Modified RTX3000 series BIOS files with memory channels disabled
  • benwaterson
    • Aug 2008
    • 202
    Hi All
    I was looking for ways to disable memory channels in BIOS for a GTX 980 (found nothing) - however I did find a load for RTX3000 series cards - file name describes which memory channel is disabled and for which card - maybe of use to someone with a card that has a bad memory controller (and ram chip is good) to get the card running again with slightly less RAM.
    They look to be from Gigabyte cards originally.
  • floodster1
    • Mar 2018
    • 26
    • canada
    Re: Modified RTX3000 series BIOS files with memory channels disabled
    I've been looking for the same software for a gtx 1080 ti
    With one bad Chanel.
    Sure there must be some way to disable a chip by moding the bios/ firmware.
    Anyone when to add to the topic?
    • yearlingchuy
      • Oct 2023
      • sedgwick
      looking for the same in a 3080ti with a bad ic . it turns out its the E1 chip location but may have bad connection under the core. im not tryint to reflow it with my skill. dont mind a cheap 3080ti with less memory. it was cheap
      • benwaterson
        • Aug 2008
        • 202
        3080ti is in those BIOS files
        • haoran wang
          • May 2024
          • 12
          • China
          I was looking for ways to disable memory channels in BIOS for a GTX 980 => same with you , hope i can learned somthing from this post.
          • haoran wang
            • May 2024
            • 12
            • China
            Old NVIDIA artifacts | GpuZelenograd
            please look at this link for detial.
            • zhangyang
              • Oct 2024
              • China
              Thank you, I really need this.
              • Burnedoutplacebo
                • Jan 2023
                • 19
                Anyone know if these 3060 bios files are for the 8 or 12 gb versions of these cards?
                • Like A dragon
                  • Jan 2025
                  • Venezuela
                  Work on 3080 Lhr versión?
                  • Burnedoutplacebo
                    • Jan 2023
                    • 19
                    Curios where these came from. Looking for one for an rtx 2070 and hoping modified files for the 20 series cards are also present wherever these were found.
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3608
                      • slovakia
                      not for 2gen. only for 3gen. its preproduction bios not for cards for sale
                      • Burnedoutplacebo
                        • Jan 2023
                        • 19
                        thanks for the info.
                        • posalopus
                          • Dec 2020
                          • Israel
                          great resource, got my 3090 to work which had broken pads on channel B.
                          Is there is a similar trick for 1080/1080ti to disable memory channels?
                          • flusher
                            • Oct 2015
                            • 46
                            • Ukraine
                            Originally posted by benwaterson
                            Hi All
                            if these are from gigabyte originally how can we adapt and write these into other brands like PALIT which is also LHR?
                            • Sofian75
                              • Aug 2023
                              • 85
                              • France
                              Is there a rom available for the 3080 LHR?
                              • Terzaghi
                                • Jul 2025
                                • UAE
                                Thanks everyone.My laptop 3070 get wrong code 43,so can there bios be used in laptop graph card to block memory channel?
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3608
                                  • slovakia
                                  what about first run mats to check what channel is bad
                                  • Terzaghi
                                    • Jul 2025
                                    • UAE
                                    I checked it by mats.The picture is as follow.Click image for larger version
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3608
                                      • slovakia
                                      i missed u have laptop. there is no edited bios for laptop. but now u have location of bad memory is so u can replace it to see if it help
                                      • Terzaghi
                                        • Jul 2025
                                        • UAE
                                        Laptop may be different with unique graph card .Do you have any tutorial on using this file to block the channel ?I appreciate if you could recommend me that. Thank you very much .
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                          Lenovo ThinkPad T16 + Extra 8GB memory Notebook Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad T16 + Extra 8GB memory Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T16 + Extra 8GB memory boardview and T16 + Extra 8GB memory schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:21 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
