US Robotics ADSL router Recap problem
  • pavithra_uk
    • Nov 2010
    • 45
    I have lightly used US Robotics USR 9112 ADSL modem/Router.
    Used by my friend in last 2 years. not a heavy user. no problems at all.
    when I got this router from him. like to mod it (recap and cooling mod)
    1. I added heatsink for Router CPU (Its runnng very hot..)
    2. Added another small heat sink for RAM chip
    3. Replaced exiting 220uF 25V cap (this cap is placed output rail of 12V to 3.3V DC-DC convertor.) with 3300uF 6.3V cap
    4. there is a 3300V 25V cap in 12V input line. I never replaced it.
    I don't know why they put 25V cap in 3.3V rail.
    DC-DC convertor is SC4519H IC
    after I replace this cap. router dissconnects from ADSL link 10~15 times per day.
    then I re solder previous cap, (220uF 25V) now router works fine.
    all caps are 25V
    even caps in 3.3V rails
    Can SC4519H IC cause problem with large caps ? since its 600 KHz SMPS
  • retiredcaps
    • Apr 2010
    • 9271
    Re: US Robotics ADSL router Recap problem
    Unless there is a typo, replacing a 220uF with a 3300uF (something almost 15x more capacitance) will probably cause problems.
    With capacitance, AFAIK, you can go slightly up, but 15x is sure to cause problems.
    For voltage, you can go from a 25V cap to a 6.3V if you know for sure and confirmed with measurements using a multimeter.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      PS. Topcat sells caps closer to the 220uF 25V specification
      Rubycon 220uF 16v (if you are sure about the voltages - 16V is good)
      https://www.badcaps.net/store/produc...products_id=53
      • Krankshaft
        • Jan 2007
        • 2328
        You shouldn't increase capacitance unless you know what circuit it's in and if it that circuit will still operate properly with the added capacitance. Stay with the original value.
        The only place where you can go up a bit without much worry is power supply filters.
        Wow US Robotics there's a name I haven't heard in years.
        The last USR product I had was a serial external 28.8 modem . Thought they were out of business.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5080
          • New Zealand
          Yeah...... they used 220uF for a reason. So you should put a 220uF in, not a 3300uF.
          -David VanHorn
          • Pyr0Beast
            • Feb 2009
            • 406
            Yes.
            Bigger is not always better.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              #1: 220uF to 3300uF is way WAY too much.
              #2: They used 25v caps because the cans are bigger which makes the ESR lower and the Ripple capacity bigger.
              Use a 220uF cap. That size is easy to find.
              You can usually raise uF by 20% but there is usually no benefit in doing that.
              [That is an option when you can't find the right uF cap but 220uF is easy to find.]
              Voltage doesn't matter AS LONG AS you have low enough ESR and high enough Ripple -and- it is more than the circuits actual voltage. You will have to look up the specs on the old cap to know ESR and Ripple.
              [And you didn't say what it is.]
              A solid polymer 220uF might be an option.
              They handle heat better.
              Mann-Made Global Warming.
              - Dr Seuss
              • double_DD
                Why does my ISP router hate my "homemade" power supply??
                by double_DD
                It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                07-12-2025, 03:09 AM
                ASUS P5GC-MX motherboard recap
                by momaka
                Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                So here is what the motherboard looked like with its original caps:
                CPU VRM area up close…...
                01-27-2021, 11:59 PM
              • shadow666
                Router Xiaomi M4A Gigabit
                by shadow666
                hello
                i need dump backup for wifi router Xiaomi M4A Gigabit M43 R0101
                Mi Router 4A Gigabit Edition
                ROM CHIP is 16 MB
                i attached picture of motherboard​...
                11-30-2024, 03:49 PM
              • EasyGoing1
                UPNP, "Standards" and hardware that implements it
                by EasyGoing1
                I've been writing a program in Java that is really just a robust front end for the use of GitHiub Gists, providing a nice interface for developers to organize, maintain and access code snippets that we tend to need from time to time in our different projects.
                One of the features of the program is the ability for people to share their Gists with others who use the program over a LAN or over the Internet. The program just basically serializes a Java class and encrypts it then wraps it into a UDP datastream and sends it over to another user.
                So I decided to implement UPNP...
                07-16-2022, 07:12 PM
                no-name Radeon 9600 XT recap and cooler
                by momaka
                I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
                This one was actually suggested to me by ChaosLegionnaire....
                11-06-2020, 07:54 PM
