Unable to access NETGEAR WGR614v7 browser user interface after resetting
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Unable to access NETGEAR WGR614v7 browser user interface after resetting
    Try replacing the caps.
    They are obviously bad.
    • Captain Bill grace digger
      • Jul 2015
      • 70
      • India
      What makes you see that the caps are bad.
      • diif
        • Feb 2014
        • 6978
        • England
        C104 looks domed.
          • Jul 2015
          • 70
          • India
          Originally posted by diif
          C104 looks domed.
          What do you mean by this I cannot find it written on any of the capacitors and none of the image numbers are C104.
            • 30965
            c104 is at the front right side - same side as the power inlet.
            it's printed on the board.
            the cap is dark green with gold print.
              • Jul 2015
              • 70
              • India
              #26
              "Thank You so much" I now see it clearly.
              But what is it that shows that this capacitor is spoilt.
                • 30965
                the top should be perfectly flat.
                if it's sticking up then the liquid inside has boiled.
                also, if you see yellow or brown on the top then it has leaked.
                also it's made by CapXon.
                the replacement must be low impedance type btw.
                  • Jul 2015
                  • 70
                  • India
                  #28
                  WOW! I took a closer look at the PCB again and saw the green cap's top is really swelled and it also has a brown dot on the top.
                  But what is wrong if the capacitors are from CapXon.
                    • Jul 2015
                    • 70
                    • India
                    #29
                    Which type of capacitor should I exactly replace it with.
                    It says it is a 6.3v, 470uf capacitor. Is there anything else I should look for.
                      • 30965
                      capxon fail very quickly,
                      what is the diameter of that cap?
                      the replacement must be the same size.
                      i would use panasonic FR series, but maybe you cant get those.
                        • Jul 2015
                        • 70
                        • India
                        #31
                        I guess the capacitor in the link below should be just the right fit. It looks exactly the same diameter when I measured the cap on the PCB with a measure tape, It also is 470uf and 6.3v and it is from Nichicon PLEASE just have a look.
                        http://www.tanotis.com/products/nich...nt=40408355984
                          • 30965
                          no, VZ is not suitable AFAIK.
                          btw, that website is a joke, it must be run by a monkey.
                          every time you click on anything, it reports it to FaceBook!!
                          it does all kinds of stuff in the background!
                          you never did say how wide the old cap is.
                          if it's 8mm then maybe this:
                          https://www.tanotis.com/products/pan...al-leaded-8-mm
                          i dont trust the seller not to be selling fakes though.
                            • Jul 2015
                            • 70
                            • India
                            #33
                            The old cap is 6mm wide and 11mm high.
                              • 30965
                              then you need EEUFR0J471
                              or something from nichicon/rubycon/ncc
                              but i dont have the datasheets for those in front of me.
                                • Jul 2015
                                • 70
                                • India
                                #35
                                Please check if this is the right part and also if the website is legit and safe to purchase..
                                The link of the website with part discription is here - http://www.mouser.in/Search/m_Produc...S4JxBTbQFzM%3d
                                Can you please also specify the
                                • lead spacing wheter - 2.5mm or 5mm and
                                • Packaging wheter - bulk, cut tape or reel.
                                as the website is asking me to choose them in the filter section.
                                  • 30965
                                  you can see the lead spacing on your board.
                                  for a 6.3mm diameter cap it would be 2.5mm
                                  the other question relates to how many you want to buy.
                                    • Jul 2015
                                    • 70
                                    • India
                                    #37
                                    "Thank's a million" but can you also please conform if this is the right part and a legit website to purchase. Link is below.
                                      • 30965
                                      no, i have no idea if mouser.in is legit.
                                      try mouser.com and select your country.
                                      btw, Bahamut could sell you cheap caps - i'm surprised he hasnt offered yet.
                                        • Jul 2015
                                        • 70
                                        • India
                                        #39
                                        That is exactly what I did.
                                          • 30965
                                          then it's a legit site
                                          • ay_erdi
                                            Netgear R7500 Router Dead
                                            by ay_erdi
                                            Hi everybody,
                                            My router netgear R7500 is dead.There are four burnt components inside.Can you help me identify?
                                            VR8-U17-U78...
                                            02-16-2024, 10:58 AM
                                          • EasyGoing1
                                            UPNP, "Standards" and hardware that implements it
                                            by EasyGoing1
                                            I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                                            One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                                            So I decided to implement UPNP...
                                            07-16-2022, 07:12 PM
                                          • howardc64
                                            Samsung UN55JU650DF network/streaming problem
                                            by howardc64
                                            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                            07-09-2025, 12:44 PM
                                          • BOSCHNJAK
                                            by BOSCHNJAK
                                            ABOUT ME INTRODUCTION FILE
                                            2
                                            024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                                            2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                                            2022 BEV, PROJECT ?
                                            2021 BEV, PROJECT ?
                                            2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                                            2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                                            12-28-2023, 02:09 PM
                                          • davg
                                            Home network connection problem
                                            by davg
                                            I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                                            03-06-2021, 07:13 AM
