Router asus bios need dsl-n10p rev:a
  • ghoshiry
    • 90
    • iran
    I need bios dump for this router
    asus model dsl-n10p
    hw:ver a
    f/w: Ver v2.1.19bh
    • 31288
    Re: Router asus bios need dsl-n10p rev:a
    i cant find that part number, is it one of these?
    https://openwrt.org/toh/asus/rt-n10p
    • ghoshiry
      • 90
      • iran
      this not working for me
      flash is 2mb
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • pirati
        by pirati
        10-27-2025, 04:20 PM
      • DynaxSC
        by DynaxSC
        06-14-2024, 03:49 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
