Cisco 2948G-L3 switch
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Rec's this used in a reported condition where it would lock up
    after a an uptime of 3/4 days
    I suspect capacitor failure in line with the symptom but
    this remains to be seen.
    With the cover off, the SMPS PSU is populated with Nichicon
    PMs and Rubycon YXGs
    The main PCB has four of the devices in the middle with
    large heatsinks and there are 4 fans to the rear of the chassis.
    The main pcb of the switch has 23 of 10V 1500uF caps
    as well as several tant chips caps and a couple of,
    what appears to solids at 35V 220uF
    My Q is?
    The 23 of 10V 1500uF caps are brown with a K mark
    on the top of the cap but, the logo on the side is
    what appears to be Nc.
    The solids have the following markings;
    100 220 35z
    I do not know what these are. Can somebody help?
    I should add there are no signs of distress albeit I
    have not tested the ESR of any yet.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Cisco 2948G-L3 switch
    http://www.niccomp.com/
    • JEWilson
      • Sep 2007
      • 369
      Thanks Willa
      In actual fact, the solids are 001 220 35z
      The lytics are NRSZ series
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        nc caps are ok
        likely rebadged sanyo.
        i have put nrsz in a ton of stuff with no problem.
          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-06-2024, 05:30 AM
        • madan1
          cisco poe switch PSU issue
          by madan1
          Hello everyone.
          I'm troubleshooting a cisco switch, which seems to have an issue with the PSU.
          The psu has the following power rails - +12v, -53.5V and +3.3V
          When connected to power, the +12 and -53.5 seem to work fine, but the +3.3 starts at ~3v and then goes down to ~0 (I guess this is the cap discharging). This happens both when the cable is connected and not to the switch board.
          Any ideas what might be causing this behavior?
          04-23-2024, 01:58 PM
        • fuxxy
          Cisco C2960CX managed switch - Won't provide POE
          by fuxxy
          Hey guys, I have 4 of these switches.
          One switch works as intended - Boots, Accepts configuration, Provides POE. However, after about 3 days the switch stops responding. Won't recognize console USB cable inserted, TX/RX lights stay lit when cables unplugged. Works again after power cycle.
          The other three will boot, accept configuration, and will uplink to the network. However they won't provide power to connected POE devices. I've ruled out configuration issue, as I have cloned the configuration from the 'working' switch to all 3 of these non-working switches....
          03-07-2022, 10:26 PM
        • Natob82
          Micro Momentary Push Switch?
          by Natob82
          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
          12-21-2022, 05:22 AM
        • grimacelord
          NEC TurboExpress On/Off Power Switch Replacement Help
          by grimacelord
          I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
          I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
          I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
          11-09-2023, 09:49 AM
