About network cards failures...
    • 30977
    Re: About network cards failures...
    carefull, most laptops dont use magjacks - they use a seperate transformer.
    post a foto of each side of the board near the connector.
      • 30977
      the transformer says "PULSE" on it and is marked U30 on the board.
      page2 on the schematic.
      • hikaruichijo
        • Aug 2015
        • 123
        • Spain
        Thanks for the warning!! I have two boards here from old acer laptops that have the black rectangular transformer, thats why I thought the Compaq has the transformer on the jack....
        Ok, here are the photos.
        Well it seens to be a diferent laptop, mine is a PIII. It says N600c series pp2040. The squematic you've found looks like a pentiun 4.
        I runaway Of P4's as far as I can .
          • 30977
          is the network controller on a seperate board? i cant see one!
          does the socket have a maker or part number on it?
          • hikaruichijo
            • Aug 2015
            • 123
            • Spain
            Well, I already noticed that, I thought that the nic may be integrated on the chipset but I don't know. It doesn't have another board apart the power board that I removed for the photos. It is a 13" laptop very small for the age from my point of view. What you see in the photos is what it has, apart from the power board, the wifi card and the ram
              • 30977
              found this:
              it says the network interface is optional on a mini-pci card.
              • hikaruichijo
                • Aug 2015
                • 123
                • Spain
                #27
                My god, no you are God, I never imagined that, it has an Intel 2200bg wifi on the pci slot so I thought the Lan nic was damaged I'm going to look if I can find that mini pci lan card somewhere.
                I never saw a thin like this...
                  • 30977
                  i have seen it before, i think it was old IBM's
                  • hikaruichijo
                    • Aug 2015
                    • 123
                    • Spain
                    #29
                    The experience makes a diference a lot of times, thanks withought your help I would be smashing my head with a wall to do nothing
                    • howardc64
                      Samsung UN55JU650DF network/streaming problem
                      by howardc64
                      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                      07-09-2025, 12:44 PM
                    • davg
                      Home network connection problem
                      by davg
                      I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                      03-06-2021, 07:13 AM
                    • japlytic
                      Maximum speed should be marked on network ports
                      by japlytic
                      I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                      One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                      12-19-2024, 05:04 PM
                    • XxMicroSoldering
                      ASUS Rog Strix G17-712LV Laptop Liquid damaged
                      by XxMicroSoldering
                      Hello Guys
                      I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
                      10-17-2024, 10:45 AM
                    • harp
                      simple win network with optimization issue
                      by harp
                      simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                      06-23-2025, 11:01 AM
