TCP Optimizer?
  • ivtec
    • Dec 2008
    • 1967
    TCP Optimizer?
    Hi guys does this TCP Optimizer works ?
    http://www.speedguide.net/downloads.php
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: TCP Optimizer?
    I dont know.... I know on Linux you just change the TCP Congestion Control.
    Follow the white rabbit.
      • 31083
      Re: TCP Optimizer?
      probably a scam like those "download accelerators" that just install addware.
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        Re: TCP Optimizer?
        Originally posted by scammers
        The TCP Optimizer is a free, easy Windows program that provides an intuitive interface for tuning and optimizing your Internet connection.
        Which you don't do on the client.
        OFC it's "totally free!" The junk simply has to be dumped; the expectation is that a certain number will fall for it- the scammers get to use those users' computers as billboards (and who know what else), some data is stolen in the process (ransomware even?), and the jerks get what they want in the end.
        The "free" tag is merely a false hope/pining/come-on.
        Even if it did work, it's not doing anything you can't already do, in your own router/modem.
        No different that the "PC Optimizer" scam, that also installed crap. They gave you a rudimentary defrag and regclean as "proof" they made your system "faster." No it didn't, even though there are legitimate defrags/regcleans, which is beside the point...
        Originally posted by bullshitters
        There is no installation required, just download and run as administrator.
        Why is that? For the "complimentary" lube job?
        Originally posted by insufferable lying bastards
        works with Windows 10, 8.1
        Won't run on "legacy" windows; it needs the "enhanced" features of h8 and 10nnis to more efficiently screw you.
        Ivtec, while this is the first time I've replied to your questions about questionable junk, it's not the first time I've noticed them. It shouldn't have even gotten to this point. Obviously, you felt something was off, otherwise you wouldn't be asking... do yourself a favor and don't let these hucksters get your goat.
        You'll be happier, and your computer won't become whitespace for the plage that is malware... Their junk'll get in there before you even know what happened- this is the very thing that causes computers to become "slow."
        No, not because "they're old." You could just as easily neuter a brand new I7 with such scamware, and they certainly aren't "old."
        "pokemon go... to hell!"
        EOL it...
        All style and no substance.
        guilty,guilty,guilty,guilty!
        guilty of being cheap-made!
        • retiredcaps
          • Apr 2010
          • 9271
          Re: TCP Optimizer?
          These types of programs may have added value when TCP/IP was first introduced into the Windows OS back in 1992, but modern TCP/IP code is likely to be very well implemented across all OSes today.
          TCP/IP, the protocol itself, has also evolved and fairly well tuned for robustness and high performance. TCP/IP is dynamic and adapts so I would generally leave the defaults as is for general Internet usage.
          If your Internet is running slow, it is likely not due to the OS implementation of the TCP/IP stack unless you are running into a bug.
          While dated, this is one of the best TCP/IP books I have read.
          TCP/IP Illustrated, Vol. 1: The Protocols - by W. Richard Stevens (Author)
          --- begin sig file ---
          --- end sig file ---
          • diif
            • Feb 2014
            • 6978
            • England
            Re: TCP Optimizer?
            Worked back in XP days but isn't required with Vista forwards as the changes were made to the OS.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Re: TCP Optimizer?
              What retiredcaps says is true, however seeing as how many people here cling to decade old operating systems a tool like this really is made for people on this forum.
              An example is that Tcp1323Opts and TcpWindowSize is set to off and a very low value respectively up to and including WinXP and Server 2003 x64.
              This severely limit download speeds over links with medium to high latency, like you would see when crossing the atlantic between Europe and the US for example.
              The tool TCP Optimizer on Speedguide.net offers a great and easy way to change this value and others, and the tool contains no malware.
              In fact it is a tool that has existed for many years, back to the Win2K days.
              Of course a power user might prefer to change the registry directly and therefore here are the default values I use on Windows 2000 up to Server 2003 x64 machines:
              Code:
              Windows Registry Editor Version 5.00
              [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters]
              "TcpWindowSize"=dword:003ebc00
              "Tcp1323Opts"=dword:00000003
              With these changes I am able to saturate a 100Mbps link with 130ms latency.
              Without the changes I max out at 0.5Mbps against the same test server in the US.
              Of course both endpoints need to support TCP Window Scaling but in 2015 this should not be a problem.
              Linux has had it enabled by default since kernel 2.6.8 released over a decade ago.
              I attached also a registry file with these options...
              • ivtec
                • Dec 2008
                • 1967
                Re: TCP Optimizer?
                stij it's not malware, i tested it on one of my machines and i notice nothing out of order,so far i don't see any benefits either,will see.
                • ivtec
                  • Dec 2008
                  • 1967
                  Re: TCP Optimizer?
                  Code:
                  Hansson you mean this TCP Optimizer will do nothing on Win 10 but will help old OPS TCP?
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Re: TCP Optimizer?
                    It's a great optimizer that will do several tweaks without the end-user having to delve into what each TCP option in the registry does, like I have.
                    That said the TCP stack in Win10 is quite good, but there are always tweaks that can be done, remember the Windows TCP code has been written to work with any links, which of course has it's drawbacks.
                    A good example would be to set Windows to acknowledge all packets, which reduces lag in games but decreases your throughput when downloading: TcpAckFrequency
                    It's a tweak that depends on usage and it's not possible to write a simple registry file for it like I've shown above because the change needs to be done at the adapter level.
                    Which is different for each PC with a unique GUID.
                    So you could use a dedicated tool, like this: http://www.wowinterface.com/download...atencyFix.html
                    Or Speedguides TCP Optimizer which can do this and lots of other tweaks...
                    • m4a2t0t
                      • Mar 2013
                      • 276
                      Re: TCP Optimizer?
                      It is not scam software. Speedguide.net has been around for quite a long time. The program was built for tweaking cable and DSL connections back when they were first coming out and people were switching from dial-up.
                      They have quite a lot of useful information on tweaking connections and friendly people on the forums.
                      • Andriy Andrusyk
                        Buying a Used GTX 1080 Ti – Is It a Scam?
                        by Andriy Andrusyk
                        I am buying a used MSI GeForce GTX 1080 Ti. All photos are attached. Is it a scam?...
                        05-15-2025, 12:31 AM
                      • Urizen
                        Canon scam: is there a useful hack to scan WITHOUT ink ? (Pixma MG 2550s)
                        by Urizen
                        title says it all
                        I've a Pixma mg2550s printer/scanner All In One
                        when I try to scan but there's no ink cartridge it gives an "error code 2,140,21"
                        scanning requires no ink so it's obvious this is a scam basically an artificial block they put in place for $ reasons
                        so how do I bypass this? is there a hack? maybe a fixed firmware
                        nb. got this new Pixma at a bargain price but I defo wont be buying another Canon product if there's no fix for this "feature"
                        12-25-2022, 09:35 PM
                      • Spork Schivago
                        Doctor's laptop and odd programs.
                        by Spork Schivago
                        Fixing a doctor's laptop. This one he says is special and the files need to be preserved. I believe it's infected with a few things. I've cloned the hard drive, hooked the machine up externally to my machine and ran Norton. It detected two things.
                        SAPE.Somoto.13 (fully resolved) --jameelnoorinastaleeq_downloader_by_ffonts.exe
                        PUA.Gen.3 (not resolved) -- Advanced System Optimizer 3 files.
                        It's the potentially unwanted application gen 3 I have a question about. I've googled the program and it looks like it might have been purposefully...
                        04-24-2016, 07:28 PM
                      • Mess
                        Motherboard diagnostic beginner advice
                        by Mess
                        To save you some time: the most important bits are in bold.
                        Some further examples/explanations or to the side & in grey - you can probs skip them if it's TLDR for you. Sorry, I've got ADHD & tend to over-explain stuff - just like I'm doing right now 😅 Briefness is for poets not me 🙈
                        Please help!! 🎶I'm just a girl in a world that wants to scam me out of lots of money for any tech stuff/repairs 🎵 Seriously tho, I'm poor&I can't afford to get laptop diagnosis, especially if it ends up needing a new motherboard. Where I live, all the tech shops are run by very...
                        09-12-2024, 07:02 PM
                        HP EliteBook 860 G10 Notebook 800 Specification for Upgrade or Repair
                        This specification for the HP EliteBook 860 G10 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 860 G10 boardview and 860 G10 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP EliteBook...
                        09-07-2024, 07:20 AM
