D-Link DGS-1016D won't turn on
+ More Options
Posts
  • wobbin
    • Apr 2013
    • 18
    Re: D-Link DGS-1016D won't turn on
    I bought six of these off Ebay a while back, sold as faulty - all 6 working fine after a cap change on the psu card and a new cooling fan :-)
    • rockitrr
      • Nov 2013
      • india
      I've DGS 1016D switch my psu burned nad-116 with YCL PCB452-D, burned component IC1, IC2 R5, R16 I can't identify R5 value please help me
      • joelsplace
        • Nov 2013
        • US
        I happened to have mine apart to replace the fans.
        R4-R14 are all the same. 472
        Sorry that's on the main board. I'll bet you want R4 on the power supply.
        I can't find mine. I replaced it a while back with an external power supply. The internal one died and I couldn't figure out what was wrong with it.
        I'll post back if I can find it.
        • joelsplace
          • Nov 2013
          • US
          Found it.
          R5 is 102
          My model is YCL PCB452-A
          • JohnnyBee
            • Feb 2014
            • Belgium
            Hoi Severach,
            thank you so much for your posting, it saved my so much time searching at the defective component in the powersupply.
            It was just as you told, "C12" ho was gone bad, replaced it and all functions ok again.
            Many greetings from out of Belgium,
            Johnny.
            • llaforest
              • Apr 2014
              After a power failure, my DGS-1024D wasn't turning on anymore. I too had this buzzing noise from the PSU. Replaced capacitor C12 and it did it!!
              Don't know how you guys figured out it was this cap since it was impossible to tell by looking at it!! Once removed, the tester confirmed there was no more capacitance, only resistance. I replaced it with one that is more chubby (105C) so I hope it will be less prompt to failure.
              Thanks again to those who found and posted that info, it saved my switch!
              Laurence
              • Jeffy
                • Aug 2014
                Another one... DGS-1024D, HW rev B4. Replaced C12 on the PS and fixed!!!
                Thank you severach !!
                Also, another funny aspect. Months ago I bought some wee little fans off eBay just because they were so cheap. Yep... In my junk box just waiting. Exact fit into the Switch to replace the noisy fan. Just had to splice the two wires.
                Fans were described as "4010S Cooler Cooling Fan Brushless DC 4*4 cm 18DB 12V VGA CPU Northbridge Fan" on eBay. About $2 each with free shipping. YMMV.
                  • 30963
                  there are loads of 40mm fans on ebay, but most need oiling.
                  not that it matters for that price - i got a set of 3 for about $4
                  crystal-clear too.
                  • TechnicalNugget
                    • Aug 2015
                    Thank you all; you guys are amazing. My DGS -1024D wasn't powering on, after reading this thread, I swapped out capacitor c12 with a new 47u 50v cap, and bam, it works perfectly. I am so glad that I found this site.
                    • mithun
                      • Dec 2015
                      • india
                      #30
                      D-Link DGS-1016D is not working while in ups back up
                      The power indicator is lightning up but all switches go off
                      Is there any trouble shoot for the problem
                      • Haribo
                        • Jun 2014
                        Originally posted by severach
                        Later models of DGS-1016D and DGS-1024D have a lifetime warranty.
                        One cap takes these switches down. Power supply C12 is the tiny cap next to the big input cap. You can't see it with the cap in but when you get it out you'll see heat damage which is why it goes bad. You can replace any other cap you like but that's the only cap I've ever seen go bad.
                        Thanks for this! Picked up this switch at Goodwill. Power light flickering and no initialization. The 12V power supply put out 5V, 8V unloaded.
                        Went right to C12, tested at 140 ohms ESR when pulled, replaced and switch is alive again.
                        • toxic
                          • Apr 2016
                          • bosnia
                          #32
                          +1 for bad C12.
                          At startup 12v voltage was about 5v.
                          Replaced C12 47mf and voltagew is normal 12v and switch working ok.
                          • zeontje
                            • Jan 2023
                            • bup
                            #33
                            Reviving this old thing here for a second.
                            In case anyone here happens to know which type C22 of the power board is (the beige/brown one next to the yellow transfo), I'd be very happy. This was partially blown, so I can't read anything of it.
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              #34
                              I guess you meant C12, look at post #5 on the previous page by severach:
                              C12: Ltec TK 47uf 50v
                              P.S: You can replace this with any high quality 105C (or higher) rated capacitor of 47uF 50v.
                                • 30963
                                no, i think c22 is a ceramic - maybe a snubber for the fet
                                  MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                                  This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-07-2024, 03:40 AM
                                • pajdek
                                  Lenovo Y700-17ISK turn on and off
                                  by pajdek
                                  Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                  09-20-2023, 02:49 AM
                                • Junkrepair
                                  Calculating ESR from tan delta -- tan delta's dependence on capacitance
                                  by Junkrepair
                                  I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                                  I found this nice little description of the conversion:
                                  Calculating capacitor ESR from Tan(delta)
                                  https://forum.digikey.com/t/calculat...-from-tan/2633
                                  It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                                  06-12-2023, 02:45 PM
                                  MSI Delta 15 A5EFK-081AU Notebook 15 Specification for Upgrade or Repair
                                  This specification for the MSI Delta 15 A5EFK-081AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-081AU boardview and 15 A5EFK-081AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-07-2024, 06:11 AM
                                  MSI Delta 15 A5EFK-046UK Notebook 15 Specification for Upgrade or Repair
                                  This specification for the MSI Delta 15 A5EFK-046UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-046UK boardview and 15 A5EFK-046UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                  09-07-2024, 05:50 AM
