Capacitors for DC smoothing, Low-ESR or not Low-ESR?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4955
    • New Zealand
    I am posting this here as my original problem has branched off into another question and I think I'll be more likely to get a good answer with this post.
    I want to replace all capacitors in my ADSL Router (Dynalink RTA1320)
    I have decided on Panasonic FM for three of them, but I am having problems with the last two.
    They are 1000uF 25v and I believe are for DC smoothing as they are just after the bridge rectifier and a couple of coils.
    They are G-Luxon SM series which are apparently just general purpose, and the datasheet doesn't even list ESR.
    Half the problem is the size of mine are not listed in the datasheet, so I suspect they are a custom job.
    The other part is that nothing with the same ratings will actually fit inside.
    16v versions are short enough, but is this OK? The voltage I measured across them was only 11.4v, but I read elsewhere that for this kind of application the rating should be higher (Not sure if this is true)
    Also, the current ones aren't apparently Low-ESR but would a Low-ESR type be better used here?
    What about ripple current? What sort of ripple does a smoothing capacitor have to deal with?
    -David VanHorn
  • yyonline
    • Jul 2009
    • 692
    Re: Capacitors for DC smoothing, Low-ESR or not Low-ESR?
    I'm guessing the device uses a 12V power adapter? I don't see any transformers which could be stepping up the voltage, and your reading confirms this. So 16V is fine, provided they have the same or higher ripple rating compared to the SM capacitors.
    • yyonline
      • Jul 2009
      • 692
      Sorry for the double post, I couldn't figure out how to edit and quote at the same time...
      Based on the SM datasheet...10x16mm at 25V is 355mA ripple. So your replacement needs to be able to handle that.
      You mentioned NHG in the other thread. NHG exceeds this rating, making it a good replacement.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4955
        • New Zealand
        It uses a 9 volt AC power adaptor.
        -David VanHorn
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          yeah so 16v is totally fine,
          • yyonline
            • Jul 2009
            • 692
            If you're measuring 11.4V, I'd check the output voltage of your power supply by measuring it. I don't see how it would be increasing the voltage unless the supply is putting out too much to begin with. I don't often work on things with external power supplies, so someone who knows more than I do on this is free to correct me if I'm wrong.
            • Agent24
              I see dead caps
              • Oct 2007
              • 4955
              • New Zealand
              Without load the 9v AC adaptor measures 10.5v AC.
              -David VanHorn
              • Radio Fox
                • Jan 2010
                • 281
                The router uses an ac adapter. The 11.4v Agent24 measured in the first post is dc. The voltage isn't increasing, it's being rectified & smoothed.
                ________________________________________________
                Invisible airwaves crackle with life
                Bright antennae bristle with the energy
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4955
                  • New Zealand
                  I thought the rectified DC would be lower because of the silicon voltage drop?
                  -David VanHorn
                  • Radio Fox
                    • Jan 2010
                    • 281
                    Yes, it would be if it wasn't for the smoothing caps keeping the output voltage at it's peak value, rather than the RMS value.
                    As the ac adapter is unregulated, let's assume that under load, it produces it's designed output of 9v ac. As you say, when it hits the bridge rectifier, you will lose around 1.2v (0.6v lost across each conducting leg of the bridge), reducing it to 7.8v. This voltage is pulsed dc.
                    The effect of the smoothing capacitors is to "fill in" the gaps between the pulses, giving a virtually continuous peak voltage reading, which is 1.414 times the RMS voltage, giving 7.8 X 1.414 = 11.03v.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4955
                      • New Zealand
                      Thanks for that, it makes more sense now!
                      I ordered the capacitors on the 25th, just got to wait until they get here... coming from the UK - RS says it'll be 8-10 days...
                      -David VanHorn
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Excuse me, there is a slight error in the calculation. The DC voltage is the peak AC voltage (9V x 1.414) less the voltage drop of two diodes (1.2V) = 11.53 volts. Doing the calculation in reverse order (as you did) results in predicting the output voltage .5 V lower than what it will actually be.
                        PlainBill
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 4955
                          • New Zealand
                          Put the new capacitors in today.
                          (https://www.badcaps.net/forum/showthread.php?t=12175)
                          I looked back to when I bought it and it has been less than a year and half.. hopefully the new ones last a bit longer..
                          -David VanHorn
                          • Pyr0Beast
                            • Feb 2009
                            • 406
                            Heat kills caps.
                            Also 6000 hours (one year) would be quite good for the caps if this stuff runs 24/7
                            • Agent24
                              I see dead caps
                              • Oct 2007
                              • 4955
                              • New Zealand
                              It's not 24\7, I usually switch off at night.
                              -David VanHorn
                              • Pyr0Beast
                                • Feb 2009
                                • 406
                                That would save power&money.
                                Still, it isn't enough.
                                Bad design
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Originally posted by Pyr0Beast
                                  Heat kills caps.
                                  The Endurance Lifetime given in data sheets doesn't have anything to do with how long caps last.
                                  It is basically how may hours you can abuse them WITHOUT anything going out of spec when returned to nominal conditions.
                                  Manufacturers make no claims in data sheets [and usually at all anywhere] as to how long they will last after the abuse or with no abuse.
                                  Mann-Made Global Warming.
                                  - Dr Seuss
                                  • Pyr0Beast
                                    • Feb 2009
                                    • 406
                                    It has everything to do with that. If they seriously get out of spec their life has ended and that is all what matters. Unsuitable for application and suitable for recycling/landfilling.
                                    >> Load Life : 105 ̊C 2000~5000hours.
                                    Dried up cap can still hold a charge but it's usability equals zero.
                                    ESR and other characteristics are defined at rated temperature.
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Most people think that.
                                      That's because most people don't know what 'Endurance" aka Endurance Lifetime" aka "Load Life" aka "Lifetime"[in a data sheet] means.
                                      - - - You just proved you don't.
                                      There are 8760 hours in one year.
                                      - According to you, 5000 hour rated caps die in 208 days of 24/7 use.
                                      - Dr Seuss
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        There is a formula to estimate Useful Lifetime from Endurance Life but according to Chemicon [I think it was] that equation only has a 40% Level of Confidence.
                                        - Dr Seuss
                                        • dragon3x
                                          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                                          by dragon3x
                                          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                                          power on.
                                          Here are some examples :
                                          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                                          switching supply area).
                                          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                                          than 6.3 V.)
                                          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                                          I replaced capacitors with aluminum-polymer.
                                          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                                          03-21-2025, 02:46 PM
                                          Panasonic switching power supply daughter board has two 27uf @ 50 volt capacitors which I do not keep in stock
                                          by sam_sam_sam
                                          I did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
                                          This is one of the shit est boards I seen in a very long time and it was the daughter board the traces just lifting off the board I had to use the capacitor leads to repair the the traces and the main board is not any better because I had to repair several traces for the daughter board to the main board
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • chth96
                                          Is it no harm to replace with capacitor without ripple current rating?
                                          by chth96
                                          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                                          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                                          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                                          Rubycon YK DataSheet (b...
                                          04-19-2024, 05:19 AM
                                        • Ady2017
                                          Are there any datasheets available for Elna RJG capacitors?
                                          by Ady2017
                                          I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                          05-25-2025, 02:19 PM
                                        • RukyCon
                                          ZUMAX Technology (Leadman Power) ZU400W (X1), Modifications & Life Test
                                          by RukyCon
                                          Hello Again, so i'm bringing back this Zumax PSU from the gutless thread and going to be doing some modifications, and also putting it into a PC i'm going to throw together out of spare parts to see how long it lasts.
                                          So the first thing i did was fill in the missing filtering, by replacing the cheap common mode choke with a real one and adding a 470nf X2 capacitor in the open capacitor spot, i then replaced the fake Y-class capacitors with real ones, i also swapped out the mismatched primary caps with a pair of Aishi WK 470uf 200v caps, both of which test around 520uf. I also swapped...
                                          04-15-2022, 11:20 PM
