Equipmet to trace Ethernet signal
+ More Options
Posts
  • gsan33
    • Feb 2023
    • 8
    • Russia
    I have Avaya 9641G IP Phone wich reports "No Ethernet" on the screen during initial start. I have intention to trace an Ehternet signal from the very input RJ45 jack throuth the phone mptherboard to the Broadcom communication CPU input pin.
    Need youe advice how to: first I have suggested to buy an oscilscope, but not sure what to select, the pro version may become too expencive, and basic version may not capture high frequesncy signal. I really don't what to spend a fortune just for the pleasure to see the Ethernet frames. I also considered to measure just an AC voltage at the Ethernet cable pair... but with lack of experience I finaaly decided to ask experts. So, what would you suggest to visualize and track Ethernet phisical signal flow over the phone mother board?
    • 30978
    Re: Equipmet to trace Ethernet signal
    how does it even know?
    is it trying to connect to something?
    • gsan33
      • Feb 2023
      • 8
      • Russia
      The phone has imbeded startup procedure. When you plug the Ethernet/PoE cable to the phone jack it starts to boot and writes some messages on the screen. After several minuties the phone writes: "No Ehternet" wich sipmply means the phone does not get any Ethernet frame from cable. Surely I have checked all possible connection issues. I finaly disassemebled the phone and looked inside - all electrical contacts seems to be fine, there are connections from input RJ45 pins to the motherboard. First they go to input transformers 1000 BASE –T MAGNETICS MODULES like 24HSS1041A-2 and it suppous to reach out to Broadcom IC. So, I need some equipmet to trace Ethernet pulses coming from a very input right to the Network Processor
        • 30978
        what i mean is, there will be no ethernet frame unless it requests something,
        and to do that it has to use an address - if your network has a firewall it could block the fone
        • CapLeaker
          Leaking Member
          • 8112
          Also make sure the phone wasn’t paired to a wifi dongle. If you pair a VOIP phone to a dongle and then disconnected the dongle without unpairing and plug it into an RJ45 cable it will also complain about no Ethernet. Guess how I found out.
          Most VOIP phones are POE capable so you don’t get T1000. T100 is all she wrote then, because 2 pairs are used for POE, then you have one pair TX and another pair for RX. Ethernet cable has 4 cable pairs. That’s it. I’d check the VOIP phone if it can handle POE and I would try to power the VOIP phone up that way. Look hard at the Ethernet jack, maybe it’s just a cold solder joint.
          If the problem is indeed the jack, it’s going to be hard to find a proper replacement without any schematic or parts diagram. In this case I would look up the data sheet for the responsible IC and see if there is an example circuit. It hopefully will show what magnetics the jack needs.
          • gsan33
            • Feb 2023
            • 8
            • Russia
            Here is what I do to force the Ethernet IC to start transmitting: I disable and enable Ethernet adapter in "Change adapter option" window. As soon as I hit the button "Enable" I immediately see some very low AC voltage right at the transmit pair. After some time, the voltage disappears and then comes back, it is about 0.2-.4 v measured by standard multimeter. I suppose I see a broadcast Ethernet frame, something like ARP request. So, it is really possible to get some transmission in the cable even without an IP address assigned. But using this multimeter is very ugly method to trace Ethernet pulses, so I am looking for some good oscilloscope
            • gsan33
              • Feb 2023
              • 8
              • Russia
              Also make sure the phone wasn't paired to a wifi dongle. If you pair a VOIP phone to a dongle and then disconnected the dongle without unpairing and plug it into an RJ45 cable it will also complain about no Ethernet. Guess how I found out.
              Most VOIP phones are POE capable so you don't get T1000. T100 is all she wrote then, because 2 pairs are used for POE, then you have one pair TX and another pair for RX. Ethernet cable has 4 cable pairs. That's it. I'd check the VOIP phone if it can handle POE and I would try to power the VOIP phone up that way. Look hard at the Ethernet jack, maybe it's just a cold solder joint.
              If the problem is indeed the jack, it's going to be hard to find a proper replacement without any schematic or parts diagram. In this case I would look up the data sheet for the responsible IC and see if there is an example circuit. It hopefully will show what magnetics the jack needs.
              The phone is pretty old and there is no WI-Fi option. I also worked hard with the input Ethernet jack, I am sure the cable connectivity is OK. I would like to trace Ehternet frames further, over the motherboard. I need to be sure that those frames really reach to the IC pins.
                • 30978
                how do you set the i.p. address?
                and does the router detect it?
                • CapLeaker
                  Leaking Member
                  • 8112
                  Maybe it’s set to a different weird IP and subnet?
                  • gsan33
                    • Feb 2023
                    • 8
                    • Russia
                    There is no IP address yet, no routers or firewalls. My home PC Ethernet adapter cable goes to PoE injector and goes to the phone. PoE comes via 7-8 and 4-5 pair, it works fine, -48 V comes to phone's motherboard, the phone display and buttons LED are working.
                    • gsan33
                      • Feb 2023
                      • 8
                      • Russia
                      Maybe it's set to a different weird IP and subnet?
                      Could be, but there is nothing like V-Lan or subnets around as there is no yet IP layer, the phone cryout "No Ehternet" it means
                      1) Connection problems - Jack, Cable, bended pins
                      2) Receiving tranfomators on the motherboard are out of order, some capasitors are in short ciurcuit, or metal path is destroyed... as result Ehternet electrics do not reach to IC pin
                      So need advice how to visualize Ehternet pulses, how to trace its track over motherboard
                        • 30978
                        i'm pretty sure you need a router to act as a gateway and DHCP server for either the phone OR windows to actually activate networking.
                        i know windows wont assign an i.p. to itself if it cant detect a network.
                        • Alphacentauri
                          • Mar 2023
                          • 3
                          The phone will probably look for an IP address via DHCP (unless you set a static address) and may just be failing to get an address from the server.
                          You could try using wireshark or tcpdump to see if anything is been sent on the wire when the phone starts.
                          • CapLeaker
                            Leaking Member
                            • 8112
                            For Avaya stuff look at www.pbxbook.com. There is some useful information there. Also www.voipdocs.io is a good source.
                            • pedrolane
                              • Mar 2023
                              • 36
                              • France
                              Do yourself a favour and first make a cross test.
                              If you plug a PC instead of the phone, does it see Ethernet up ?
                              If you plug the phone on another switch, another port, with another cable, does it still say "no ethernet"
                              Don't spend time checking router / firewall (layer 3), Ethernet is layer 2, it can work without router. If the Ethernet interface does not come up, it is an Ethernet issue.
                              As Capleader mentioned, Ethernet 100BT needs 1,2,3,6 pins only to work (2 pairs).
                              So you can use a cable with only 2 pairs to avoid the phone / the switch to try gigabit.
                              Also be sure to power the phone with an AC adapter first to test without power-over-ethernet (POE)
                              If you re sure POE is fine, check on switch side for warning message.
                              If only RX pair is okay, the switch may see the phone up, but brings the port down after few seconds when autonegotiation failed. if that is the case you can try to disable autoneg on switch side, and force 100 full-duplex.
                              • SluggerB
                                Help with trying to fix phone that is not charging (Pics inside)
                                by SluggerB
                                I have two TCL A30 phones.
                                Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                                New Phone: Works fine, bought as a donor board to try and repair Old Phone
                                My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                                08-12-2024, 08:11 AM
                              • keeney123
                                new OS on a Sonim XP5s phone
                                by keeney123
                                To you programmers out there I want to know if it is possible to put a new OS on the Sonim XP5s phone? I only need this phone to make calls, receive calls, have a list of contacts and be able to call voice mail.
                                I bought this phone new Sep.2021 as an unlock phone from a third-party seller. The phone worked fine until Jan 2022. I then had intermittent problems with the sound setting resetting itself. One of the settings, outdoor, would go to silent all by itself. When in silent mode it does not indicate a call has come in. I missed very important phone calls. All the other setting in sound...
                                05-13-2022, 07:19 PM
                              • AstutePauciloquent
                                Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                                by AstutePauciloquent
                                Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                                I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                                11-23-2023, 11:02 PM
                              • chth96
                                Is it possible bridging tiny broken trace
                                by chth96
                                When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                                cutting tiny trace.
                                This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                                Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                                But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                                12-03-2022, 11:32 PM
                                Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook T Specification for Upgrade or Repair
                                This specification for the Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T490s + Ethernet Extension Adapter Gen 2 boardview and T490s + Ethernet Extension Adapter Gen 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
                                09-06-2024, 08:58 AM
