Cisco C2960CX managed switch - Won't provide POE
+ More Options
Posts
  • fuxxy
    • 318
    Hey guys, I have 4 of these switches.
    One switch works as intended - Boots, Accepts configuration, Provides POE. However, after about 3 days the switch stops responding. Won't recognize console USB cable inserted, TX/RX lights stay lit when cables unplugged. Works again after power cycle.
    The other three will boot, accept configuration, and will uplink to the network. However they won't provide power to connected POE devices. I've ruled out configuration issue, as I have cloned the configuration from the 'working' switch to all 3 of these non-working switches.
    I'm at a loss for where to look, since the 802.1at POE standard has a couple different ways a switch can discover and supply power to a POE-capable client device.
    Does anyone have access to a schematic or block diagram for ANY recent Cisco POE-enabled switch?
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Re: Cisco C2960CX managed switch - Won't provide POE
    open up the switch and take some pictures and share with us.
    based on some switch poe c3750 poe troubleshooting, inspect the poe ic chips for any blown components.
    sometimes lightning can bring the fuse down
      Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
      This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-06-2024, 05:30 AM
    • madan1
      cisco poe switch PSU issue
      by madan1
      Hello everyone.
      I'm troubleshooting a cisco switch, which seems to have an issue with the PSU.
      The psu has the following power rails - +12v, -53.5V and +3.3V
      When connected to power, the +12 and -53.5 seem to work fine, but the +3.3 starts at ~3v and then goes down to ~0 (I guess this is the cap discharging). This happens both when the cable is connected and not to the switch board.
      Any ideas what might be causing this behavior?
      04-23-2024, 01:58 PM
    • Natob82
      Micro Momentary Push Switch?
      by Natob82
      Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
      12-21-2022, 05:22 AM
    • SluggerB
      Help making a switch work the opposite way with a relay
      by SluggerB
      I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
      I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
      It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
      02-07-2025, 07:57 PM
    • madan1
      Cisco catalyst 2960c POE
      by madan1
      Hello everyone.
      Got a catalyst 2960 from the usual scrapyard - ebay.
      It is stuck in bootloop and the power supply is missing the 3.3v rail. (+12V, -53V, +3.3V)
      Some green moisture crystallization on mainboard, which cleared very well with IPA and visually there is nothing rusted or gone.
      Still working on the PSU to get the 3.3v rail back (waiting for parts), but for now I'm using an external buck converter board hooked up to the 12V rail ( by the way, the switch seems to be working with only 12V ).
      The switch fails to boot due to the following POST error:...
      12-19-2024, 09:34 AM
