Re: Suggestions on how to CAT6, CAT3 and RG6
I misunderstood what you were asking originally. When you said both sides of the return, I thought you meant the one upstairs was one side, the one in the basement was the other side, for some reason. But I do have access to the whole return grate upstairs, the problem is the entire floor joist is now the ductwork, you follow? They used this cardboard type stuff called ThermOpan to block off the rest of the joists. I can probably remove the piece they put in by the romex, but I'm not sure I can put it back in, now that the ductwork on the first floor is installed. They put them in through the hole they cut in the ceiling of the first floor. Want me to try removing that and seeing what's back there? How would I tell when the wires go dead if I don't have access to any junction boxes up there? I'd have to kill the power to the entire house, wouldn't I?
