Netgear Prosafe GS116 16 port switch - bad cap.
  • kleung
    • 72
    I know there are internet blogs about the GS108 (8 port version); however no one mentions the 16 port version.
    This is a small business "prosafe" model.
    It is very compact; but gets pretty hot with little circulation.
    After 7 years; the switch would give intermittent connection problems only for some computers on the network (lack of switching)
    also, internet and high bandwidth would crawl along at times. This happened pretty suddenly and was hard to diagnose which is why I wanted to add to the knowledge base.
    After disassembly, clearly 1 cap is bulging. However, everything else looked fine.
    Contacted netgear and told them the cap was bulging; got an immediate RMA.
    There is lifetime warranty. In some ways; I should have just recapped myself to save another item going to the landfill.
    HOWEVER, don't have the time these days and also, for a mission critical environment; I would never trust my soldering skills.
    So, off to RMA exchange it goes....
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Netgear Prosafe GS116 16 port switch - bad cap.
    These switches are rock solid (well, besides the occasional bad cap) didn't know they had lifetime warranty.
    GS105, GS108, and GS116 are my absolute favorite unmanaged switches.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      and it will fail again!
      Follow the white rabbit.
      • kleung
        • 72
        The deadly thing is that failure is intermittent and inconsistent.
        For example; on my network; the local lan worked but the wan did not. I presume it has something to do with traffic volume issues. Also, only a few of the ports were showing issues (2?) which made it really hard to diagnose the problem.
        I actually went with a cisco switch as a replacement in the meantime. I will get the warranty repair and probably keep that around as a backup switch after inspecting it for bad capacitors of course.
        • kleung
          • 72
          Just a follow-up.
          They emailed me a brand new switch (version 2) as a replacement. I didn't bother opening up the sealed package. Will probably sell it off or keep it as a backup.
          • retiredcaps
            • Apr 2010
            • 9271
            Chemicon KZG are known to fail in any type of heat situations.
            I'm surprised at the lifetime warranty. Usually, there isn't enough margin in the low end commodity devices to cover warranty claims.
            I suspect companies just hope for the user to upgrade and recycle the old stuff before the device fails.
            --- begin sig file ---
            --- end sig file ---
            • kleung
              • 72
              well, these swithces are marketed for "small business" use and are comparable to the cisco line.
              cisco switches also have a lifetime warranty.
              the 16 port switch sold for about $180 new at the time i believe.
              they are still going for $150 these days.
              I bought a cisco 16 port switch in the interim and that was $140
              Originaly bought a dlink 16 port switch as a replacement but there are complaints about failed switches on the internet.
              • cannonman
                • Aug 2015
                Many thanks for posting on this issue kleung. I had no idea they had a lifetime warranty. As soon as I saw your post, I got on netgear chat and had a new one coming to me in less than an hour. The longest bit was finding the newegg receipt. 6 year old and still under warranty! Seeing all the info on heat, mine was in a basement open lan closet, nice and cool for 5 years then it was moved to underneath an office desk. Still open but it was warmer and failed in the next year. I have not torn in down as it is going in for RMA. From what I can see through the sides of the switch it looks like the top of the center cap is swollen just like the one in your picture. Many many thanks for getting me a near free replacement for my 16 port switch. Weird things had been going on in that network segment, and now I know why and can fix them!
                • Hemingray
                  KABOOM!
                  • Jul 2010
                  • 143
                  Have this same switch, Although with one popped cap it would only work somewhat correct on random ports. Changing said cap restored normal operation. Still using it to this day.
                    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 05:30 AM
                  • shovenose
                    Netgear JGS516PE Switch Fan Replacement
                    by shovenose
                    I got a free Netgear JGS516PE PoE switch and it works fine but the fan makes a grinding sound.
                    It uses a 12V 3 pin fan with a non standard pin out. So I took a Noctua fan and moved the wires around in the connector to make it work.
                    Unfortunately, the fan spins for just a couple seconds before it turns off and the Fan Fault LED comes on.
                    I think it's stupid they designed it to stop powering the fan when it detects a fault but I guess that's what they chose to do.
                    Instead of spending $30 on the correct replacement fan, does anyone have a clean...
                    12-12-2024, 03:24 PM
                  • Natob82
                    Micro Momentary Push Switch?
                    by Natob82
                    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                    12-21-2022, 05:22 AM
                  • grimacelord
                    NEC TurboExpress On/Off Power Switch Replacement Help
                    by grimacelord
                    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                    11-09-2023, 09:49 AM
                  • SluggerB
                    Help making a switch work the opposite way with a relay
                    by SluggerB
                    I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                    I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                    It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                    02-07-2025, 07:57 PM
