Bought this hub a while back and used it as a secondary device because speed wasn't important. It died one day by disconnecting nodes and then the lights on the front panel got dimmer. I said "WTH' and immediately took the cover off. On the low-voltage input side beyond the diodes, choke, and axial fuse is one damn domed Wendell 470uF 25V! It is traced to one of the legs of the mosfet close by. I contacted the manufacturer about the "quality" of components they used (all Wendell) and they replied they were sorry there was nothing they could do since it was beyond its useful life. If they didn't put shit in it, it would have a full "useful" life. Engineered obselesence by way of Taiwan and especially China. I'm having flashbacks of Wendell from the Soyo AT boards I had repaired. What if we took the people who decided to use these crappy caps and put bad components in them? Then they would see what end of useful life really meant. Didn't Gates come up with this life cycle crap in order to indoctinate more people in to the Micro$ mantra? Upgrade! Upgrade! Upgrade!
Sohoware NDH305 hub
Re: Sohoware NDH305 hub
i agree with you on the cheaping out of manufacturers especially on the small hubs. what like 4 or so caps? would cost what. anyway it is easy to recap hubs. i had some intel inbusiness hubs, good caps on some not good on others. anyway the psu with nice rubycon caps crapped out on all units one by one. design fault? i dont know. i got some still running in a few very small offices with new psu and new heatsink replacing hsf on one chip. damn fan breaks maybe before the psu. anyway nice for sharing dsl and by no means is 10/100 obsolete trash candidate at the moment. a few bucks and it is again useful. the 3com officeconnect 8 ports on the other hand with 4 new good caps they are fine for more years, psu is still good after years.Last edited by willawake; 10-21-2005, 03:14 PM. -
LOLASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
by eccerr0rYeah it's free speed, but do people generally still overclock their computers risking instability, using more power/cooling, etc. or have people simply accepted stock speeds or perhaps it's pretty much impossible to overclock in general because CPUs are already at its limits, or perhaps it's not possible without surgery, ridiculous cooling, or signed firmware hacks nowadays?
Wondering if I should run my 2.67GHz C2Q at 3 or 3.2GHz and risk instability or corruption during the summer months as it's nice and cool now during the winter...-
by eccerr0rI do have a website but it's not for general use. Definitely not doing any e-commerce, and at most it's just general computer information if it has any value at all.
However I noticed that people are sending ping requests to my computer, constantly. In fact I get around 8000 individual ICMP echo requests a day though each IP sending them send multiple packets.
I set my computer to stop replying to them to see if it would stop. Nope.
What value is there is to sending these if I don't respond to them? Anyone have similar data?
Just curious of what...-
Hi everyone.
Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
- Loading...
