Repaired a generic, no-name Internet router...
  • UraBahn
    Scrapheap Hound
    • Nov 2004
    • 165
    This no-name Internet router wouldn't turn on, so I opened it up and, lo and behold, a single 220uf 16v Teapo SEK cap on the input. I replaced the cap (with great difficulty as part of the Teapo's leg broke off in the hole and I had to solder over it because I couldn't get it out) with a Chemi-Con KME 220uf 25v and tried it again, but it still wouldn't come to life. Then, as I was trying to get it to turn on, I noticed the input diode "sparking" whenever I applied the power. Hmmm, that can't be right I thought. So what I did, was take an old dead Sega Genesis motherboard, scavenged what looked like the same kind, color and size diode off it, and replaced the router's diode with it. Because I couldn't get the broken Teapo's leg out of the hole, I "bridged" the UCC's negative leg to the anode of the diode (the capacitor and diode were on the same circuit.)
    The end result: LIFE! The router blinked to life. I connected it to my network hub, and it gave out DHCP addresses. I could ping the router, and even access the password screen for the web interface. (I don't have the password because the person who gave me the router didn't give me its password! ) Now if I can find out just who made this thing, I can get to configuring it for a test run.
    Only one cap, the 220uf 16v one I mentioned earlier, was a Teapo SEK. The rest of the caps are very low-value (as in 22uf) Wendell and 'W.D.'. For the recap I used a single United Chemi-Con KME 220uf 25v cap.
    And now, for the ugly pics of my ghetto repair job. (People who can solder, please don't ever do this! I was lucky this skank-@$$ "repair" worked at all!)
    The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
    I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
  • UraBahn
    Scrapheap Hound
    • Nov 2004
    • 165
    Re: Repaired a generic, no-name Internet router...
    Update: I made an educated guess at the router's password, and was finally able to access the web-based configuration. Nowhere on there does it state the manufacturer or even the model number, all it says is "Broadband Router Version 1.00.00". It does have a handy array of features, like port triggers, virtual server and the like.
    In case anyone's interested, this particular router uses the ADM5106 gateway controller chip (based on an ARM7TDMI actually). I'll be testing it on my home LAN soon enough.
    (sorry for the double post, I ran out of time before I could edit the previous one.)
    • gonzo0815
      • Feb 2006
      • 1600
      If this unit ahs an FC number, may be you can indentify the manufakturer.
      • Rainbow
        • Aug 2005
        • 1374
        Try using MAC address - http://coffer.com/mac_find/
        • UraBahn
          Scrapheap Hound
          • Nov 2004
          • 165
          Thanks a ton for the help, guys! Using your advice I discovered it was an Abocom CAS3040 4-Port Router with Integrated Switch. I also found the user's manual and a firmware update, which I will shortly install.
          Abocom's Website: http://www.abocom.com.tw
          • Tom41
            • Oct 2005
            • 336
            • England
            Sorry for 'bumping' an old topic like this, but this sounds EXACTLY like what happened to my old wireless router. One day I saw the LEDs on the front going crazy, flashing at random. I pressed the reset button with a pencil, but to no avail. Even power-cycling didn't help.
            Finally it died altogether and wouldn't power on. Opening it up, I was surprised to find that the wi-fi portion of the router was simply a PCMCIA card connected to the external antenna
            In fact, I took the PCMCIA card out, inserted it into my laptop, and it's been working happily ever since - connecting to my new router
            Anyway, I didn't see any bulged or venting caps, but when I applied power I saw distinctly the input diode 'sparking' - just like Urabahn mentioned. Not having the technical knowledge or equipment to trace the fault, I just decided to discard this router and buy a new one.
            The caps on the board are mostly 'SC' caps, see attached picture. Is this a known brand, and if so is it good or bad? Maybe it failed like a Teapo cap, i.e. no visible signs.
            You know there's something wrong when you open your PC and it has vented Rubycons...
            • gonzo0815
              • Feb 2006
              • 1600
              Well, those caps are looking very ugly, of course not a educated decision, but i for shure won`t thrust them.
              is there a coil (e.g a torroid) and a transistor like device with 3 or more legs?
              If yes, there is indeed a smps bubk regulator, wich could be handicaped from bad caps up to the point of no operation. If there is only a linear regulator without any coil, i thin it would probably an other (e.g firmware related ) problem.
              • double_DD
                Why does my ISP router hate my "homemade" power supply??
                by double_DD
                It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                07-12-2025, 03:09 AM
              • shadow666
                Router Xiaomi M4A Gigabit
                by shadow666
                hello
                i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                Mi Router 4A Gigabit Edition
                ROM CHIP is 16 MB
                i attached picture of motherboard​...
                11-30-2024, 03:49 PM
              • EasyGoing1
                UPNP, "Standards" and hardware that implements it
                by EasyGoing1
                I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                So I decided to implement UPNP...
                07-16-2022, 07:12 PM
              • BleedCap
                OLD Socket 478 custom bracket + NEW generic cooler
                by BleedCap
                I already posted this on vogons.
                Its a 3d printed custom bracket for socket 478.
                I used this AM4 bracket as a base design.
                Its to be use with cheap generic clip based cpu cooler.
                Reason for doing this is:
                - Its hard to get/find a good copper base cooler. Even if you find one, the price is ....
                - New generic cooler is cheaper and can use bigger fan (less noise)
                I tested the bracket with cheap chinese horizontal cooler + fan taken from CM hyper 212 evo.
                The processor that I was using is P4 2.4Ghz prescott....
                11-05-2023, 08:09 PM
              • chronic519
                Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                by chronic519
                Hello.
                GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                Found issue with a RAM block
                Replaced, green lines gone.
                Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                Used a good card to test and same results low errors 32+.
                I am just search for some form of command to do a full test on the GPU.
                I just ran the mats command with my good GPU and passed after roughly 40 min.
                The repaired one, ran...
                05-20-2025, 07:56 PM
