Dyson Pure Hot+Cool HP00 - Datasheet needed
  • Toueno
    Geek life !
    • Aug 2024
    • France
    My Dyson Pure Hot+Cool, model HP00, no longer starts.
    After disassembling and accessing the electronic motherboard, I found that the 16A fuse soldered to the motherboard is dead. I decided to do an electronic shunt to see the reaction, and the Dyson turns on for a few seconds and then turns off.
    It is likely that a voltage control chip or a safety chip is dead, but without the electrical schematics, the repair becomes complicated…
    Thank you in advance for your help.
    Best regards
    • 31260
    getting clear info on dyson shit is pretty much impossible.
    i just had to scroll through pages of crap just to find out the heater rating - 2kw
    2kw is 8A so if you have a bad 16A fuse something big is shorted.
    • asustuf
      Datasheet for it8225vg needed
      by asustuf
      does anyone know where to find datasheet for it8225vg chip? I can't find it on their official website.
      10-13-2023, 12:55 PM
    • PNI E.
      Dyson v15 problem with the dust detector board
      by PNI E.
      Hi guys, I have a Dyson v15 that didn’t work. The battery blink 10 times. If i disconnect the cable of the dust detector board, the Dyson turn on but after some seconds stop because didn’t feel the flow of the air because I disconnected the bird sensor, if I connect the Dyson is death. I notice the big mosfet I think with 3 pins. If I check the mosfet I have a short circuit from the center pin ne the left pins…so I think that s the problem or I wrong? The problem I can’t understand what type of mosfet is….someone can help it s hard to find. New board...
      10-02-2025, 10:18 AM
    • SoulFreeze
      Help finding datasheet for component marked G34662
      by SoulFreeze
      Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
      Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
      Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
      05-01-2025, 03:56 AM
    • quickname
      Cyberpower 1500AVR UPS repair
      by quickname
      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
      I decided to verify that the batteries were...
      11-12-2023, 09:57 AM
    • Rainbow_Chameleon
      Searching Datasheet for AM113 IC by O2MICRO
      by Rainbow_Chameleon
      I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
      Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
      If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
      On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
      So if anyone has a datasheet or at least...
      01-23-2025, 12:03 PM
