TP-LINK TL-GS1016D ver 8.0 burn
  • tahc81
    • Nov 2019
    • 42
    • Slovakia
    Hi all, I've been using external 12V PSU for this switch, but mistakenly connected it to 48V. Better do not ask how I'm going to rescue it, will replace both chips (shorted to ground), but both switching controllers were burnt as well.
    3.3V controller unreadable, SOT23-6.
    1.1V removed and forgot to note the remaining markings
    Anyone with same switch available to check? In a worst case, I'll use 2 step-down modules instead... Thanks
    • 30977
    Re: TP-LINK TL-GS1016D ver 8.0 burn
    48v?
    you tried to chain it via POE?
    • tahc81
      • Nov 2019
      • 42
      • Slovakia
      Originally posted by stj
      48v?
      I said, don't ask I forgot to connect step down 48->12 between battery and devices. Also Synology DS923+ died... That's when one used same connectors on both sides. Not the opposite polarity, but 4x voltage
        • 30977
        i have a 108e if it has the same parts, but probably not because it only needs half the power.
        • tahc81
          • Nov 2019
          • 42
          • Slovakia
          I bought same switch, but Ver.11 and it looks completely different... Whatever, will put an order on Ali to get the ICs, and use some step downs to test. Will be a pain to solder/check that TQFP-216.
          At least SPI EEPROM is readable, and there isn't anything else to be broken.
          • ttmi100x
            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
            by ttmi100x
            Greetings everyone,
            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
            Upon closer inspection...
            07-31-2024, 06:36 PM
          • howardc64
            Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
            by howardc64
            Eventually discovered a burn mark near lower corner of LCD. Here is a summary
            • Backlight on, no image
            • Disconnect right buffer board (view from front), left side display comes on
            • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
            • Buffer board is pretty simple
            Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
            07-11-2025, 04:04 PM
          • Seville
            Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
            by Seville
            Hello all!
            Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
            I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next....
            10-10-2022, 07:31 AM
          • dumbdd
            Sony VA panel burn in
            by dumbdd
            I have a Sony 75x940e that I just fixed with the help of the forum (bad emmc). For the last couple of months I was noticing some burn in of the android home icons on dark backgrounds (photo is attached). I always thought VA panels were immune to burn ins. Is there anything I can do to fix it? Could it be because of a failing component other than the panel itself?...
            07-19-2023, 09:23 PM
          • beal
            TPLINK TD-W9970(EU) Dump
            by beal
            hi
            Please bios dump Tplink TD-W9970(EU) Ver 2.0
            bios : 25Q64
            thanks
            12-26-2024, 01:10 AM
