Cisco AP won't come on randomly
+ More Options
Posts
  • sebr
    • Oct 2010
    • 79
    I have a Cisco AP1252 that randomly won't come on and all three led's are solid red. I noticed that when I am heating up (hairdryer) the area where the 4 caps are located the AP has a much better success rate to start up (and working normally afterwards).
    Even if I let it cool down for like half an hour it will still start sometimes.
    The caps tested well (in circuit) with ESR meter - they are in parallel tho. As well no bulging or leaking.
    So I am really not sure how to find the fault here. Bad solder joint? Caps?
    • 30953
    Re: Cisco AP won't come on randomly
    is that liquid between the pair on the right?
    put your iron on the connections and see if it smells.
    • sebr
      • Oct 2010
      • 79
      Hehe sorry for confusing you. I already put a bit of flux there since i planned to remove them but then , after thinking over, I might experience some cold solder joints.
      BTW: let it totally cool down now and dead again (only three solid leds). What would you suggest?
        • 30953
        change them, lifespan on smd is rubish anyway.
        use fullsize caps at a 90' angle.
        • sebr
          • Oct 2010
          • 79
          Just finished replacing those 4 but nothing changed :-(
          There are 2 other caps (100V / 10uF) that are obviously just for smoothing the PoE. They tested OK but I replaced them as well. Still no luck
            • 30953
            all i can think of is reflowing stuff then.
            • sebr
              • Oct 2010
              • 79
              Well, unfortunately I don't habe a reflow oven, only a hotair station and heatgun. Maybe I give it a try with the heatgun. What temp / time is best practice for preheating / reflowing a board? Normal oven in kitchen won't get hot enough i guess.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4939
                • New Zealand
                If you have freezer spray (or an up-side down can of air duster) you may be able to heat\freeze and narrow down the temperature sensitive part.
                -David VanHorn
                  • 30953
                  i would use the hot-air station to just reflow parts individually rather than baking the board.
                  maybe you can use the station to just heat specific areas to pinpoint the problem.
                  • sebr
                    • Oct 2010
                    • 79
                    I removed some shieldings and there are lots of BGA IC's. So next I will try to heat these up as I could not find which one cause the problems. But i highly suspect them all because the get very hot during normal operation and have thermal pads which they touch the housing.
                    Before I ruin it completely: which nozzle, airflow and temps are proper for this kind of job? NoClean flux is available.
                      • 30953
                      small 3-4mm nozzle, low airflow, temp - enough to melt solder
                      • japlytic
                        • Oct 2005
                        • 2086
                        The electrolytic capacitors in the picutre are Nichicon UUD Series (low-ESR), with their "oval" insignia of Nichicon:
