Am I wrong on this?
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Am I wrong on this?
    I told him the throughput is likely the switch, or an idiot time warner tech
    • 30964
    Re: Am I wrong on this?
    the fact that it's halved - is everything hard configured for "full duplex" and not entrusted to "auto"??
    i have seen XP and older fuck this up by default sometimes.
    not touched any newer win-shit so dont know.
    • Uniballer
      • Jul 2013
      • 334
      There is not enough information in the screen shots to be sure what is being measured. For example, if the tech is reading framing info, or measuring actual throughput to the first hop router (wherever that is physically located), and the user is trying to use speedtest.net, or to download a file from a real server out on the Internet when everybody in the neighborhood is doing the same, it is no wonder that the measurements differ.
      One of my co-workers who is paying for 100 Mbps Internet access over Verizon FiOS asked me to check it, and he was really getting 100 Mbps to speedtest.net.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Depends on the speed of the can on the other end of the string (what server you're measuring from). Also, there could be a limit on the modem or router if either was bypassed.
        Also the tech may be using a BS tool that is more marketing than diagnostics.
        sigpic
        (Insert witty quote here)
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          One thing not included is on two seperate computers hes getting 50mbps on ethernet. So I was thinking perhaps router processing power
            • 30964
            well router ethernet>ethernet port performance is generally crap compared to a hardware switch / hub,
            but exactly half the rated speed is a bit suspicious.
            • ChaosLegionnaire
              HC Overclocker
              • Jul 2012
              • 3264
              • Singapore
              try plugging in a third pc/laptop/tablet/whatever if the router has a third ethernet port and see how it behaves now.
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                It would not matter because half duplex only means a device cannot both talk and listen at the same time ... if its just listening (to data coming in lets say like a download or a streaming video) then that data can still stream in at the full hundred megabits (minus overhead for TCP etc.).
                sigpic
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  First ... your assumption that the tech is full of shit and trying to evade the work involved of actually solving the problem is the right assumption in just about EVERY case of large ISPs ... the fact that hes getting 100 meg at his meter doesnt mean shit! What the hell is a meter anyways? Is it a PC running TCP/IP? Or is it some special device designed to measure the actual layer 1 / 2 signal coming into the clients home? Cause if thats the case, then all the tech has verified is that the signal coming into the home is sufficient to handle the service level that the client is paying for ... the problem now, is that somewhere his service is being choked back to 50 meg, and I would bet a donut that the confifg issue is in the cable modem.
                  sigpic
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    This is a dumb thing to suggest because things like this are almost ALWAYS a default ... but has he power cycled his cable modem since changing his service? OR is this a problem that recently started ... like his service was running fine then allofasudden it wasn't???
                    sigpic
                      • 30964
                      not true,unless your using UDP every packet - usually small like 8-64k has to be aknowleged before the next packet is sent.
                      dont be fooled by terms like "streaming", it's more like a high speed stream of bursts with ack's returned between each one.
                      • junktv
                        • Nov 2010
                        • 3064
                        My ISP uses light. I get 50m/50m. Unless I go straight to pc. My router is getting old like me.
                        I'm not a network guy.
                        • EasyGoing1
                          Shock Therapist
                          • Sep 2016
                          • 977
                          TCP/IP overhead exists in both half and full duplex as it is the nature of the protocol...
                          My point was that the duplex setting will not effect bandwidth, and in general ... a one way transmission over a half or full duplex connection given the same bandwidth will be very close to the same speed. Set the NIC in your computer to half duplex and download a large file. Then set it to full duplex and download that file again ... you'll see what I'm talking about.
                          sigpic
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            You're saying that your ISP uses fiber optic as their transmission medium... odd that you would not get the same bandwidth going straight to your computer ...
                            And just for trivial knowledge, the methods of moving Internet traffic over fiber are often the same as the methods used in copper (same protocols etc.) - the only time it is different is if they configure it as a trunk line which is an extremely fast way to push multiple data connections over one strand of fiber... those trunking protocols are wicked fast and the newer implementations wont even work on copper over long distances especially. fiber can be run at much MUCH longer distances before the signal needs to be repeated. Copper is lossy and noisy where fiber is virtually lossless and extremely quiet. it would be like driving a 30 year old car that had its shocks and struts replaced with steel rods on a dirt road... then switching to a brand new cadillac. night and day.
                            sigpic
                            • EasyGoing1
                              Shock Therapist
                              • Sep 2016
                              • 977
                              If the router is what the ISP typically uses for these connections then doing a bandwidth test (preferably to a server on the ISPs network) will always result in showing you the speced speed of the connection... you would need many computers all of them sucking down Internet data in alarming quantities at the same time you're running the bandwidth test before you're going to notice their effect on the connection.
                              sigpic
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                Like you could literally have 15 computers all watching youtube videos at the same time and then run a bandwidth test from a 16th computer and I would be surprised if the test results didn't show the full subscription speed ... and that is because of the nature of video streaming being very "bursty" ... even if other computers were downloading large files at the same time .. the odds that the server they are pulling the file from, actually allowing them to saturate your bandwidth is extremely low ... when you run a server, you design the throttling of outgoing bandwidth because you're going to have many people accessing you at the same time and you don't want people on the internet taxing your service and your hardware at any level where your own computer performance will be affected. In other words ... its pretty difficult for one person or even a bunch to be doing stuff on the internet at a level where others on the network will notice the speed loss... That would be VERY difficult to do.
                                sigpic
                                • junktv
                                  • Nov 2010
                                  • 3064
                                  Yes
                                  Odd you would think hardware doesn't matter. I mean 14k modem should gigabit right?
                                  • Jeff'sTech
                                    Dell Latitude 7420 BIOS Unlock Gone Wrong
                                    by Jeff'sTech
                                    Hello everyone.
                                    I have come here with a rather specific question. I was given a Dell Latitude 7420 laptop with a busted screen, and wanted to see if I could refurbish it into my daily driver. I wanted to experiment and see if a 2-in-1 display would work as the chassis of the laptop and 2-in-1 7420 looked identical. I threw in the display and my hypothesis was correct, however, I was greeted with a locked BIOS and since I didn't know the password, I figured I'd try to unlock it somehow. I bought one of those POGO pin probe things for my CH341A programmer so I could read and make...
                                    11-08-2023, 03:30 PM
                                  • Vincent Kahle
                                    Winbond 25Q16JWNIG – Asus ROG Strix Scar 18 G814JZ bricked after wrong flash – Need help
                                    by Vincent Kahle
                                    I hope someone can help me.
                                    I have an Asus ROG Strix Scar 18 (G814JZ) laptop with a Winbond 25Q16JWNIG chip on the motherboard.
                                    Unfortunately, I flashed the wrong file (BIOS/EC/other region – I'm honestly not sure anymore), and now the laptop is completely dead: no display, no fan spin, no reaction at all.
                                    I have a CH341A programmer and I'm able to read and write to the chip. However, I'm not sure which software is best (AsProgrammer, NeoProgrammer, etc.) or if there's anything specific I should watch out for.
                                    A valid BIOS/EC backup...
                                    06-05-2025, 09:27 PM
                                  • BMCappelletti
                                    Asus Chromebox CN62 - wrong chip put on BIOS reader
                                    by BMCappelletti
                                    Long story short:
                                    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                                    - gave the computer to his son a couple years later
                                    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                                    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                                    (seems like the story was not that short)
                                    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                                    01-08-2025, 07:27 PM
                                  • Andreasbest
                                    HP 840 G1 Completely wrong system info
                                    by Andreasbest
                                    Hello.
                                    I received a 840 G1 with completely wrong system info in BIOS.
                                    Serial Number and everything is wrong, even the Model is wrong (written as 850 G1)
                                    How can i reset these info?
                                    Thank you!
                                    03-22-2022, 03:59 AM
                                  • alegatorul
                                    Cello Tv . wifi 40" board HK.T.RT2841P638 wrong file update
                                    by alegatorul
                                    hi,
                                    i've being using this Cello tv, uk brand, C40rts, HK.T.RT2841P638 main board, for a year or more.
                                    Last week i've found an update, 3rd party, that i though it was close to my board. Inserted on a usb stick the install.img, started the Firmware update, ended, rebooted and nothing. The led (red-green) keeps flashing, backlight is on but to response on remote.
                                    I've retried with original fw, no success. Hooked the uart Cp2102, putty, tried to swuu command (to update from usb), it goes for a while the get "cpu reset" on laptop screen that brakes the process and halt....
                                    11-03-2024, 02:28 AM
