Recommendations please
  • dsc
    • Aug 2015
    • 53
    Quick background: I work at a golf course where the main building and maintenance building are approximately 400 yards apart.
    The main building has the server and internet but the maintenance is to far away for them to run a line.
    There is wifi but the signal is simply to weak, it is also a portal so you have to open a browser and click for internet access.
    I would like to install an antenna (yagi or parabolic) on the building and a network card in my pc to pull in the signal.
    On top of this I would like to be able to feed the other two computers in the maintenance building via cable and have our own wifi signal.
    As there are so many cards and such out there I am looking for suggestions as to best performance/price.
    The other question is, can I install a wifi card in the pc (Windows 7 or 10) to pull in the signal and then connect a switch router (have a old one with DD WRT on it) to the original ethernet card in the pc thus providing the wifi and cabled connections?
    I've looked for a new card that has both wifi and ethernet but the only one I saw was rather expensive.
    • 31087
    Re: Recommendations please
    just use a tp-link high-power access point like a wa5110g / wa5210g
    • dsc
      • Aug 2015
      • 53
      Thank you STJ but they won't work for my situation.
      The IT guy refuses to change anything at the main building, which has a great deal of metal in it, as does the shop.
      The other problem is I have to sign into the available wifi as it is a public portal connection, simple enough if I have a browser access. IT won't allow anyone but the office managers onto the secure system via wifi. I would simply use the DD WRT powered router if it wasn't for that.
      • TechGeek
        Computer Geek
        • Jan 2015
        • 2254
        Install a high-power antenna, have some kind of receiver w/ coax line, and hook that to a cable Internet box. Use the Ethernet connection for the WiFi router, and done.
        Permanently Retired Systems:
        Kooky and Kool Systems
        sigpic
        • diif
          • Feb 2014
          • 6978
          • England
          Bridging the connection between wireless and a wired connection is easy, however I think the portal might possibly cause an issue with your DD-WRT router (you couldn't run DHCP on it).
          If you have two laptops you could try it out before spending any money.
          Connect to the DD-WRT router and configure the wireless and turn off DHCP.
          Plug it onto the Ethernet socket on the laptop. Connect your laptop to the the wireless network and bridge the connection between the wireless and wired, then see if another laptop can connect to your router.
          • steved271
            • Jan 2014
            • 29
            • England
            I had to do something similar back in 2008 when i was an IT systems engineer for a company, we were waiting for fiber to be installed under a road, but some dufus had already setup the factory with its machines.... I installed two of these, one at either end and it worked great, that great infact that they decided to use it as a backup in case anyone accidentally chopped the fiber when digging up the road....
            Similar product to this would work, but you would need to check out the range properly and find one that will intersect with your WIFI Base Station by 33 - 45% at least, that way you would get a decent stable signal in all weathers....
            http://www.uk.insight.com/en-gb/prod...FY4V0wodZM4MVg
            The company i work for now, installs WIFI in Towns and cities in the UK...
              • 31087
              not "Kelly's" i hope!
              • steved271
                • Jan 2014
                • 29
                • England
                No way... I wont say my opinion of them on a public forum... lol
                • ant3202
                  • Jun 2006
                  • 275
                  • Singapore
                  depends on the budget......
                  can consider looking at ubiquiti outdoor range
                  • Uniballer
                    • Jul 2013
                    • 334
                    If there is a business purpose to support it then putting in fiber is the best answer. In the long run it will pay for itself in reliability, bandwidth, lightning immunity, etc. Run everything on it: Internet, in house computer links, telephone system, video surveillance.
                      I need an answer to how to amplify my WiFi signal because it is so weak outside
                      I have a really bad situation right with a very weak WiFi signal outside of the house and I have been told that I can not have two routers on my modem because it cause issues so what is the solution for this issue
                      I can fix the garage door opener with a cat5 cable to device modem or at least that is what I call it and it works very well so far but by doing this I have no router in the garage and no WiFi signal inside the garage unless the door is open but it is extremely weak if not at all
                      The MyQ cameras can NOT hookup to a cell phone hotspot I have tried it need...
                      11-19-2023, 06:23 PM
                    • BOSCHNJAK
                      by BOSCHNJAK
                      ABOUT ME INTRODUCTION FILE
                      2
                      024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                      2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                      2022 BEV, PROJECT ?
                      2021 BEV, PROJECT ?
                      2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                      2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                      12-28-2023, 02:09 PM
                    • AstutePauciloquent
                      Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                      by AstutePauciloquent
                      Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                      I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                      11-23-2023, 11:02 PM
                    • howardc64
                      M557-G0 no WiFi/Bt no WIFIVendor file?
                      by howardc64
                      Thanks to Diah, got M557-G0 LCD panel buffer board repaired and running ( link ) Next challenge is no WiFi/Bt despite module on the main board and getting 3.3v supply (3.45v measured)
                      • TV Menu shows Network Access Point option (enet unplugged) but menu can't select that entry
                      • Service Menu shows many Bt/Wifi info missing
                      • Vizio app shows no WIFIVendor file
                      Prior owner used enet and said turned off wifi somehow. It seems system config info for wifi might be missing. Anyone experienced this before?
                      • Tried countless enet unplug (user manual said need to unplug enet to get to wifi menu), factory
                      10-15-2024, 01:12 PM
                    • ugamazing
                      820-00850 & 820-01949, No WiFi *In Recovery*
                      by ugamazing
                      I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
                      1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
                      2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
                      01-25-2023, 05:39 PM
