Dell 2007WFP Won't Power On
  • peterfares
    • Aug 2010
    • 15
    Re: Dell 2007WFP Won't Power On
    The capacitor says 47uF 25V on it. Would it be ok to replace it with a 47uF 16V I have lying around? Also does anyone know if the monitor should start without the USB board in place? Because it doesn't.
    • retiredcaps
      • Apr 2010
      • 9271
      Originally posted by peterfares
      The 3A fuse shows 2000 ohms resistance. Is it good or blown?
      Also the voltage regulator on the USB board is showing the same resistance as the one that is supposedly fried.
      EDIT 2: I was able to scrape that gunk off the "blown" voltage regulator and it came off fine. The part doesn't appear to be damaged.
      A good fuse should read 0.3 ohms. Your 3A fuse is bad at 2000 ohms.
      Post another pic of the "blown" regulator. A reading of 5 ohms suggests it is shorted. The only way to know 100% is to measure it out of circuit so that other components are not affecting the reading.
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        Generally when you replace caps, it should be the same uF and voltage. You can put in the lower voltage cap IF you know 100% certain that it sits in a path where the voltage never exceeds 16V. So if you knew for sure, that this cap sits in the 12V circuit, you can use the 16V cap.
        • peterfares
          • Aug 2010
          • 15
          Does radio shack carry fuses? I can only find 250V fuses. Does the voltage only mean the maximum voltage?
          They appear to only have the glass fuses and the blade fuses.
          Also the "blown" regulator looks totally fine with the crap scraped off.
          • retiredcaps
            • Apr 2010
            • 9271
            You will find a better selection at digikey.com. Shipping from them is around $2.50 USD from what other members report here. Digikey also sells caps as well.
            Again, a reading of 5 ohms suggests that it is shorted (bad). Only way to know is to test out of circuit.
            edit: With all that crap scraped off, what is the part number on the chip?
            • peterfares
              • Aug 2010
              • 15
              #26
              It is a little hard to make out but it appears to be 960T65.
              Also is it possible to use the blade fuse or would that not work?
              • peterfares
                • Aug 2010
                • 15
                #27
                YES!
                I replaced the 3A fuse with a 3A tube fuse from RadioShack and the monitor works!
                Thanks for all your help!
                • jetadm123
                  • 2169
                  #28
                  Great job!! It wasn't as bad as you thought it might be.
                  Was that "gunk" covering the so called "blown" regulator electrolyte from the the cap? Is so, make sure you clean it up with distilled water and Qtips because it is corrosive.
                  I'm still a little puzzled how shorting out the 12 volt output affected the logic board so badly. Maybe you should use a 2A fuse instead of 3A.
                  Again, good work!
                  • peterfares
                    • Aug 2010
                    • 15
                    #29
                    I believe the stuff on the regulator was from the capacitor, there is a little bit of it all around that capacitor. Do you think it is going to go out soon?
                    Maybe the capacitor has nothing to do with what I did and is just a coincidence? I already put the whole monitor together without cleaning it up I'll have to do that some other day.
                    I also got some annoying scratches under the Dell logo trying to figure out how to open the damn thing.
                    • jetadm123
                      • 2169
                      #30
                      If that cap is leaking, it would be wise to replace it ASAP with a low-esr cap.
                      • freddy314
                        • Nov 2010
                        • 5
                        #31
                        Dell 2007WPFB went blank. No indications that it's powered.
                        And I didn't do anything - just read the news
                        Can't figure out how to open the back cover for a quick fuse check.
                        • freddy314
                          • Nov 2010
                          • 5
                          #32
                          UPDATE:
                          opened the box
                          found no fuses. No quick fixes like loose connector or so.
                          Looks like 2.5 years old DELL monitor is going to the recycling bin.
                          No more DELL for me thank you.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            I have opened 17 or 18 monitors and every one has at least one fuse on it. However, it may not be your problem.
                            If you are giving up, then post it on craigslist or something like that. Others will want a chance to fix it.
                            • freddy314
                              • Nov 2010
                              • 5
                              #34
                              retiredcaps,
                              thanks for the quick reply!
                              Will try tomorrow to locate the fuse one more time.
                              Could you please give me an idea where it could be?
                              Fuse is the only thing I possibly could "fix".
                              • freddy314
                                • Nov 2010
                                • 5
                                #35
                                Found and checked the fuse - OK.
                                It's beyond my capacity.
                                IF anybody need this monitor in Calgary - you welcome to pick it up.
                                • Diablo_Rojo
                                  • 28
                                  #36
                                  Just in case you have not,check warranty status of your monitor. I see many with a 3 year warranty and you said 2.5 year old Dell. I just hate to see it end up in a garbage fill.
                                  • freddy314
                                    • Nov 2010
                                    • 5
                                    #37
                                    I checked paperwork - 3years warranty. But I was wrong in the monitor's age - it's 3 years and 4 months.
                                    Thanks for the idea anyway, I was sure it's 1 year warranty.
                                    Anyway I have somebody from this forum interested in taking it.
                                    I hope it will be easy fix for him!
                                    I already researching for a new RELIABLE monitor.
                                    • core2kid
                                      • Jan 2011
                                      • 15
                                      #38
                                      Sorry to bring this old thread back to life but I'm having a similar problem.
                                      I have a second 2007WFP which will only flash the power and <- continuously. I replaced every board with a known good one and came down to the conclusion that the USB hub board has a fault in it. I broke it down even further and figured out that if I bend pin 3 out of the way, the monitor powers on but I don't see a picture on it. Any ideas?
                                      Pin 3 is:
                                      If you take peterfares picture below
                                      https://www.badcaps.net/forum/attach...8&d=1281651994
                                      take the 12 pin connector at the bottom. The shown pin all the way to the left is pin 2. The one below it is pin 1. The one to the left of that is pin 3.
                                      If you all need any pictures let me know. Thanks for all your help.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Pin 3 is:
                                        I would want to see pictures of YOUR board, good clear pictures of both top and bottom. That board is not only the USB hub board, it is the power input board.
                                        PlainBill
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #40
                                          1) I echo what PlainBill says. We want to see pictures of your board.
                                          2) Check the voltage regulators (marked U) and diodes (FD) for shorts (especially FD3 and FD4).
