Dynalink RTA1320 ADSL router - bad recap or DSL issue?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5085
    • New Zealand
    So, I replaced the capacitors in my RTA1320 a while ago, because it was having this weird problem sometimes where it would get DSL sync but wouldn't authenticate PPP and get an IP address when first turned on (I leave it off at night) - rebooting would usually fix the problem.
    When I opened it I noticed 3 of the capacitors were bloated, but I replaced the lot.
    The original threads:
    https://www.badcaps.net/forum/showthread.php?t=12175
    https://www.badcaps.net/forum/showthread.php?t=12213
    It worked OK for a week with new capacitors but then it refused to do PPP authentication at all.
    Only way I got it working again was to reflash the firmware, reset everything to defaults and reconfigure everything from scratch.
    It worked again for another week and then did the same thing.
    I gave up on it for now and am currently using a Thomson Speedtouch ST536 v6 - but which has the most annoying web interface I have ever used.
    The catch in all of this - the Thomson has exhibited the same problems as the Dynalink, not authenticating the PPP session and requiring a reboot (although not nearly as much). It also uses the same Broadcom chipset as the Dynalink and I have not noticed any problem prior to a recent DSLAM upgrade.
    However the Dynalink was in much better shape before the recap so I suspect something there as well. I am just not sure.
    This is all very confusing - I hope someone can help me with it!
    -David VanHorn
  • japlytic
    • Oct 2005
    • 2086
    Re: Dynalink RTA1320 ADSL router - bad recap or DSL issue?
    I had a situation where the ADSL modem would not authenticate the user, even though it was properly synchronized to the ADSL line. It turned out that the username was incomplete - just a phone number (username) without @providername.com.au was causing the modem not to authenticate the user, even though it worked in the past. Something must have been changed at the provider's side...
    • Agent24
      I see dead caps
      • Oct 2007
      • 5085
      • New Zealand
      That would sound sensible but my ISP (Telecom NZ) doesn't authenticate with username\password anymore, they authenticate with the phone number.
      I believe you can put anything as the username and password, and it will still work.
      The new Thomson routers from Telecom are all set up by default with "user@xtrabb.co.nz" as the username, I guess to make it easier for people to set up
      -David VanHorn
      • double_DD
        Why does my ISP router hate my "homemade" power supply??
        by double_DD
        It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
        So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
        For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
        07-12-2025, 03:09 AM
        ASUS P5GC-MX motherboard recap
        by momaka
        Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
        This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
        So here is what the motherboard looked like with its original caps:
        CPU VRM area up close…...
        01-27-2021, 11:59 PM
      • shadow666
        Router Xiaomi M4A Gigabit
        by shadow666
        hello
        i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
        Mi Router 4A Gigabit Edition
        ROM CHIP is 16 MB
        i attached picture of motherboard​...
        11-30-2024, 03:49 PM
      • EasyGoing1
        UPNP, "Standards" and hardware that implements it
        by EasyGoing1
        I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
        One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
        So I decided to implement UPNP...
        07-16-2022, 07:12 PM
        no-name Radeon 9600 XT recap and cooler
        by momaka
        I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
        This one was actually suggested to me by ChaosLegionnaire....
        11-06-2020, 07:54 PM
