popped a little while ago, openened it up, fuse gone, mosfets shorted, etc. I ordered a cheap one (Not Microsoft Original). This one also popped the weekend, opened up, and needed a couple of Caps to be replaced, as the saying goes, "it is always a cap..."
                                          When I opened the replacement I bought, it has about 25% of the number of componenets compared to the Microsoft original, which is expected I suppose for the 1/4er of the price, but the bloddy thing does not even have a fuse in!!!
                                          Unfortunately wife has cleaned...
                                          01-18-2024, 07:10 AM
