Homemade 2.4GHz Bi-Quad Wi-Fi Antennas
  • Shock2cure
    Test Subject
    • Jul 2018
    • 140
    Homemade antenna's I've made on the cheap. Why buy?
    Various designs based on 2.4GHz Bi-Quad designs. Incredibly powerful design using basic copper wire culled from common AC house wiring.
    Folding Colander design
    This thing has been in the kitchen since I was a kid, and since I never used it for it's original purpose. (boiling veggies,etc in a pot) I decided to try to make some sort of antenna with it. The shape was interesting enough, and 1st thought I could make a parabola type with it. After measuring and calculating the diameter to center angles, I found it would have made a very crappy parabola reflector, BUT, the reflector area was good enough to use it as a normal wi-fi antenna.
    The 2 most important parts of making this antenna is the wave length and exact mounted distance between the antenna and back reflector.
    Making the main driven element for 2.4GHz is simple, in the States, 2.4GHZ is spread through 12 channels, so ya want to get as close to the middle of the band as possible, so shooting for ch6 is the goal.
    Ends up the main element will be made with 1/4 wave lengths of 31.25mm lengths.
    I took an old hotel key card, measured & cut it to size,measure my wire then took needle nose pliers butted up and bend at right angles, ya could also use a cut straw to measure.
    you'll end up making a bow-tie type consisting of 2 squares, where the center will have a final right-angle bend to mount to reflector. the entire element MUST be exactly mounted 15mm from reflector. A low-loss coax cable (50Ω) with an SMA connector is attached, with the ground being soldered to the reflector/main driven element base, the center conductor will be soldered to the lower middle bend of the element
    CD case design
    CD spindle cases work great, gonna have to cut out a circle of metal for the back reflector, put the lid back on it to weatherize the element.
    Parabolic Dual Bi-Quad design
    For the reflector on this one, I cut it out from an old TV back cover, to achieve the proper curve, I rolled it using a pin-roller, laying the metal on something like a cushion, I included a PDF with the proper bend angle
    (PS: where the square says 100mmx100mm, cut in 1/2 100mmX50mm)
    Find the center after cutting and mark it.
    The driven element is a bi-quad design X 2, bending the same way as a single, but also you're going to have a couple 62.5mm lengths in it (31.25mm x 2)theres 2 points where the wire will cross each other, it's crucial to insulate them to prevent shorting. Use a piece of heat shrink or save a couple bits of the stripped insulation.
    I used an old broken GPS suction-cup mount and fashioned a holder from 2 pieces of coat hanger.
    the double bi-quad is a powerful one, roughly 13-14 dB gain w/ about a 1/2 mile range.
    Best external network card IMO is the ALFA USB, 2000Mw (18-28$ flEbay)
    SMA pigtails from China (5 for $2.48) (flEbay)
    "Our technologies have surpassed our humanity" ~Einstein
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Homemade 2.4GHz Bi-Quad Wi-Fi Antennas
    You are a genius. Nice post and very interesting information. Thanks.
    • Shock2cure
      Test Subject
      • Jul 2018
      • 140
      according to my old man, I'm a moron and a failure in life...LMFAO
      fak 'em
      thanks Andrew
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        You proved him wrong, Bro. I'm sure he couldn't design this...
        • junktv
          • Nov 2010
          • 3065
          Works great with old satellite dish also.
          For adapters etekcity from ebay was another good one cheaper than alfa. Although ubiquiti bullet with a dish or yagi is tits.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            I made one of these in college for my electromagnetics class. I still have it somewhere, assuming the steel ground plate didn't rust too horribly.
            Better than one of my classmates who used an old CD-R spindle and some aluminum foil for his reflector... he had the fabrication skills of a teddy bear.
            sigpic
            (Insert witty quote here)
            • desert-rat
              • Mar 2014
              • 4103
              I was thinking of mounting a usb wifi adpt. in the center of a sat dish antenna just to see how well it would do .
                • 31196
                it wont, it needs to be on the end of the feed arm and you need to point the dish taking into account the angle the signal is deflecting onto the arm.
                infact it will work better if you keep the lnb casing to use it's feedhorn - it's matched to the distance and angle from the reflector.
                • haanuman
                  • Jul 2018
                  • 12
                  • India
                  fak 'em
                  thanks Andrew
                  He's just jealous and proud at the same time :P Good job OP.
                  • flysky
                    Gigabyte H610M S2H V2 help to identify the element.
                    by flysky
                    There is a motherboard Gigabyte H610M S2H V2 (DDR5), I can't find boardview
                    Help to identify the element, marking on the element - C31PH. It stands next to the USB 3.0 and it looks like it is ESD Protect chip. We need a datasheet to this element. Maybe someone has already identified such an element. Help please.​
                    01-23-2025, 07:21 PM
                  • EasyGoing1
                    The best way to drive a heating element?
                    by EasyGoing1
                    I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                    What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                    This is the general setup that I have now.
                    This is what the...
                    01-25-2023, 11:29 AM
                    Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                    by sam_sam_sam
                    I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                    I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                    12-16-2023, 08:39 PM
                  • x_orange90_x
                    Backlight Reflector Modification
                    by x_orange90_x
                    I am writing this because I came looking for the same information but couldn't find anything. There are certain model tvs that will have 2 or more different backlight strip configurations and there is often no way to tell exactly what you have without disassembling the panel. Twice now I have run into this issue and ended up ordering the wrong sets BOTH times. The previous TV I reordered the correct ones and went on my way. The second one I had no patience for returns or reorders, let alone peeling the brand new strips back out and risk damaging them.
                    The number of LEDs per pair is...
                    03-12-2024, 08:32 AM
                  • wwbielsko
                    Macbook A1707 touchpad smd element identification
                    by wwbielsko
                    one sms element is missing at touchpad pcb in Macbook A1707
                    Could anyone identify it ? Smd element is pointed on pictures
                    thanks...
                    01-09-2025, 01:10 PM
