Re: Website, CSF, and lots of attacks.
Ahh, that would make sense, wouldn't it?
maybe this explains your Telnet probes.
http://www.theregister.co.uk/2016/10/03/iot_botnet/Leave a comment:
These must be cheap windows. We can't find any make or model information anywhere, on any of them. There's some stickers but just warnings and stuff. If you carefully look at the metalish looking strip between the panes, you can read 2 MI. I don't think they make the windows though. I tried contacting them and never got a response. We need new screens but these aren't normal screens. They're weird. I guess eventually, we'll replace the windows with those low-e's. The window things way off topic though. Sorry {: - )Leave a comment:
From what I can remember, 15k hard drives were used by companies in RAID6 or similar configurations, along with "short stroking", a technique where a partition smaller than the total capacity of the drive is created in order to make the hard drive move the heads much less, so faster access times to particular data tracks.
This was great for databases, for lots of I/O per second, to access random rows in tables of the database very fast. You bought 75 GB drives and made 20-30 GB partitions and had a 100 GB drive in a RAID6 or something like that, enough for databases.
WD had 10k raptor drives in 3.5" format and then moved to 2.5" drives in 3.5" shell (heatsink) pretty much in order to simulate this short stroking technique, by using smaller platters you get smaller access times, besides the other benefit of less platter expansion, fewer recalibrations etc etc
The technique was useful for reading tracks fast once the heads positioned themselves over the track.
Advances in head and platter technology made high speeds less important. Think giant magnetoresistance (GMR) , perpendicular recording , shingled magnetic recording (SMR) all these contributed to increasing area density so basically the head reads a lot more bits at a slower rpm compared to older drives.
Then you also have movement to Helium which basically reduces the heat produced by friction with regular air and vibrations are reduced as well, so platters may not expand and contract as much, and the platters can be made thinner.
It's also rumored (i'm not sure it's true) that due to less expansion and contraction, the platters can be made with fewer servo tracks, fewer calibration tracks, so more tracks per inch can be squeezed on platters.
See text, comments and pictures in this article on Anandtech if you're curious to learn more about Helium usage in drives: http://www.anandtech.com/Show/Index/...ultrastar-he10Leave a comment:
the flash problem is getting worse,
they keep shrinking the cells to get higher capacity.
as you shrink the cells, you reduce the residual charge.
very old flash chips could retain for 10years+
relativly old - 5years+
the very latest huge capacity chips with internal error remapping etc are rated in months sometimes - you need an o.s. that will refresh the cells with a filescan ocasionally, or an SSD firmware that will enforce a refresh.
BUT that wont help if it goes in storage or is simply not used for whatever reason for a relativly long time.Leave a comment:
Helium permiates most materials slowly - inc rubber.
i bet those drives dont contain helium for very long!Leave a comment:
Right, the question wasn't so much about what drives are better or faster. I'm just trying to wrap my head around the the RPMs. How that equates to faster transfer rates. I would think access time and seek time for the older style hard drives would be what mattered and the speed of the drive (in RPMs) wouldn't really matter at all. Just because it's 10,000 RPM, if it takes longer to find the data and access the data then a 7,200 RPM drive, wouldn't the 7,200 RPM drive be faster, even if it spins a bit slower?
See text, comments and pictures in this article on Anandtech if you're curious to learn more about Helium usage in drives: http://www.anandtech.com/Show/Index/...ultrastar-he10Last edited by mariushm; 09-28-2016, 01:49 PM.Leave a comment:
I mean, ultimately, you need redundancy (backups, RAID, both, etc) if the data's important.
I had a 2GB unit I bought, brand new, never opened, but it was maybe 10 - 15 years old. It was in high storage lockup at Staples. High storage is for high ticket items. Item's likely to get stolen. Only managers have keys and it was just sitting on a shelf for years. Never touched. I bought it. It was like 2$. Originally, it was like 600$.
I plugged it into a PC. It was IDE. The PC started, initialized the disc. I threw a Linux live disc in and was formatting the drive. About half way through the format, click click click. Drive died. Moving parts will always fail, sooner or later. I'm guessing these parts failed from age, but I guess someone could have dropped it during shipping or something.
I found a thumb drive that was 256MB in size in my house. It was when they first came out. It had a little display on it that showed how full it was. I didn't think the thumb drive would work. It must have been at least 10 years old, if not older. Back then, 256MB thumb drives were huge. Probably costed me close to 100$ back in the day. The bar that showed how much storage was being used, it was still active and displaying. I was like how the heck is this possible? We don't have batteries that last that long! Anyway, I plugged it into the PC and sure enough, data was perfectly fine and it brought back some good memories. I had some old C source codes on it from when I was majoring in Computer Science back in 1999 ~ 2000.Leave a comment:
Regardless of rpm, any SSD kills classical hard drives, except those on SAS 12 gbps maybe (and even those are killed by some more high end SSD drives, like the pci-e based ones, r NVMe drives with pci-e x2 or x4 bandwidth).
The 15k drives are basically a compromise between capacity (600 GB) and access times, but the price of SSD drives and flash memory is going down fast that they're not worth it anymore.
Have a look at specs for 15k drives: http://www.seagate.com/gb/en/interna...15k-hdd/#specs
530 gigabit per square inch density, and they peak at 246 MB/s and up to 2400 MB/s bursts (reading from cache, stuff like that)
There's drives with higher data density out there and drives which can sustain transfer speeds close enough to those of 15k drives, so the only benefit they have is lower access times
For example here's the Seagate 10TB Helium drive : http://www.seagate.com/gb/en/enterpr...dd-10tb/#specs
They have sustained rate of 237/249 MB/s, close enough to the 15k drives ..
Makes no sense to pay close to 400$ for 300 GB 15k 12gbit drive when i could pay 750$ for 10 TB drive.
Or you could pay $250 for something like Plextor M8Pe Series 512GB which reads at 2300 MB/s and writes at up to 1300 MB/sLeave a comment:
Which make hard drives good for storage or a clone drive when the SSD fails.Leave a comment:
the other thing is data retention - i'v seen some pretty fucked up numbers on the entrophy of the cells in some MLC flash drives.
hard-drives, hold the data for years.Leave a comment:
Or you could pay $250 for something like Plextor M8Pe Series 512GB which reads at 2300 MB/s and writes at up to 1300 MB/sLast edited by mariushm; 09-28-2016, 10:52 AM.Leave a comment:
The data is scattered about the platter/s if it can seek it faster the IOPS increases.
Imagine a conveyor belt in an Amazon warehouse with two order pickers. One is a little faster on his feet than the other, the parcels still move along the conveyor at the same speed but there are more parcels with the faster picker.
There's access time as well. So, does the speed of the drive actually matter? Or in the end, is it just access time and seek time that really matter? Are there any 10,000 RPM drives that don't perform as well as a 7,200 RPM drive with faster seek and access times?Leave a comment:
Imagine a conveyor belt in an Amazon warehouse with two order pickers. One is a little faster on his feet than the other, the parcels still move along the conveyor at the same speed but there are more parcels with the faster picker.Leave a comment:
it is faster, they have been around for many years - if you use scsi.
i have some.
https://www.cnet.com/forums/discussi...-drive-100519/
notice the date on that!
http://www.seagate.com/gb/en/interna...mance-15k-hdd/Leave a comment:
your talking about seek rates, that is in the drive specsLeave a comment:
I'm having a hard time seeing how the speed of the drive affects overall transfer rates.Leave a comment:
So it is a hybrid drive not just a hard drive. I tried to read up on the platform but the download was so slow I could of gone to sleep.Leave a comment:
There aren't any 15000rpm SATA drives as far as I am aware.
A faster drive has a faster access time and IOPS input/output operations per second.
Whilst a drive might be connected to a SATA 3, that's not its read speed. Thats the theoretical max speed.Leave a comment:
by soflesHi there.
I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
Now situation looks like this, If... -
by HondamanI found an interesting summary on a wiki that Youtube "right to repair" enthusiast Louis Rossman put up. He suggested I could use a hardware firewall and pfSense as a firewall, and use pfSenseNG as an ad blocker. Or use OPNSense as a similar alternative. Seems like it would be easy to set up, but it only runs on the hardware supported by BSD. (I'm sure the developers and maintainers of BSD are super-busy and cannot support every single piece of hardware out there, so I can't fault them.)
The trick, apparently, is to "assign IP address lists from sites like I-blocklist...-
Channel: Troubleshooting & Designing Networks
by prw07Mac crashes and restarts with kernel panic. No water damage on board. Board is clean. Memtest86 showing no errors. The installation Ventura or Sonoma is successful, but after 5-10 minutes of operation, the accident occurs again. Did a DFU restore and revive, twice with success and successfully reinstalled Sonoma. After 5 minutes of work Mac crashes with Kernel Panic. Apple Diagnostic (AHT) does not find errors.
How to localize the problem ? -
by phantomEVOPlease help. Never opened before!!
arrived with black screen (with backlight) . trying to reboot: still the same.
booted to usb ->ok
format ->ok
but a lot of kernel panic!
tried other os, tried other ssd, no luck
sometimes it works flawessly, some time a lot of kernel
I ADD KERNEL PANIC LOG
PS no error from apple hardware test... -
by ronaldopdiasHi, I have an A1990, i9 & Radeon 560X. Before it was freezing every few seconds, almost as if failing SSD, even on external macOS installation. I have tried a clean reinstall, revive + restore T2 firmware and it now works fine, other than it seems to kernel panic after some time in sleep.
Below is the kernel panic log, its similar to a lot of posts online for the same model, with no comments on how to fix the issue, and whether its firmware related or an LB issue. Most seemed to happen running Catalina but I am on the latest version of macOS Ventura.... - Loading...
