FIC AU31 No longer posting
  • ProdigyS10
    • Jan 2023
    I have an FIC AU31 i'm hoping to resurect to be a win98SE retro pc. has a athlon xp 3200+ cpu.
    it had bad capacitors on it causing reboots (or so i thought), replaced the capacitors 4 of them had opened up. we didn't do a very clean job. but it worked and the system seemed stable. during this testing though i had a pci card that was up slightly and without thinking i pushed it down and
    the system hung. i tried rebooting and wouldn't get any post beeps after that. ive since upgraded my solidering/desolidering station and cleanly mounted the capacitors nicely hoping that it was just one of the caps got loose.
    still no luck so i've started trying to diagnose it deeper
    removed ram and cpu and power on the board it turns on and fans spin but zero post beeps. i can push and hold the power button and it will still respond and shut off that way so i don't think its totally dead yet.
    using https://cdn.badcaps-static.com/pdfs/...ef6a0f5689.pdf
    on the socket A cpu i looked up pins wanting to see if the cpu was getting power since it didn't seem warm ever after trying to post.
    took a reading from B2 (vss) got like .01v and then D2 (vcc) but got 0v.
    any thoughts on where to look next?
  • ProdigyS10
    • Jan 2023
    Re: FIC AU31 No longer posting
    https://theretroweb.com/motherboards/s/fic-au31-l is the board in question if its any help
    • ChaosLegionnaire
      HC Overclocker
      • Jul 2012
      • 3266
      • Singapore
      Originally posted by ProdigyS10
      i had a pci card that was up slightly and without thinking i pushed it down and the system hung.
      i think doing ^this^ might have resulted in esd that fried the southbridge.
      do u have another spare known working cpu and ram to test? to rule out faulty cpu and ram, or another spare socket 462 motherboard to test the cpu and ram? to prove the fault is indeed with the motherboard. i know athlon xp cpus of that era are "fragile and brittle" and are prone to failure: case #1. if u run it without the heatsink, it would often overheat and fry the chip. not sure if it lacks proper esd protection as well, if u tried hotplugging things in the expansion and/or ram slots, it may fry the cpu...
      umm... u take cpu vcore readings from the body pad of the cpu vrm mosfets, the cpu vrm coils or the positive leg of the caps on the cpu vrm output. NOT on the cpu socket pins! they are fragile and so many of them packed closely together. what if u accidentally short the adjacent pins? that would most likely fry/short-circuit the cpu!
      • ProdigyS10
        • Jan 2023
        hoping not to have fried the southbridge but its definitely possible.
        lots of spare ram but only the one cpu. but in theory it should give the no ram and no cpu beeps if its getting to that point.
        pulling the voltage from the socket seems to be fairly common on a lot of diagnostic youtube channels. necroware frequently will place a small wire in to the right pin point to confirm a voltage or frequency for the cpu just like i did. infact thats where i got the idea from.
        i do have one of those pci/isa post code cards coming that may shed some light on things once it arrives as well.
          master hoarder
          • May 2008
          • 12175
          Can't test board for POST codes without CPU. Without RAM - yes.
          Install CPU and CPU heatsink (with proper thermal compound) and heatsink fan attached to motherboard (some socket A motherboards have a protection feature where they won't POST if they don't see a tachometer readout for the CPU fan.) No need to install memory. All other peripherals and hardware removed, including any PCI cards. See if board gives memory beep code. If not, unplug PSU from the wall and remove CMOS battery for a minute. Re-install CMOS battery and re-test again. If you do get a memory error / beep code, install memory back (1 stick at a time.)
          Too risky, IMO - very easy to slip with the probe/wire and short something out.
          Doing it from a low-side MOSFET's Drain pin is easier and gives acceptable accuracy usually. Doing it at the output of the filter toroids is better (may get slightly more accurate voltage.)
          Good.
          Those do come in handy every once in a while with older boards, at least to see if a board is doing something or not.
          i know athlon xp cpus of that era are "fragile and brittle" and are prone to failure: case #1. if u run it without the heatsink, it would always overheat and fry the chip.
          Fixed that for you.
          And yes, socket A CPUs are also fragile in the literal meaning too - very easy to crack the core or chip a corner if not careful during heatsink installation.
          Older CPUs are actually more resilient to ESD, in or out of the board.
          Also, on these older PCs like socket A, socket 370, and socket 478, pretty much all of the pins on the CPU go through the Northbridge. So hot-plugging a PCI card can't really fry the CPU. PCI signals on old boards go through the Southbridge, which then connects with the Northbridge, which communicates with the CPU. So more likely the Southbridge could have taken a hit... or the PCI card in question (hence the suggestion to test with all PCI cards and other non-essential hardware removed.)
          • ChaosLegionnaire
            HC Overclocker
            • Jul 2012
            • 3266
            • Singapore
            huh? this means he measured by putting the wire in with no cpu in the socket. this is meaningless and doesnt do anything because the cpu needs to be in the socket to send its vid signal to the vrm controller ic to tell it what voltage the cpu requires to start. different cpus are programmed with different vid values at the factory. without a cpu in the socket, the vrm controller doesnt know what voltage to send to the cpu so it just turns itself off as a safety feature by default so no wonder u measured 0V at the vcc pins... therefore, this doesnt tell us anything useful about why the board wont post at all...
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Adding to what ChaosLegionnaire said: the quoted procedure only works on older CPU's where you set the voltage via jumpers on the mainboard.
              Then it it a good test to make sure you don't fry a 3.3v CPU with 5v for example.
              For more modern boards that set the voltage automatically by detecting the CPU this is not useful...
              • tuankietkiet
                Dead Dell Inspiron 14r N4010 (Used to beeps 3 times but no longer do)
                by tuankietkiet
                When plugged in (no battery installed), the battery light on the motherboard lights up and then turn off. When powering on, the same and light and the power button also light up in a white color but no output on the display. It stayed like that for a few seconds before shutting down. I also seem to ruined a connector that connects to the WLAN, 2 USB and audio board, the same board also have a melted 2062A IC. I will post pictures in the reply section
                05-11-2024, 04:40 AM
              • retrorepair2
                HP Z820 Workstation 4 beeps (sometimes)
                by retrorepair2
                I've got an issue with my Z820 that I'm having trouble working out the root cause of.
                More often than not it'll turn onand fans will blast for a moment before stopping and I'll get 4 beeps that will repeat forever (at least the power light will keep flashing).
                What I can't understand is sometimes it'll just work and I can use it all day but other times it'll boot then reboot then reboot and 4 beeps for the rest of the day. Sometimes it'll work fine from cold for hours, sometimes it'll do the 4 beeps from cold.
                Another oddity is the fans. Before the 4 beeps...
                09-24-2025, 08:05 AM
              • ktmmotocross
                Old hp compaq nc6320 weird beeps after low bios battery
                by ktmmotocross
                Hello.
                Have this old hp compaq nc6320 that came with one long and one short beep + backlight on. bios battery have only 0.5V. I remove it, but now it start beep some weird way. I think it is bios /one long + two short beeps+ baklight on/, but when i flash new bios from hp, no beeps and no backlight.
                i attach record of beeps...
                04-27-2025, 12:48 AM
              • jake-b
                dell e6540 boots to black screen (no dell logo)
                by jake-b
                good morning all,
                i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                01-08-2024, 10:29 AM
