Se7500CW2 worth it?
    Se7500CW2 worth it?
    got Intel se7500CW2 all nichion caps are blown.
    6.3 2200
    Anyone know abotu this board, worth it to re-cap? `
    Re: Se7500CW2 worth it?
    6.3 2200
    Let me guess. It is HM(M) markings on these nichion caps?
    Topcat sells Rubycon's here 2200uF 6.3v for 87 cent each if you buy 10. Samxon 2200uF 6.3v are 59 cents each if you buy 10.
    Or you can buy from digikey.com and get Panasonic FM
    http://search.digikey.com/scripts/Dk...name=P12344-ND
    for 10, they are 46 cents each.
    Any of these will work fine.
    --- begin sig file ---
    --- end sig file ---
      wow your good!
      and your right, they all have HM(M) markings...
      For 10-15 bucks is worth it i suppose as long as i can justify power consuption with a use.
      What about the rest of caps, physically, they look fine, but...you know....
      Rubycon YXG 6.3v1000
      Sanyo OSCON 820/4 (purple caps with no vents on top, that 4v820?)
      Sanyo OSCON 270/16
      Sanyo 25v100uf
      PS21u 4v560 (silver color caps with blue color marking on top
      Also has a burnt smd from the usb header, not to worried about that becasue my case wont even have front panel usb.
        My Compaq SFF has bad HM(M). That is how I knew.
        Sanyo OSCON 270/16
        Sanyo 25v100uf
        Folks here like Rubycon and Sanyo. Don't know about the PS21u though.
        And you are right about caps being bad without physical signs of distress. They could have high ESR (ohms) or out of tolerance capacitance. For example, a 1000uF 16V cap could measure 240uF.
          Sounds like Chemi-con PS series. Solid polymer and very reliable.
            Thank you all for your insights, im going to just replace the nichicon craps and go from there.. hopefully i have a hand me down working server to goof around with after all is done.
