Unable to access NETGEAR WGR614v7 browser user interface after resetting
Re: Unable to access NETGEAR WGR614v7 browser user interface after resetting
Hey I cannot watch everything ya know
I got Chemi-Cons KZM 470/6.3, even slightly better than FR. From the picture, you can also fit D8x12-15 cap bent 90°. Or put two 470uF in parallel, in the second vacant spot too.Last edited by Behemot; 12-15-2017, 06:44 AM.Less jewellery, more gold into electrotech industry!
Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Is it true that if I use an old router it will be less prone to hacking like my NETGEAR WGR614v7 router as I read somewhere that old computers and old computer hardware like floppy disks, routers etc. are less prone to hacking.Last edited by Captain Bill grace digger; 12-22-2017, 10:30 AM.Comment
the fewer fancy "features" the smaller the attack surface is.
best to use open source firmware on it and keep up on any patches.
i also disable config via wifi.
this forces a wouldbe attacker to gain wired access to even try.
No. This is a misconception based on a lack of understanding of technology and how it can be (ab)used.
Once an exploit is known, it can be catalogued and then called up as needed and applied to whichever target is of interest. E.g., you can design a web site to look at the browser being used (not just rely on the information that the browser provides to identify itself -- cuz that can be spoofed) and deliver a customized page designed to confound that particular client at that particular time. Another client accessing the same page could receive a different payload tailored to his vulnerabilities.
Likewise, your host(s) can be probed to determine which services are running and those services probed to determine their vulnerabilities.
Even basic network traffic can reveal the identity of the OS that is behind it.
My "secure" laptop (e-commerce) is a stripped down system with no extraneous applications, no unnecessary services, etc. And, it has no persistent storage! Turn it off and the system forgets every exploit that may have been (successfully) targeted at it while it was running. Turn it back on and the effects of the exploit are gone, completely.
I.e., you use it for a specific purpose and then turn it off. You forego the convenience of checking your mail, opening PDF's, surfing the web, etc. in order to maximize its resilience.
Machines on which I want that sort of convenience trade it for a complete absence of any information/access that an attacker might want. So, if ever successfully breached, I am forced to reload all of those applications (from the disk image that I made when I built the machine -- a 15 minute recovery effort).
As a result, I don't have to stay current with the latest "security updates" from OS vendors. Nor perpetually update all of the applications I've installed. Nor worry about 0-day exploits! And, I don't take the performance hit of running (and keeping up-to-date) an AV/ID product.
[C'mon, computers are cheap enough that if you can't afford to have one for on-line use and one for REAL use, off-line, you're not trying very hard!
FOSS isn't a panacea as evidenced by the vulnerability in the HTTPd of his WGR614
One of the problems with FOSS is that folks don't think they need to understand the technology in order to benefit (in terms of savings in development costs) from using the existing codebase. That's why you see TV's (and other "smart" appliances) that crash -- cuz the code wasn't designed to run on an appliance! Or, in a potentially "hostile" environment.
[I.e., the folks using/deploying the code never take the time to read through it with an eye towards understanding its limitations and how it can fail]Comment
by ay_erdiHi everybody,
My router netgear R7500 is dead.There are four burnt components inside.Can you help me identify?
VR8-U17-U78...-
Channel: Troubleshooting & Designing Networks
by double_DDHi all,
It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,... -
by EasyGoing1I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
So I decided to implement UPNP...-
by howardc64Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable... -
by BOSCHNJAKABOUT ME INTRODUCTION FILE
2024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
2022 BEV, PROJECT ?
2021 BEV, PROJECT ?
2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...-
Channel: Visitor Messages
12-28-2023, 02:09 PM -
- Loading...
